Extension managert CS6 never finishes loading extensions
Jun 12, 2012 8:07 AM
Tags: #problems #extension_manager
I have Dreamweaver CS5 anCS6 installed and am trying to open extension manager CS6 to load extensions. It will not finish "Loading Extensions".
    Jun 13, 2012 1:28 AM   in reply to boydbartley
    Has Extension Manager never finished loading since you installed CS6? Or it stopped working after you had installed some extensions? Please generate log files and paste the content here. You can click "Frequently Asked Questions" at the right of the forum homepage to know how to generate log files, or simply click http://forums.adobe.com/community/creativesuites/extensionmanager/faq.
    Jun 14, 2012 6:23 PM   in reply to boydbartley
    Is your account in admin group? Or you can try to run cmd as admin. Start ---> All Programs ---> Accessories, right click "Command Prompt", select "Run as dministrator", and select 'Yes". Then try "echo > ExManLog.YES" again.
    Jun 14, 2012 8:10 PM   in reply to boydbartley
    Yes, even if you signed in as Admin, you still need to run this command as admin too. Oterwise, you will have "Access is denied." warning message. Start ---> All Programs ---> Accessories, right click "Command Prompt", select "Run as dministrator", and select 'Yes". Then cd to "C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6\",  try "echo > ExManLog.YES" again.
    Apr 1, 2013 6:29 AM   in reply to boydbartley
    I'm having the same exact problem.
    • Extension manager never stops "Loading Extensions."
    • Following directions for generating log file (ExManLog.YES), but it's not generating a log file.
    I'm using CS6 (Creative Cloud subscriber) and am using Mac OS 10.8.3.
    Any help/thoughts?  It's becoming a bit of a blocker that I can't install any extensions.
    Apr 1, 2013 7:26 AM   in reply to Matthew Ferrell
    Hi Matthew,
    Please make sure that there is no other extension name in "ExManLog.YES"( windows will hide the extension name by default so make sure the file is NOT "ExManLog.YES.txt" ). The log file will be created next time Extension Manager is launched. The log file is in "C:\Users\<username>\AppData\Roaming\Adobe\Extension Manager CS6".
    Xiaoyi
    Apr 1, 2013 7:31 AM   in reply to Xiaoyi Tong
    I'm on a Mac and generated ExManLog.YES in the terminal using the touch command.  There's no other extension on it.
    Apr 1, 2013 7:43 AM   in reply to boydbartley
    The instructions on the knowledge base article I used were wrong.  Finally got the log to generate and here it is.  Any idea why I can't get past the "loading extensions"?
    [INFO] Mon Apr  1 10:41:45 2013 [.622] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/main.mm,808) -BridgeTalk initialized successfully.
    [INFO] Mon Apr  1 10:41:45 2013 [.692] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/main.mm,765) -initStage succeed.
    [INFO] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/main.mm,201) -AIR is ready for waiting the invocation from C++ side
    [DEBUG] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedLocalList.cpp,56) -Sending Get Locale list request to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airGetLocaleList
    [DEBUG] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.495] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb _NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.565] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/PumpBridgeTalkMessageCommand.cpp,67) -PumpBridgeTalkMessageCommand::execute(), register bridge talk message handler.
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-1. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedLocalList.cpp,81) -Get Locale list completed
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.566] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.567] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.567] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.568] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.568] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airSetLocale
    [DEBUG] Mon Apr  1 10:41:46 2013 [.568] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.568] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.568] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.573] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1327) -Extension Mnaager starts initializing
    [DEBUG] Mon Apr  1 10:41:46 2013 [.576] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrExtensionManagerProduct.cpp,193) -Application name is Adobe Extension Manager CS6
    [FATAL] Mon Apr  1 10:41:46 2013 [.578] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,264) -create directory failed
    [DEBUG] Mon Apr  1 10:41:46 2013 [.585] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,90) -Application path is /Applications/Adobe Illustrator CS6
    [INFO] Mon Apr  1 10:41:46 2013 [.587] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/5.0/Providers/Plugins2/WRLiloPlugin1.2.bund le/Contents), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.588] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Photoshop CS5.1), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.588] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe InDesign CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.588] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Media Encoder CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.589] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Extension Manager CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.589] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/5.5/Providers/Plugins2/WRLiloPlugin1.2.bund le/Contents), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.590] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Device Central CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.590] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Fireworks CS5.1), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.591] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.591] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Flash Catalyst CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.591] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/5.5/Providers/Plugins2/AdobeHunspellPlugin. bundle/Contents), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.592] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/XMP/Custom File Info Panels/3.0/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.592] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/TypeSupport/CS5/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.593] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Dreamweaver CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.593] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Utilities/Adobe Utilities-CS5.5.localized/ExtendScript Toolkit CS5.5/ExtendScript Toolkit.app), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.594] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/5.0/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.594] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Illustrator CS5.1), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.594] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Bridge CS5.1 Extensions/Adobe Output Module), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.595] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/PDFL/9.9/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.595] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/TypeSupport/CS5/CMaps/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.596] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Flash CS5.5), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.597] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/ssc/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.597] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Bridge CS5.1), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.597] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/5.5/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.599] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Audition CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.600] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/XMP/Custom File Info Panels/4.0/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.600] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Fireworks CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.601] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Extension Manager CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.602] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Edge Animate), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.603] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe After Effects CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.603] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Utilities/Adobe Utilities-CS6.localized/ExtendScript Toolkit CS6/ExtendScript Toolkit.app), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.604] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Bridge CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.604] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Media Encoder CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.605] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Camera Raw 7), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.606] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/6.0/AMT), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.609] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Photoshop CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.609] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/6.0/Providers/Plugins2/WRLiloPlugin1.3.bund le/Contents), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.610] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Library/Application Support/Adobe/Linguistics/6.0/Providers/Plugins2/AdobeHunspellPlugin. bundle/Contents), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.611] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Creative Cloud Connection), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.617] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Illustrator CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.620] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Premiere Pro CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.620] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Encore CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.627] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,232) -Got installed languages for key (/Applications/Adobe Flash CS6), with value (en_US).
    [INFO] Mon Apr  1 10:41:46 2013 [.627] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,273) -Got dummy languages for key (/Applications/Adobe Flash CS6), with value (da_DK,en_US;en_AE,en_US;en_GB,en_US;en_IL,en_US;es_MX,es_ES;fi_FI,en _US;fr_CA,fr_FR;fr_MA,fr_FR;hu_HU,en_US;nb_NO,en_US;uk_UA,en_US;).
