Auto Reset Prefs?
Jun 13, 2012 12:50 PM
Tags: #reset_prefs
This morning, I got up early to finish a project. Photoshop looked loke it had been invaded by some sort of hack, at least to someone at 4AM before coffee!
It turned out that preferences had been reset to default, except for the arrangement of palettes on my second screen. And that really confused me. It took a while to realize exactly what happened. When I told PS to Reset my personal settings, then the palettes also changed.
So, what happened?
I'm running CS6 on Win 7 Ultimate 64 bit. I don't turn the computer off, I use Sleep Mode over night. A reboot of course did nothing to fix it.
It took over an hour to finally understand what happened and begin to reset everything back. Some items like Open CL and such remained as I set it but others, even my custom hot keys went back to default. Hence the hour+ to redo it.
Looking for the Reset Prefs file, I found it under Roaming. I assume that is the correct file. I also found a separate file for setting keystrokes and several others, also indicting that they had been changed this date. So until I scope out all those controls I don't know what actually changed back to what. I saved it to the desktop to prepare for similar problems in the future. Do I need to save anthing else?
A side but appropriate note: Shift+F6 does not bring up the Feathering Dialog. It brings up Flip. The keystroke dialog says Shift+F6 controls Feathering. So Feathering had to be reset. I set it to Ctrl+Alt+F6. This was true for the beta version but is still true for the Release version.
There may be others.
  • Noel Carboni
    Dec 23, 2006
    Jun 13, 2012 1:45 PM   in reply to Hudechrome
    Lawrence, please let me rephrase what I read to ensure I understdand you:
    What you're saying is that on a Photoshop startup you found Photoshop to have reset preferences, but not your workspace, without your having done so?  Or was Photoshop already running?
    As you may have read in my book, I advise against using sleep states.  That may not be "green thinking", but Windows just has a lot of trouble waking all its hardware up, and I've run across more folks than not who have trouble after suspending their systems.
    It's better to just either leave your system on and allow it to turn off the monitors and spin down the disks, or just shut it down fully if you want maximum power savings.  If you choose the latter, it's well worth the few moments longer it takes to boot up.  Personally, I leave my system on 24/7 and I just don't have trouble...  At the moment it's been running and under hard use for just over 12 days, since the last software update required a restart.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Jun 14, 2012 8:45 AM   in reply to Hudechrome
    I've no experience with manually manipulating Photoshop preferences files myself because I simply haven't had to do so.  Here's hoping someone else will chime in on what files you should manipulate to effect a restoral of your prefs.  I'm not sure whether you'd have to create a script or batch file that would manipulate files in multiple different folders.
    This page describes what the various files are and where they can be found:  http://helpx.adobe.com/photoshop/kb/preference-file-functions-names-lo cations.html
    That help page suffers from version ambiguity (it says CS5 and multiple different versions e.g., 11.0, 12.0), but if you substitute CS6 and 60.0 in appropriate places you get what you need.
    -Noel
    Jun 14, 2012 8:59 AM   in reply to Hudechrome
    Do you by chance have the Commands action set loaded? That set has the Shift+F6 shortcut set for Flip Horizontal.
    For years once i install a new version of photoshop and get the preferences, workspaces and such set, then i make a copy of the whole preferences folder (adobe photoshop cs6 in your case)
    (C:\Users\Your Name\AppData\Roaming\Adobe\Adobe Photoshop CS6) and save it somewhere on my hard drive. Then if you need to reset the preferences one can just replace that folder with your backup.
