insert image
Hello,
I'm trying to figure out to create 4 div tags within a body content area. And have them formatted with two on top and two right beneath. Then have a right hand column within this body area. Here is the code I have so far. Its more about getting the format I need.
<div id="body">
<div id="1">Content for id "1" Goes Here</div>
<div id="2">Content for id "2" Goes Here </div>
<div id="3">Content for id "3" Goes Here </div>
<div id="4">Content for id "3" Goes Here</div>
<div id="4">Content for id "RighhandColumn" Goes Here</div>
</div>
Any help?
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Untitled Document</title>
<style>
body {
width: 960px;
margin: auto;
.article {
width: 60%;
float: left;
background: #FFF;
.three {
margin-top: 20px;
.aside {
width: 35%;
float: right;
min-height: 250px;
background: #FFC;
</style>
</head>
<body>
<div class="aside">Content for id "RighhandColumn" Goes Here</div></body>
<div class="article one">Content for id "1" Goes Here</div>
<div class="article two">Content for id "2" Goes Here</div>
<div class="article three">Content for id "3" Goes Here</div>
<div class="article four">Content for id "3" Goes Here</div>
</html>
Gramps
Note that in your original example, you have written the same id twice:
Just wanted to make sure you understand classes (as in Gramp's response) may be used multiple times on a page, but IDs may only be used once. In this case, your last ID would logically be "5."
Chris
One more thing, I tried that code at the computer lab, and it shows the two
boxes are on top of each other.
Do you know how I can make two box appear side by side to each other and
then have another row right beneath with two boxes side by side.
The right hand column does appear to be on the right side within this area,
so thanks for that.
Chris
That is a very good comment, one that has opened a debate whether to use ID's when only used for styling purposes. The contemporary trend is to use CLASS's for styling purposes and ID's when one wants to identify an element to manipulate it using scripts.
A good example is the SpryMenuBar where menubar widgets are identified with an ID and styles are given to a CLASS as in
<ul id="MenuBar1" class="MenuBarHorizontal">
<li><a class="MenuBarItemSubmenu" href="#">Item 1</a>
<ul>
<li><a href="#">Item 1.1</a></li>
<li><a href="#">Item 1.2</a></li>
<li><a href="#">Item 1.3</a></li>
</ul>
</li>
<li><a href="#">Item 2</a></li>
<li><a class="MenuBarItemSubmenu" href="#">Item 3</a>
<ul>
<li><a class="MenuBarItemSubmenu" href="#">Item 3.1</a>
<ul>
<li><a href="#">Item 3.1.1</a></li>
<li><a href="#">Item 3.1.2</a></li>
</ul>
</li>
<li><a href="#">Item 3.2</a></li>
<li><a href="#">Item 3.3</a></li>
</ul>
</li>
<li><a href="#">Item 4</a></li>
</ul>
<script>
var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", {imgDown:"SpryAssets/SpryMenuBarDownHover.gif", imgRight:"SpryAssets/SpryMenuBarRightHover.gif"});
</script>
A second menubar will have an ID of MenuBar2 (or similar) and deviating style rules will be addressed using ul#MenuBar2.MenuBarHorizontal as the selector. Notice how #MenuBar2 is used to identify the menu list element and is not allotted a style.
Gramps
Hacks and if that's not bad enough hacks for IE5????????????(who the F••K uses IE5??????
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarHorizontal iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarHorizontal li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
The whole css needs rewriting.
Hello Gramps,
Thanks again for your help. So I applied your changes and still cant the
two boxes in the second row to match up the two boxes in the first row.
Could you take a look? Thanks
http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
body {
background-color: #CF3;
height: auto;
width: 960px;
margin-right: auto;
margin-left: auto;
#wrapper {
background-color: #CCC;
width: 960px;
margin-right: auto;
margin-left: auto;
height: auto;
#logo
#banner
#navbar {
background-color: #FFF;
height: auto;
width: 960px;
font-family: Arial, Helvetica, sans-serif;
font-size: 24px;
font-style: normal;
font-weight: bold;
text-transform: uppercase;
color: #F00;
text-align: center;
border-top-width: medium;
border-bottom-width: medium;
border-top-style: solid;
border-bottom-style: solid;
border-top-color: #000;
border-bottom-color: #000;
#rightside
.article
!art116/owzhu/images/PandaBanner2.jpg|height=175|width=700|src=art116/ owzhu/images/PandaBanner2.jpg!
!art116/owzhu/images/PandaLogo.jpg|height=175|width=260|src=art116/owz hu/images/PandaLogo.jpg!
home | listings | events | classifieds | FAq's |
about
Content for id "box1" Goes Here
insert image
insert image
insert image
insert image
</html
Is this more or less what you're trying to do? View source to see the code.
http://alt-web.com/TEMPLATES/2-col-fixed-with-floats.shtml
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