    [INFO] Mon Apr  1 10:41:46 2013 [.633] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,360) -For product (/), the installed languages are (e)
    [DEBUG] Mon Apr  1 10:41:46 2013 [.633] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,76) ----Begin to read xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.633] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,77) -The present xman data file is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.633] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,78) -MAC OS:Applications:Adobe Illustrator CS6:Configuration:XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,87) ----End to read  xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,68) -Sending XML contents to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airParseXML
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --3
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Illustrator CS6/Configuration/XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
    [DEBUG] Mon Apr  1 10:41:46 2013 [.634] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.651] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.651] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.651] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.651] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --3
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$illustrator
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$plugin
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder/Plug-ins.localized
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$scripting
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder/Scripting.localized
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder/Presets.localized
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -DisplayName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -FamilyName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductVersion
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -16.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -HostNameForCSXS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ILST
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -IconPath
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Configuration/ai_app_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -SupportedInSuite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -DefaultLocale
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-3. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.706] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,111) -XML contents parse completed
    [FATAL] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Illustrator
    [DEBUG] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,401) -Product Name for illustrator-16.064 is Illustrator
    [FATAL] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1317) -Display Name for illustrator-16.064 is Illustrator CS6
    [FATAL] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -16.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,444) -Product version forIllustrator CS6 is 16.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,463) -Language code for Illustrator CS6 is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.707] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,191) -Icon Path for Illustrator CS6 is /Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,382) -Product Family Name for illustrator-16.064 is Illustrator
    [DEBUG] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product illustrator-16.064 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1459) -EMStore path per-machine for illustrator-16.064 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:EM Store:Illustrator CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1528) -MxiFlag path per-machine for illustrator-16.064 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:Mxi Flag:Illustrator CS6:
    [FATAL] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.708] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.709] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.709] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.710] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product illustrator-16.064 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.710] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Illustrator CS6 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.711] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,90) -Application path is /Applications/Adobe Photoshop CS6
    [INFO] Mon Apr  1 10:41:46 2013 [.711] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,360) -For product (/), the installed languages are (e)
    [DEBUG] Mon Apr  1 10:41:46 2013 [.711] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,76) ----Begin to read xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.711] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,77) -The present xman data file is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.711] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,78) -MAC OS:Applications:Adobe Photoshop CS6:Configuration:XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,87) ----End to read  xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,68) -Sending XML contents to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airParseXML
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --4
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
    [DEBUG] Mon Apr  1 10:41:46 2013 [.712] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --4
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -EmStorePath
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$SharedRibsDataFolder/Adobe/Extension Manager
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$installfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.729] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder/Plug-Ins
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder/Presets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$platform
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Mac
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$actions
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Actions
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$blackandwhite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Black and White
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$brushes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Brushes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$channelmixer
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Channel Mixer
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$colorbooks
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Color Books
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$colorrange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Color Range
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$colorswatches
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Color Swatches
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$contours
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Contours
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$curves
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Curves
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$customshapes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Custom Shapes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$duotones
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Duotones
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$exposure
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Exposure
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$gradients
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Gradients
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$huesat
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Hue Sat
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$imagestatistics
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Image Statistics
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$keyboardshortcuts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Keyboard Shortcuts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$layouts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Layouts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$lenscorrection
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Lens Correction
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$levels
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Levels
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$liquifymeshes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Liquify Meshes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$menucustomization
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Menu Customization
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$optimizedcolors
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Optimized Colors
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$optimizedoutputSettings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Optimized Output Settings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$optimizedsettings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Optimized Settings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$patterns
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Patterns
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$reducenoise
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Reduce Noise
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$replacecolor
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Replace Color
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$scripts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Scripts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$selectivecolor
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Selective Color
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$shadowhighlight
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Shadow Highlight
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$smartsharpen
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Smart Sharpen
    [DEBUG] Mon Apr  1 10:41:46 2013 [.730] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$styles
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Styles
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$textures
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Textures
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$tools
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Tools
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$variations
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Variations
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$webphotogallery
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Web Photo Gallery
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$workspaces
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Workspaces
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$zoomify
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Zoomify
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$hueandsaturation
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Hue and Saturation
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$lights
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Lights
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$materials
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Materials
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$meshes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Meshes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$rendersettings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Render Settings
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$volumes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Volumes
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$widgets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$presetsfolder/Widgets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder/Locales
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$additionalplugins
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Plug-ins
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$additionalpresets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localeskeyboardshortcuts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesmenucustomization
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesworkspaces
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$automate
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Automate
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$digimarc
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Digimarc
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$displacementmaps
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Displacement Maps
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$effects
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Effects
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$extensions
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Extensions
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$fileformats
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/File Formats
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$filters
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Filters
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$imagestacks
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Image Stacks
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$importexport
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Import-Export
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$measurements
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Measurements
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$panels
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Panels
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$parser
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Parser
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$3dengines
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/3D Engines
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$lightingstyles
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$pluginsfolder/Filters/Lighting Styles
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$matlab
    [DEBUG] Mon Apr  1 10:41:46 2013 [.731] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder/MATLAB
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -UserExtensionFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$photoshopappfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Adobe Photoshop CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -DisplayName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -FamilyName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductVersion
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -13.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -IconPath
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Configuration/PS_exman_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -SupportedInSuite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -HostNameForCSXS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -PHSP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-4. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.732] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,111) -XML contents parse completed
    [FATAL] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Photoshop
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,401) -Product Name for photoshop-60.032 is Photoshop
    [FATAL] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1317) -Display Name for photoshop-60.032 is Photoshop CS6
    [FATAL] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -13.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,444) -Product version forPhotoshop CS6 is 13.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,463) -Language code for Photoshop CS6 is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,191) -Icon Path for Photoshop CS6 is /Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,382) -Product Family Name for photoshop-60.032 is Photoshop
    [DEBUG] Mon Apr  1 10:41:46 2013 [.734] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product photoshop-60.032 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.735] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1459) -EMStore path per-machine for photoshop-60.032 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:EM Store:Photoshop CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.735] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product photoshop-60.032 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.735] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1528) -MxiFlag path per-machine for photoshop-60.032 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:Mxi Flag:Photoshop CS6:
    [FATAL] Mon Apr  1 10:41:46 2013 [.738] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.738] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.739] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.739] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.741] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.741] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Mac
    [FATAL] Mon Apr  1 10:41:46 2013 [.742] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.743] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.744] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product photoshop-60.032 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.744] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Photoshop CS6 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,90) -Application path is /Applications/Adobe Premiere Pro CS6
    [INFO] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,360) -For product (/), the installed languages are (e)
    [DEBUG] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,76) ----Begin to read xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,77) -The present xman data file is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,78) -MAC OS:Applications:Adobe Premiere Pro CS6:Configuration:XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.745] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,87) ----End to read  xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,68) -Sending XML contents to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airParseXML
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Premiere Pro CS6/Configuration/XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
    [DEBUG] Mon Apr  1 10:41:46 2013 [.746] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Premiere
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -DisplayName
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductVersion
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -HostNameForCSXS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -PPRO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -IconPath
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Configuration/pr_icon_24.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -SupportedInSuite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Bit
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -64
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-5. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.752] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,111) -XML contents parse completed
    [FATAL] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Premiere
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,401) -Product Name for premierepro-6.0 is Premiere
    [FATAL] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1317) -Display Name for premierepro-6.0 is Premiere Pro CS6.0
    [FATAL] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,444) -Product version forPremiere Pro CS6.0 is 6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,463) -Language code for Premiere Pro CS6.0 is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,191) -Icon Path for Premiere Pro CS6.0 is /Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrCommonProduct.cpp,382) -Product Family Name for premierepro-6.0 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.753] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product premierepro-6.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.754] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1459) -EMStore path per-machine for premierepro-6.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:EM Store:Premiere Pro CS6.0:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.754] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product premierepro-6.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.754] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1528) -MxiFlag path per-machine for premierepro-6.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:Mxi Flag:Premiere Pro CS6.0:
