Compilation failed while executing: ADT
Feb 12, 2012 11:31 AM
I have a project that I've been successfully compiling for iOS in Flash Professional 5.5, with uses AIR 2.6. I decided to try compiling in Flash Builder 4.6 using AIR 3.1. It runs fine on the desktop, no errors or warnings. When I try to do an Ad Hoc release build, it fails with java.lang.NullPointerException at java.util.TreeMap.getEntry(TreeMap.java:324), (The Export Release Build dialog does not let me select the text, otherwise I'd paste the stack here)starting at com.adobe.air.ipa.BitcodeGenerator.main(BitcodeGenerator.java:82) and saying  "Compilation failed while executing: ADT"
Any suggestions would be appreciated!
John
    Jun 14, 2012 11:55 AM   in reply to John R Nyquist
    I am having the same exact problem right now, and as far as I can tell, this post is the only example of it on the internet, and it has no replies.. Did you ever figure out what was happening?
    Jun 14, 2012 9:12 PM   in reply to John R Nyquist
    Hi John,
    Could you please try packaging it on command line using ADT (available @ C:\Program Files\Adobe\Adobe Flash Builder 4.x\sdks\4.x\bin)
    # adt -package -target ipa-ad-hoc -provisioning-profile <path to mobileprovision> -storetype pkcs12 -keystore <path to p12> -storepass <password> hellworld.ipa hellworld-app.xml hellworld.swf
    Is it specific to ipa-ad-hoc target only? Could you try it with other targets like ipa-app-store or ipa-test-interpreter
    Please share the adt version by executing following command.
    # adt -version
    -Thanks
    Pahup
    Jun 15, 2012 7:03 AM   in reply to Pahup
    I'm not John, but I have the exact same issue, same traceback. I'm compiling on the commandline with adt version 3.1.0.4880, but it also happens with sdk versions 3.2 and 3.3. If I compile the SWF using -debug, the problem doesn't occur - only with the release build. It also occurs with the ipa-app-store target, but not with ipa-test-interpreter (not too surprising, given the error traceback).
    Jun 15, 2012 7:05 AM   in reply to Pahup
    Oh, and here's the complete traceback:
    Exception in thread "main" java.lang.NullPointerException
            at java.util.TreeMap.getEntry(Unknown Source)
            at java.util.TreeMap.get(Unknown Source)
            at adobe.abc.Algorithms$SetMap.get(Algorithms.java:223)
            at adobe.abc.Algorithms.addUses(Algorithms.java:166)
            at adobe.abc.Algorithms.findUses(Algorithms.java:186)
            at adobe.abc.GlobalOptimizer.sccp(GlobalOptimizer.java:4626)
            at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:3514)
            at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:2215)
            at adobe.abc.LLVMEmitter.optimizeABCs(LLVMEmitter.java:527)
            at adobe.abc.LLVMEmitter.generateBitcode(LLVMEmitter.java:337)
            at com.adobe.air.ipa.AOTCompiler.convertAbcToLlvmBitcodeImpl(AOTCompiler
    .java:510)
            at com.adobe.air.ipa.BitcodeGenerator.main(BitcodeGenerator.java:80)
    Compilation failed while executing : ADT
    Jun 15, 2012 3:35 PM   in reply to Pahup
    FWIW, the problem also occurs with -target ipa-test.
    Jun 17, 2012 8:13 AM   in reply to panicolai
    Thanks for your reply, please raise the bug @ https://bugbase.adobe.com/ request you to attach relevant sources/swf/xml, so that we could investigate the issue at our end.
    -Pahup
