Muse question: I export to html, and have all the files including .css, files for images, etc. I moved them over to my domain (not business catalyst), but the file being pulled up looks wrong... potentially not linking correctly to css. Also, no other script files exported, and I suspect there should be javascript as its cited in the html. I did have to change the name of the html document (default to index), but did not move anything around in folders so they should link together. Any thoughts on how I can get this to look like I laid it out?
http://unitedwayofeastcentraliowa.org/leadership/leadershipoverview.ht ml is where this is at for now. All other exported documents in same directory. No scripts folder was exported. I've done this before with no problem. I really don't know what's wrong. Thanks for your help.
I see that. I also see that on export of any file out of Muse (file - export as html) it exports only index.css and no files under scripts/1.1 as has worked in the past. I was recently working on an old file, and tried to export and see that it did not re-create the scripts I need to put on my server.
Muse only gives me the option to export to Documents\MuseExport. I am working with the "Release Version". I have the Creative Cloud, but haven't seen Muse as an available update under that yet. Maybe the problem is that. You've been so helpful... can you help me some more? Thanks.