    [FATAL] Mon Apr  1 10:41:46 2013 [.754] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.754] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.755] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.755] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.755] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product premierepro-6.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.755] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Premiere Pro CS6.0 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrDreamweaver11_5.cpp,93) -Application path is /Applications/Adobe Dreamweaver CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrDreamweaver11_5.cpp,108) - does not exist
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.757] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,211) -The product dreamweaver-11.5 is not supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product dreamweaver-11.5 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.758] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS5.5 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrDreamweaver12.cpp,95) -Application path is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.759] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.760] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrDreamweaver9.cpp,237) -Language code for Dreamweaver is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,211) -The product dreamweaver-12.0 is not supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product dreamweaver-12.0 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Dreamweaver CS6 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.761] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFireworks11_5.cpp,100) -Application path is /Applications/Adobe Fireworks CS5.1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.762] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFireworks11_5.cpp,115) - does not exist
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.777] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,211) -The product fireworks-11.1 is not supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product fireworks-11.1 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.778] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Fireworks CS5.1 is
    [DEBUG] Mon Apr  1 10:41:46 2013 [.779] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFireworks12.cpp,100) -Application path is /Applications/Adobe Fireworks CS6
    [INFO] Mon Apr  1 10:41:46 2013 [.779] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,360) -For product (/), the installed languages are (e)
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,76) ----Begin to read xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,77) -The present xman data file is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,78) -MAC OS:Applications:Adobe Fireworks CS6:Configuration:XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,87) ----End to read  xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,68) -Sending XML contents to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airParseXML
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
    [DEBUG] Mon Apr  1 10:41:46 2013 [.780] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -HostNameForCSXS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -FWKS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -ProductVersion
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -12.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.791] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -PreExtensionFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$SharedCommonDataFolder/Adobe/Fireworks CS6/PreInstall
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$fireworks
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$installfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$fireworksuser
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$userdatafolder/adobe/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -SupportedInSuite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Bit
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -32
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-6. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.792] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,111) -XML contents parse completed
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.806] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.807] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.807] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.807] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFireworks9.cpp,375) -Language code for Fireworks CS4 is en
    [FATAL] Mon Apr  1 10:41:46 2013 [.808] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.808] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.808] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.809] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product fireworks-12.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.809] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1459) -EMStore path per-machine for fireworks-12.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:EM Store:Fireworks CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.809] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1528) -MxiFlag path per-machine for fireworks-12.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:Mxi Flag:Fireworks CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.809] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Fireworks CS6 is MAC OS:Library:Application Support:Adobe:Fireworks CS6:PreInstall:
    [FATAL] Mon Apr  1 10:41:46 2013 [.810] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.810] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -12.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.811] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash11_5.cpp,580) -The User perferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash11_5.cpp,449) -The present language code for Flash CS5 is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash11_5.cpp,472) -Application path is /Applications/Adobe Flash CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash11_5.cpp,488) - does not exist
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1726) -=====Supported locales list items:=====
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ja_JP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fr_FR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -de_DE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -es_ES
    [DEBUG] Mon Apr  1 10:41:46 2013 [.812] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -it_IT
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pt_BR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nl_NL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -sv_SE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -nb_NO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -da_DK
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -fi_FI
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ru_RU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -pl_PL
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_CN
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -zh_TW
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -ko_KR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -cs_CZ
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -hu_HU
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -tr_TR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.813] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1730) -uk_UA
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1750) -The User preferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../../../Borg/Source/MMFC/Source/MacrOS.cpp,1753) -en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash11_5.cpp,580) -The User perferred language code is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash9.cpp,183) -Language code for Flash is en_US
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,211) -The product flash-11.5 is not supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.814] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product flash-11.5 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.815] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash12.cpp,464) -Application path is /Applications/Adobe Flash CS6
    [INFO] Mon Apr  1 10:41:46 2013 [.815] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProductInfoFromCapsLib.cpp,398) -For product (/), the installed languages are (e)
    [DEBUG] Mon Apr  1 10:41:46 2013 [.815] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,76) ----Begin to read xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.815] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,77) -The present xman data file is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.815] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,78) -MAC OS:Applications:Adobe Flash CS6:XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MactProductInfoFromBridge.cpp,87) ----End to read  xman configuration data file---
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,68) -Sending XML contents to AIR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airParseXML
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --7
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Flash CS6/XManConfig.xml
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Configuration.VariableForExMan.Data
    [DEBUG] Mon Apr  1 10:41:46 2013 [.816] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) --7
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$UserExtensionFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$UserDataFolder/Adobe/Flash CS6/$Locale/Configuration/Extensions
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -SupportedInSuite
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -HostNameForCSXS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -FLPR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -Bit
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -32
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$RootFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$RootFolderLocal
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$InstallFolder/$LOCALE
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$flash
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -$UserBinfolder
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,165) -RequestId is-7. It is a request used to unlock OK/Cancel
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/macrgetXml_impl.cpp,111) -XML contents parse completed
    [DEBUG] Mon Apr  1 10:41:46 2013 [.831] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash9.cpp,183) -Language code for Flash is en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.832] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,104) -the source path is not correct:
    [FATAL] Mon Apr  1 10:41:46 2013 [.832] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -en_US
    [FATAL] Mon Apr  1 10:41:46 2013 [.832] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/MacPathConvert.cpp,105) -CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.833] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/Products/MacrFlash9.cpp,215) -User bin folder for Flash is MAC OS:Users:********:Library:Application Support:Adobe:Flash CS6:en_US:Configuration:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.833] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product flash-12.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.833] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1459) -EMStore path per-machine for flash-12.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:EM Store:Flash CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.834] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,203) -The product flash-12.0 is supported by CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.834] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1528) -MxiFlag path per-machine for flash-12.0 is MAC OS:Library:Application Support:Adobe:Extension Manager CS6:Mxi Flag:Flash CS6:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.834] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,1283) -Preferred folder for Flash CS6 is
    [INFO] Mon Apr  1 10:41:46 2013 [.836] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,2126) -Database connection is established successfully.
    [INFO] Mon Apr  1 10:41:46 2013 [.838] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,2249) -User database is attached successfully.
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1432) -All products hav been processed and saved in DB
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1533) -Extension Manager initialization finished.
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/commandExecutor.cpp,40) -OWL Controller initialized succeed
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airNotifyReady
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) --9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.841] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.845] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.845] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetExManConfigPath
    [DEBUG] Mon Apr  1 10:41:46 2013 [.845] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.845] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.845] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,66) -ExMan machine EMStore path: /Library/Application Support/Adobe/Extension Manager CS6/EM Store
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,85) -ExMan my EMStore path: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,92) -Version number is:
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,93) -6.0.5.9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetSupportedProducts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -3
    [DEBUG] Mon Apr  1 10:41:46 2013 [.846] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [INFO] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,152) -ExMan's last version's reource folder does not exist
    [INFO] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/getExManConfigPathCommand.cpp,153) -MAC OS:Library:Application Support:Adobe:Extension Manager2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store
    [DEBUG] Mon Apr  1 10:41:46 2013 [.847] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -6.0.5.9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.848] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -file:///Library/Application Support/Adobe/Extension Manager CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.848] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -file:///Library/Application Support/Adobe/Extension Manager CS5.5/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.848] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications
    [DEBUG] Mon Apr  1 10:41:46 2013 [.848] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 12.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : NoDefined
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : FLPR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.850] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 12.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : NoDefined
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.852] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : FWKS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.853] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter :
    [DEBUG] Mon Apr  1 10:41:46 2013 [.853] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.853] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Fireworks CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 6.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : PPRO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.854] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.855] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Premiere Pro CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 13.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.856] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : PHSP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.857] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Photoshop CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : 16.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/GetSupportedProductsCommand.cpp,54) -GetProductName Command, parameter : ILST
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.858] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -3
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -NoDefined
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -FLPR
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Flash CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -FWKS
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Fireworks CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -6.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.859] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -PPRO
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -2
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Premiere Pro CS6/Configuration
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -13.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -http://www.adobe.com/go/exchange
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -http://www.adobe.com/cfusion/exchange/upload/index.cfm
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -PHSP
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -16.0.0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/******** 1/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -ILST
    [DEBUG] Mon Apr  1 10:41:46 2013 [.860] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -7
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -preinstall
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalMigratePreferredExtension
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -4
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLExtensionMgrUI.cpp,244) -SetProgressCount:100
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -4
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -1
    [DEBUG] Mon Apr  1 10:41:46 2013 [.912] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.913] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.913] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.913] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -4
    [DEBUG] Mon Apr  1 10:41:46 2013 [.913] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.913] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is airNotifyOperationBeginOrEnd
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -8
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -preinstall
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.939] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalGetLastVersionPointProducts
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product flash-12.0 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product fireworks-12.0 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product premierepro-6.0 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product photoshop-60.032 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.947] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrProduct.cpp,182) -The product illustrator-16.064 is not supported by CS5.5
    [DEBUG] Mon Apr  1 10:41:46 2013 [.948] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.948] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.948] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.948] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.948] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,95) ------------------AIR request To C++ Start-----------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,98) -Receive the request from AIR, Request name is externalLoadExtension
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,118) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,142) -----------------AIR request To C++ End--------------------------------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1834) -Begin to load extensions...
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLExtensionMgrUI.cpp,244) -SetProgressCount:100
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:46 2013 [.957] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.958] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.958] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.958] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.959] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.959] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -10
    [DEBUG] Mon Apr  1 10:41:46 2013 [.959] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -15
    [DEBUG] Mon Apr  1 10:41:46 2013 [.962] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -20
    [DEBUG] Mon Apr  1 10:41:46 2013 [.963] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.966] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1819) -Load: P firstLaunch is t
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -30
    [DEBUG] Mon Apr  1 10:41:46 2013 [.967] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -31
    [DEBUG] Mon Apr  1 10:41:46 2013 [.968] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -32
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -33
    [DEBUG] Mon Apr  1 10:41:46 2013 [.969] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -34
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -35
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.970] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -36
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -37
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.971] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -38
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -39
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.972] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -40
    [DEBUG] Mon Apr  1 10:41:46 2013 [.974] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1819) -Load: F firstLaunch is t
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -50
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.979] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -60
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 18
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 19
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 20
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 21
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,3301) -UpdateExtensionSets: not dirty for porductId 22
    [DEBUG] Mon Apr  1 10:41:46 2013 [.980] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/DBWrapper.cpp,2609) -InitPredefinedExtensionSetTbl: clean up dirty table
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,404) --------------------Request (C++ side To AIR part ) Start--------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,407) -Method Name: airCallBack
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -12
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -9
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -70
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,450) --------------------Request (C++ side To AIR part ) End---------------------------
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../../Extensions/MacrExtensionManager.cpp,1937) -End to load extensions...
    [INFO] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/LoadExtensionCommand.cpp,46) -Load extension finished
    [DEBUG] Mon Apr  1 10:41:46 2013 [.981] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/OWLFrontController.cpp,424) -0
    [DEBUG] Mon Apr  1 10:41:49 2013 [.973] (/Develop/jenkins_slave/workspace/ExMan_6.0.5_Mac/Trelo/Source/Manage r/Mac/../Control/HeadLightsMgr.cpp,322) -ShutDown: +++
    Apr 1, 2013 7:44 AM   in reply to Matthew Ferrell
    Apologies ... there are two log files that were generated.  Here's the other.
    4/1/2013 10:41:46.490 [INFO] com.adobe.exman.controller.PassiveGatewayPrepCommand execute(), PassiveGatewayPrepCommand is executed.
    4/1/2013 10:41:46.494 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway registerAirInterfaces
    4/1/2013 10:41:46.495 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCallBackReady(), available==true
    4/1/2013 10:41:46.495 [INFO] com.adobe.exman.controller.ModelPrepCommand ModelPrepCommand command finished.
    4/1/2013 10:41:46.498 [INFO] com.adobe.exman.model.ExManConfigurationProxy ExManConfigurationProxy(), zstringPath is: /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS/ZStringResources
    4/1/2013 10:41:46.499 [INFO] com.adobe.exman.model.ExManConfigurationProxy initLocaleList(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_ NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
    4/1/2013 10:41:46.507 [INFO] com.adobe.exman.view.ExManApp ExManApp(), instance is constructed.
    4/1/2013 10:41:46.524 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan: ctor...
    4/1/2013 10:41:46.535 [DEBUG] com.adobe.exman.util.ExManVulcan ExManVulcan, vulcanSetup
    4/1/2013 10:41:46.562 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airGetLocaleList Message:-1,airGetLocaleList
    4/1/2013 10:41:46.562 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirGetLocaleList(), sessionId== -1
    4/1/2013 10:41:46.563 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), sessionId= -1
    4/1/2013 10:41:46.563 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_ NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
    4/1/2013 10:41:46.564 [INFO] com.adobe.exman.controller.passivecommand.RespondPassiveExternalGatew ayCommand execute(), parameter: sessionId to respond: -1parameters to respond: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_ NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
    4/1/2013 10:41:46.564 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-1,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU ,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_ CN,zh_TW
    4/1/2013 10:41:46.565 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-1,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU ,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR,ru_RU,sv_SE,tr_TR,uk_UA,zh_ CN,zh_TW
    4/1/2013 10:41:46.568 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airSetLocale Message:-2,airSetLocale,en_US
    4/1/2013 10:41:46.568 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirSetLocale(), sessionId=-2args=en_US
    4/1/2013 10:41:46.569 [INFO] com.adobe.exman.model.ExManConfigurationProxy defaultOSLocale(), set to: en_US
    4/1/2013 10:41:46.575 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: SET_LOCAL
    notification body: en_US
    4/1/2013 10:41:46.575 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.575 [DEBUG] com.adobe.exman.view.ExManApp SET_LOCAL
    4/1/2013 10:41:46.576 [INFO] com.adobe.exman.view.ExManApp handleNotification(), locale= en_US
    4/1/2013 10:41:46.578 [INFO] com.adobe.exman.controller.LoadUIPreferencesCommand execute(), LoadUIPreferencesCommand is executed.
    4/1/2013 10:41:46.579 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: LOAD_UI_PREFERENCES_DONE
    notification body: [object UIPreferences]
    4/1/2013 10:41:46.579 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.580 [DEBUG] com.adobe.exman.view.ExManApp LOAD_UI_PREFERENCES_DONE
    4/1/2013 10:41:46.580 [INFO] com.adobe.exman.controller.SetWindowPreferencesCommand execute(), SetWindowPreferencesCommand is executed.
    4/1/2013 10:41:46.581 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
    4/1/2013 10:41:46.582 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ExternalGateway()
    4/1/2013 10:41:46.582 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface()
    4/1/2013 10:41:46.583 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface(), airCallBack added.
    4/1/2013 10:41:46.583 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
    4/1/2013 10:41:46.583 [INFO] com.adobe.exman.controller.gateway.ExternalGateway setWindowPreferences(), sessionId= 0, windowPosition_x= 100, windowPosition_y= 100, windowWidth= 810, windowHeight= 600
    4/1/2013 10:41:46.654 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message0,0
    4/1/2013 10:41:46.654 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 0
    responseType= 0
    responseBody=
    4/1/2013 10:41:46.655 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::SetWindowPreferencesSessi on got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:46.655 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.655 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_SET_WINDOW_PREFERENCES_SUCCEED
    4/1/2013 10:41:46.656 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
    4/1/2013 10:41:46.665 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange()
    4/1/2013 10:41:46.666 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth()
    4/1/2013 10:41:46.667 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth(), width of column [OnOff] set to: 69
    4/1/2013 10:41:46.667 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange(), width of column [0] is changed to: 69
    4/1/2013 10:41:46.686 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-3,airParseXML,/Applications/Adobe Illustrator CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
    4/1/2013 10:41:46.687 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-3got xml String to parse: /Applications/Adobe Illustrator CS6/Configuration/XManConfig.xml
    4/1/2013 10:41:46.688 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
    4/1/2013 10:41:46.689 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Illustrator%20CS6/Configuration/XManConf ig.xml
    4/1/2013 10:41:46.689 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
    4/1/2013 10:41:46.689 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Illustrator%20CS6/Configuration/XManConf ig.xml
    4/1/2013 10:41:46.705 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-3,0,$illustrator,$InstallFolder,$plugin,$InstallFol der/Plug-ins.localized,$scripting,$InstallFolder/Scripting.localized,$ presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS6,ProductName,Illustrator,FamilyName,Illustrator,ProductVersion,16. 0,HostNameForCSXS,ILST,IconPath,Configuration/ai_app_24px.png,Supporte dInSuite,CS6,DefaultLocale,en_US
    4/1/2013 10:41:46.705 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-3,0,$illustrator,$InstallFolder,$plugin,$InstallFol der/Plug-ins.localized,$scripting,$InstallFolder/Scripting.localized,$ presets,$InstallFolder/Presets.localized,DisplayName,Illustrator CS6,ProductName,Illustrator,FamilyName,Illustrator,ProductVersion,16. 0,HostNameForCSXS,ILST,IconPath,Configuration/ai_app_24px.png,Supporte dInSuite,CS6,DefaultLocale,en_US
    4/1/2013 10:41:46.712 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-4,airParseXML,/Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
    4/1/2013 10:41:46.713 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-4got xml String to parse: /Applications/Adobe Photoshop CS6/Configuration/XManConfig.xml
    4/1/2013 10:41:46.713 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
    4/1/2013 10:41:46.713 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Photoshop%20CS6/Configuration/XManConfig .xml
    4/1/2013 10:41:46.714 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
    4/1/2013 10:41:46.714 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Photoshop%20CS6/Configuration/XManConfig .xml
    4/1/2013 10:41:46.728 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-4,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extensi on Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopa ppfolder/Plug-Ins,$presetsfolder,$photoshopappfolder/Presets,$platform ,Mac,$actions,$presetsfolder/Actions,$blackandwhite,$presetsfolder/Bla ck and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Ch annel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Cur ves,$customshapes,$presetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exp osure,$gradients,$presetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfol der/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolde r/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolde r/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/ Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textur es,$tools,$presetsfolder/Tools,$variations,$presetsfolder/Variations,$ webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder /Zoomify,$hueandsaturation,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Ma terials,$meshes,$presetsfolder/Meshes,$rendersettings,$presetsfolder/R ender Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widg ets,$localesfolder,$photoshopappfolder/Locales,$additionalplugins,$loc alesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digim arc,$pluginsfolder/Digimarc,$displacementmaps,$pluginsfolder/Displacem ent Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Exten sions,$fileformats,$pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/I mage Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$plug insfolder/Measurements,$panels,$pluginsfolder/Panels,$parser,$pluginsf older/Parser,$3dengines,$pluginsfolder/3D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photos hopappfolder,$photoshop,$UserDataFolder/Adobe/Adobe Photoshop CS6/Configuration,DisplayName,Photoshop CS6,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,13.0,Ic onPath,Configuration/PS_exman_24px.png,SupportedInSuite,CS6,HostNameFo rCSXS,PHSP
    4/1/2013 10:41:46.729 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-4,0,EmStorePath,$SharedRibsDataFolder/Adobe/Extensi on Manager,$photoshopappfolder,$installfolder,$pluginsfolder,$photoshopa ppfolder/Plug-Ins,$presetsfolder,$photoshopappfolder/Presets,$platform ,Mac,$actions,$presetsfolder/Actions,$blackandwhite,$presetsfolder/Bla ck and White,$brushes,$presetsfolder/Brushes,$channelmixer,$presetsfolder/Ch annel Mixer,$colorbooks,$presetsfolder/Color Books,$colorrange,$presetsfolder/Color Range,$colorswatches,$presetsfolder/Color Swatches,$contours,$presetsfolder/Contours,$curves,$presetsfolder/Cur ves,$customshapes,$presetsfolder/Custom Shapes,$duotones,$presetsfolder/Duotones,$exposure,$presetsfolder/Exp osure,$gradients,$presetsfolder/Gradients,$huesat,$presetsfolder/Hue Sat,$imagestatistics,$presetsfolder/Image Statistics,$keyboardshortcuts,$presetsfolder/Keyboard Shortcuts,$layouts,$presetsfolder/Layouts,$lenscorrection,$presetsfol der/Lens Correction,$levels,$presetsfolder/Levels,$liquifymeshes,$presetsfolde r/Liquify Meshes,$menucustomization,$presetsfolder/Menu Customization,$optimizedcolors,$presetsfolder/Optimized Colors,$optimizedoutputSettings,$presetsfolder/Optimized Output Settings,$optimizedsettings,$presetsfolder/Optimized Settings,$patterns,$presetsfolder/Patterns,$reducenoise,$presetsfolde r/Reduce Noise,$replacecolor,$presetsfolder/Replace Color,$scripts,$presetsfolder/Scripts,$selectivecolor,$presetsfolder/ Selective Color,$shadowhighlight,$presetsfolder/Shadow Highlight,$smartsharpen,$presetsfolder/Smart Sharpen,$styles,$presetsfolder/Styles,$textures,$presetsfolder/Textur es,$tools,$presetsfolder/Tools,$variations,$presetsfolder/Variations,$ webphotogallery,$presetsfolder/Web Photo Gallery,$workspaces,$presetsfolder/Workspaces,$zoomify,$presetsfolder /Zoomify,$hueandsaturation,$presetsfolder/Hue and Saturation,$lights,$presetsfolder/Lights,$materials,$presetsfolder/Ma terials,$meshes,$presetsfolder/Meshes,$rendersettings,$presetsfolder/R ender Settings,$volumes,$presetsfolder/Volumes,$widgets,$presetsfolder/Widg ets,$localesfolder,$photoshopappfolder/Locales,$additionalplugins,$loc alesfolder/$LOCALE/Additional Plug-ins,$additionalpresets,$localesfolder/$LOCALE/Additional Presets,$localeskeyboardshortcuts,$localesfolder/$LOCALE/Additional Presets/$platform/Keyboard Shortcuts,$localesmenucustomization,$localesfolder/$LOCALE/Additional Presets/$platform/Menu Customization,$localesworkspaces,$localesfolder/$LOCALE/Additional Presets/$platform/Workspaces,$automate,$pluginsfolder/Automate,$digim arc,$pluginsfolder/Digimarc,$displacementmaps,$pluginsfolder/Displacem ent Maps,$effects,$pluginsfolder/Effects,$extensions,$pluginsfolder/Exten sions,$fileformats,$pluginsfolder/File Formats,$filters,$pluginsfolder/Filters,$imagestacks,$pluginsfolder/I mage Stacks,$importexport,$pluginsfolder/Import-Export,$measurements,$plug insfolder/Measurements,$panels,$pluginsfolder/Panels,$parser,$pluginsf older/Parser,$3dengines,$pluginsfolder/3D Engines,$lightingstyles,$pluginsfolder/Filters/Lighting Styles,$matlab,$photoshopappfolder/MATLAB,UserExtensionFolder,$photos hopappfolder,$photoshop,$UserDataFolder/Adobe/Adobe Photoshop CS6/Configuration,DisplayName,Photoshop CS6,ProductName,Photoshop,FamilyName,Photoshop,ProductVersion,13.0,Ic onPath,Configuration/PS_exman_24px.png,SupportedInSuite,CS6,HostNameFo rCSXS,PHSP
    4/1/2013 10:41:46.746 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-5,airParseXML,/Applications/Adobe Premiere Pro CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
    4/1/2013 10:41:46.746 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-5got xml String to parse: /Applications/Adobe Premiere Pro CS6/Configuration/XManConfig.xml
    4/1/2013 10:41:46.746 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
    4/1/2013 10:41:46.747 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Premiere%20Pro%20CS6/Configuration/XManC onfig.xml
    4/1/2013 10:41:46.747 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
    4/1/2013 10:41:46.747 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Premiere%20Pro%20CS6/Configuration/XManC onfig.xml
    4/1/2013 10:41:46.751 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-5,0,ProductName,Premiere,DisplayName,Premiere Pro CS6.0,ProductVersion,6.0,HostNameForCSXS,PPRO,IconPath,Configuration/ pr_icon_24.png,SupportedInSuite,CS6,Bit,64
    4/1/2013 10:41:46.752 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-5,0,ProductName,Premiere,DisplayName,Premiere Pro CS6.0,ProductVersion,6.0,HostNameForCSXS,PPRO,IconPath,Configuration/ pr_icon_24.png,SupportedInSuite,CS6,Bit,64
    4/1/2013 10:41:46.780 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-6,airParseXML,/Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml,Configuration.VariableForExMan.Data
    4/1/2013 10:41:46.781 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-6got xml String to parse: /Applications/Adobe Fireworks CS6/Configuration/XManConfig.xml
    4/1/2013 10:41:46.781 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
    4/1/2013 10:41:46.781 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig .xml
    4/1/2013 10:41:46.782 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
    4/1/2013 10:41:46.782 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Fireworks%20CS6/Configuration/XManConfig .xml
    4/1/2013 10:41:46.791 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-6,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExt ensionFolder,$SharedCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafold er/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
    4/1/2013 10:41:46.791 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-6,0,HostNameForCSXS,FWKS,ProductVersion,12.0,PreExt ensionFolder,$SharedCommonDataFolder/Adobe/Fireworks CS6/PreInstall,$fireworks,$installfolder,$fireworksuser,$userdatafold er/adobe/Fireworks CS6,SupportedInSuite,CS6,Bit,32
    4/1/2013 10:41:46.816 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airParseXML Message:-7,airParseXML,/Applications/Adobe Flash CS6/XManConfig.xml,Configuration.VariableForExMan.Data
    4/1/2013 10:41:46.816 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-7got xml String to parse: /Applications/Adobe Flash CS6/XManConfig.xml
    4/1/2013 10:41:46.817 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
    4/1/2013 10:41:46.817 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: file:///Applications/Adobe%20Flash%20CS6/XManConfig.xml
    4/1/2013 10:41:46.817 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is XManConfig.xml file, just load it directly
    4/1/2013 10:41:46.818 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: file:///Applications/Adobe%20Flash%20CS6/XManConfig.xml
    4/1/2013 10:41:46.830 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, success, externalCallBack,-7,0,$UserExtensionFolder,$UserDataFolder/Adobe/Flas h CS6/$Locale/Configuration/Extensions,SupportedInSuite,CS6,HostNameFor CSXS,FLPR,Bit,32,$RootFolder,$InstallFolder,$RootFolderLocal,$InstallF older/$LOCALE,$flash,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
    4/1/2013 10:41:46.830 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalCallBack,-7,0,$UserExtensionFolder,$UserDataFolder/Adobe/Flas h CS6/$Locale/Configuration/Extensions,SupportedInSuite,CS6,HostNameFor CSXS,FLPR,Bit,32,$RootFolder,$InstallFolder,$RootFolderLocal,$InstallF older/$LOCALE,$flash,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration,$UserBinfolder,$userdatafolder/Adobe/Flash CS6/$LOCALE/Configuration
    4/1/2013 10:41:46.841 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airNotifyReady Message:-9,airNotifyReady
    4/1/2013 10:41:46.842 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirNotifyReady(), sessionId=-9
    4/1/2013 10:41:46.842 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----
    4/1/2013 10:41:46.843 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----
    4/1/2013 10:41:46.843 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----
    4/1/2013 10:41:46.844 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----2----3----
    4/1/2013 10:41:46.845 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getExManConfigPath(), the params to OWL: sessionid=2
    4/1/2013 10:41:46.845 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetExManConfigPath,2
    4/1/2013 10:41:46.845 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###getSupportedProducts(), the params to OWL: sessionid=3
    4/1/2013 10:41:46.846 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetSupportedProducts,3
    4/1/2013 10:41:46.848 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message2,0,/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.5.9,,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
    4/1/2013 10:41:46.848 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 2
    responseType= 0
    responseBody=/Library/Application Support/Adobe/Extension Manager CS6/EM Store,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store,6.0.5.9,,file:///Library/Application Support/Adobe/Extension Manager CS6/,file:///Library/Application Support/Adobe/Extension Manager CS5.5/,/Applications
    4/1/2013 10:41:46.848 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetExManConfigPathSession got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:46.849 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store
    4/1/2013 10:41:46.849 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store
    4/1/2013 10:41:46.849 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :6.0.5.9
    4/1/2013 10:41:46.849 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
    4/1/2013 10:41:46.850 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :file:///Library/Application Support/Adobe/Extension Manager CS6/
    4/1/2013 10:41:46.850 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :file:///Library/Application Support/Adobe/Extension Manager CS5.5/
    4/1/2013 10:41:46.850 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Applications
    4/1/2013 10:41:46.851 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy totalExtDir(), the _totalExtDir is set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/
    4/1/2013 10:41:46.851 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy myEMStorePath(), the _myEMStorePath is set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/
    4/1/2013 10:41:46.852 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager's version is set to: 6.0.5.9
    4/1/2013 10:41:46.852 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager last version extension path is set to:
    4/1/2013 10:41:46.852 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----
    4/1/2013 10:41:46.861 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message3,0,0,Flash CS6,Flash,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusio n/exchange/upload/index.cfm,Flash,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6          ,0,0,FLPR,,,1,/Applications/Adobe Flash CS6,0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusio n/exchange/upload/index.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,Premiere Pro CS6.0,Premiere,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/,http://www.adobe.com/go/exchange,/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Appli cation Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0          ,0,0,PPRO,,,2,/Applications/Adobe Premiere Pro CS6/Configuration,0,Photoshop CS6,Photoshop,13.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,Photoshop,/Libr ary/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6          ,0,0,PHSP,,,0,/Applications/Adobe Photoshop CS6/Configuration,0,Illustrator CS6,Illustrator,16.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,Illustrator,/Li brary/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6          ,0,0,ILST,,,0,/Applications/Adobe Illustrator CS6/Configuration
    4/1/2013 10:41:46.862 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 3
    responseType= 0
    responseBody=0,Flash CS6,Flash,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusio n/exchange/upload/index.cfm,Flash,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6          ,0,0,FLPR,,,1,/Applications/Adobe Flash CS6,0,Fireworks CS6,Fireworks,12.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/,http://www.adobe.com/go/exchange,NoDefined,http://www.adobe.com/cfusio n/exchange/upload/index.cfm,Fireworks,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6          ,0,0,FWKS,,,1,/Applications/Adobe Fireworks CS6/Configuration,0,Premiere Pro CS6.0,Premiere,6.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/,http://www.adobe.com/go/exchange,/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,,/Library/Appli cation Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0          ,0,0,PPRO,,,2,/Applications/Adobe Premiere Pro CS6/Configuration,0,Photoshop CS6,Photoshop,13.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,Photoshop,/Libr ary/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6          ,0,0,PHSP,,,0,/Applications/Adobe Photoshop CS6/Configuration,0,Illustrator CS6,Illustrator,16.0.0,/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/,http://www.adobe.com/go/exchange,/Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png,http://www.adobe.com/cfusion/exchange/upload/index.cfm,Illustrator,/Li brary/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6          ,0,0,ILST,,,0,/Applications/Adobe Illustrator CS6/Configuration
    4/1/2013 10:41:46.862 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetSupportedProductsSessi on got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:46.863 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0
    4/1/2013 10:41:46.863 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Flash CS6
    4/1/2013 10:41:46.863 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :Flash
    4/1/2013 10:41:46.863 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :12.0.0
    4/1/2013 10:41:46.864 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    4/1/2013 10:41:46.864 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6
    4/1/2013 10:41:46.864 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Flash CS6/
    4/1/2013 10:41:46.864 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 7 :http://www.adobe.com/go/exchange
    4/1/2013 10:41:46.865 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 8 :NoDefined
    4/1/2013 10:41:46.865 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 9 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
    4/1/2013 10:41:46.865 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 10 :Flash
    4/1/2013 10:41:46.865 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 11 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    4/1/2013 10:41:46.866 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 12 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    4/1/2013 10:41:46.866 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 13 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6
    4/1/2013 10:41:46.866 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 14
    4/1/2013 10:41:46.866 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 15
    4/1/2013 10:41:46.867 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 16 :FLPR
    4/1/2013 10:41:46.867 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 17 :
    4/1/2013 10:41:46.867 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 18 :
    4/1/2013 10:41:46.867 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 19 :1
    4/1/2013 10:41:46.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 20 :/Applications/Adobe Flash CS6
    4/1/2013 10:41:46.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 21
    4/1/2013 10:41:46.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 22 :Fireworks CS6
    4/1/2013 10:41:46.868 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 23 :Fireworks
    4/1/2013 10:41:46.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 24 :12.0.0
    4/1/2013 10:41:46.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 25 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    4/1/2013 10:41:46.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 26 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6
    4/1/2013 10:41:46.869 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 27 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Fireworks CS6/
    4/1/2013 10:41:46.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 28 :http://www.adobe.com/go/exchange
    4/1/2013 10:41:46.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 29 :NoDefined
    4/1/2013 10:41:46.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 30 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
    4/1/2013 10:41:46.870 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 31 :Fireworks
    4/1/2013 10:41:46.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 32 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    4/1/2013 10:41:46.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 33 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    4/1/2013 10:41:46.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 34 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6
    4/1/2013 10:41:46.871 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 35
    4/1/2013 10:41:46.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 36
    4/1/2013 10:41:46.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 37 :FWKS
    4/1/2013 10:41:46.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 38 :
    4/1/2013 10:41:46.872 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 39 :
    4/1/2013 10:41:46.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 40 :1
    4/1/2013 10:41:46.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 41 :/Applications/Adobe Fireworks CS6/Configuration
    4/1/2013 10:41:46.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 42
    4/1/2013 10:41:46.873 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 43 :Premiere Pro CS6.0
    4/1/2013 10:41:46.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 44 :Premiere
    4/1/2013 10:41:46.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 45 :6.0.0
    4/1/2013 10:41:46.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 46 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    4/1/2013 10:41:46.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 47 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0
    4/1/2013 10:41:46.874 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 48 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Premiere Pro CS6.0/
    4/1/2013 10:41:46.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 49 :http://www.adobe.com/go/exchange
    4/1/2013 10:41:46.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 50 :/Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
    4/1/2013 10:41:46.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 51 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
    4/1/2013 10:41:46.875 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 52 :
    4/1/2013 10:41:46.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 53 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    4/1/2013 10:41:46.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 54 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    4/1/2013 10:41:46.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 55 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0
    4/1/2013 10:41:46.876 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 56
    4/1/2013 10:41:46.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 57
    4/1/2013 10:41:46.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 58 :PPRO
    4/1/2013 10:41:46.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 59 :
    4/1/2013 10:41:46.877 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 60 :
    4/1/2013 10:41:46.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 61 :2
    4/1/2013 10:41:46.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 62 :/Applications/Adobe Premiere Pro CS6/Configuration
    4/1/2013 10:41:46.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 63
    4/1/2013 10:41:46.878 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 64 :Photoshop CS6
    4/1/2013 10:41:46.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 65 :Photoshop
    4/1/2013 10:41:46.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 66 :13.0.0
    4/1/2013 10:41:46.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 67 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    4/1/2013 10:41:46.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 68 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6
    4/1/2013 10:41:46.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 69 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Photoshop CS6/
    4/1/2013 10:41:46.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 70 :http://www.adobe.com/go/exchange
    4/1/2013 10:41:46.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 71 :/Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png
    4/1/2013 10:41:46.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 72 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
    4/1/2013 10:41:46.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 73 :Photoshop
    4/1/2013 10:41:46.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 74 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    4/1/2013 10:41:46.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 75 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    4/1/2013 10:41:46.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 76 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6
    4/1/2013 10:41:46.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 77
    4/1/2013 10:41:46.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 78
    4/1/2013 10:41:46.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 79 :PHSP
    4/1/2013 10:41:46.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 80 :
    4/1/2013 10:41:46.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 81 :
    4/1/2013 10:41:46.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 82
    4/1/2013 10:41:46.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 83 :/Applications/Adobe Photoshop CS6/Configuration
    4/1/2013 10:41:46.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 84
    4/1/2013 10:41:46.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 85 :Illustrator CS6
    4/1/2013 10:41:46.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 86 :Illustrator
    4/1/2013 10:41:46.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 87 :16.0.0
    4/1/2013 10:41:46.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 88 :/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    4/1/2013 10:41:46.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 89 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6
    4/1/2013 10:41:46.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 90 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/Mxi Flag/Illustrator CS6/
    4/1/2013 10:41:46.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 91 :http://www.adobe.com/go/exchange
    4/1/2013 10:41:46.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 92 :/Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png
    4/1/2013 10:41:46.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 93 :http://www.adobe.com/cfusion/exchange/upload/index.cfm
    4/1/2013 10:41:46.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 94 :Illustrator
    4/1/2013 10:41:46.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 95 :/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    4/1/2013 10:41:46.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 96 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    4/1/2013 10:41:46.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 97 :/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/**********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/          /Users/****/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6
    4/1/2013 10:41:46.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 98
    4/1/2013 10:41:46.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 99
    4/1/2013 10:41:46.887 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 100 :ILST
    4/1/2013 10:41:46.888 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 101 :
    4/1/2013 10:41:46.888 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 102 :
    4/1/2013 10:41:46.888 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 103
    4/1/2013 10:41:46.888 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 104 :/Applications/Adobe Illustrator CS6/Configuration
    4/1/2013 10:41:46.890 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Flash CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
    4/1/2013 10:41:46.891 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Flash CS6, EM store path set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
    4/1/2013 10:41:46.891 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Fireworks CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
    4/1/2013 10:41:46.892 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Fireworks CS6, EM store path set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/
    4/1/2013 10:41:46.892 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe Premiere Pro CS6/Configuration/pr_icon_24.png
    4/1/2013 10:41:46.892 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Premiere Pro CS6.0, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/
    4/1/2013 10:41:46.893 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Premiere Pro CS6.0, EM store path set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/
    4/1/2013 10:41:46.893 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe Photoshop CS6/Configuration/PS_exman_24px.png
    4/1/2013 10:41:46.893 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Photoshop CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/
    4/1/2013 10:41:46.894 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Photoshop CS6, EM store path set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/
    4/1/2013 10:41:46.894 [INFO] com.adobe.exman.vo.ProductInfo ProductInfo(), icon path /Applications/Adobe Illustrator CS6/Configuration/ai_app_24px.png
    4/1/2013 10:41:46.894 [INFO] com.adobe.exman.vo.ProductInfo productMachineEMStorePath(), product name: Illustrator CS6, EM store path set to: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/
    4/1/2013 10:41:46.894 [INFO] com.adobe.exman.vo.ProductInfo productMyEMStorePath(), product name: Illustrator CS6, EM store path set to: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/
    4/1/2013 10:41:46.896 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: ctor...
    4/1/2013 10:41:46.897 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: open public db conn...
    4/1/2013 10:41:46.899 [DEBUG] com.adobe.exman.util.DBWrapper DBWrapper: attach user db conn...
    4/1/2013 10:41:46.902 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.902 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_APPLICATION_STARTUP_SUCCEED
    4/1/2013 10:41:46.903 [INFO] com.adobe.exman.controller.MigratePreferredExtensionCommand execute(), MigratePreferredExtensionCommand
    4/1/2013 10:41:46.904 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----
    4/1/2013 10:41:46.905 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 1----3----4----5----
    4/1/2013 10:41:46.905 [INFO] com.adobe.exman.controller.session.frontend.FrontendMigratePreferredE xtensionSession initiate()
    4/1/2013 10:41:46.906 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
    notification body: [object ActionBeginParameter]
    4/1/2013 10:41:46.906 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.906 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
    4/1/2013 10:41:46.907 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
    4/1/2013 10:41:46.908 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
    4/1/2013 10:41:46.909 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
    4/1/2013 10:41:46.910 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
    4/1/2013 10:41:46.910 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 6, opCode=10, mouseX=0, mouseY=0
    4/1/2013 10:41:46.910 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. initiate ()
    4/1/2013 10:41:46.911 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
    4/1/2013 10:41:46.911 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,7,preinstall,1,0
    4/1/2013 10:41:46.912 [INFO] com.adobe.exman.controller.gateway.ExternalGateway migratePreferredExtension(), the params to external install: sessionid=4
    4/1/2013 10:41:46.912 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalMigratePreferredExtension,4
    4/1/2013 10:41:46.912 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
    4/1/2013 10:41:46.913 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----
    4/1/2013 10:41:46.924 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message4,9,1
    4/1/2013 10:41:46.924 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 4
    responseType= 9
    responseBody=1
    4/1/2013 10:41:46.924 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::MigratePreferredExtension Session got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.925 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :1
    4/1/2013 10:41:46.925 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 1
    4/1/2013 10:41:46.925 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.925 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.926 [INFO] com.adobe.exman.view.ExManApp app got progress: 1
    4/1/2013 10:41:46.937 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message4,0
    4/1/2013 10:41:46.938 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 4
    responseType= 0
    responseBody=
    4/1/2013 10:41:46.938 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::MigratePreferredExtension Session got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:46.938 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
    4/1/2013 10:41:46.939 [INFO] com.adobe.exman.controller.NotifyOperationBeginEndCommand execute(), NotifyOperationBeginEndCommand is executed.
    4/1/2013 10:41:46.939 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr airNotifyOperationBeginOrEnd,8,preinstall,0,0
    4/1/2013 10:41:46.939 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.940 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_MIGRATE_PREFERRED_EXTENSION_COMPLETE
    4/1/2013 10:41:46.941 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsCommand execute(), GetLastVersionPointProductsCommand
    4/1/2013 10:41:46.942 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----
    4/1/2013 10:41:46.942 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----10----
    4/1/2013 10:41:46.943 [INFO] com.adobe.exman.controller.session.frontend.FrontendGetLastVersionPoi ntProductsSession initiate()
    4/1/2013 10:41:46.943 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----9----
    4/1/2013 10:41:46.943 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
    4/1/2013 10:41:46.944 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.944 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
    4/1/2013 10:41:46.944 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
    4/1/2013 10:41:46.945 [DEBUG] com.adobe.exman.ExManGUI onActionBegin(), unknown action name: GET_LAST_VERSION_PRODUCTS
    4/1/2013 10:41:46.945 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
    4/1/2013 10:41:46.945 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
    4/1/2013 10:41:46.946 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
    4/1/2013 10:41:46.946 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 11, opCode=10, mouseX=0, mouseY=0
    4/1/2013 10:41:46.946 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProduct sSession. GetLastVersionPointProductsSession. initiate ()
    4/1/2013 10:41:46.947 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getLastVersionPointProducts(), the params to external install: sessionid=9
    4/1/2013 10:41:46.947 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalGetLastVersionPointProducts,9
    4/1/2013 10:41:46.947 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----
    4/1/2013 10:41:46.948 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message9,0
    4/1/2013 10:41:46.948 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 9
    responseType= 0
    responseBody=
    4/1/2013 10:41:46.948 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetLastVersionPointProduc tsSession got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:46.949 [INFO] com.adobe.exman.controller.session.backend.GetLastVersionPointProduct sSession. GetLastVersionPointProductsSession. specificHandleSuccess ()
    4/1/2013 10:41:46.949 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.950 [DEBUG] com.adobe.exman.view.ExManApp END_GET_LAST_VERSION_POINT_PRODUCTS
    4/1/2013 10:41:46.951 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _already_Migrated_Flag_File: /Users/********/Library/Preferences/Adobe/Extension Manager CS6/Migrated.YES
    4/1/2013 10:41:46.951 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _never_Migrated_Flag_File: /Users/********/Library/Preferences/Adobe/Extension Manager CS6/Migrated.NEVER
    4/1/2013 10:41:46.951 [INFO] com.adobe.exman.model.MigrationExtensionsProxy needToMigrateExtensions(), don't need to immigrate extensions.
    4/1/2013 10:41:46.952 [INFO] com.adobe.exman.controller.RequestLoadExtensionCommand execute(), RequestLoadExtensionCommand
    4/1/2013 10:41:46.952 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
    4/1/2013 10:41:46.953 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
    4/1/2013 10:41:46.953 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----13----
    4/1/2013 10:41:46.953 [INFO] com.adobe.exman.controller.session.frontend.FrontendRequestLoadExtens ionSession initiate()
    4/1/2013 10:41:46.954 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 9----12----
    4/1/2013 10:41:46.954 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
    4/1/2013 10:41:46.954 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.954 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_ACTION_BEGIN
    4/1/2013 10:41:46.955 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
    4/1/2013 10:41:46.955 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
    4/1/2013 10:41:46.955 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
    4/1/2013 10:41:46.956 [INFO] com.adobe.exman.controller.AppWinOperationCommand execute(), AppWinOperationCommand is executed. notification=APPWIN_MODALDIALOG_POPUP
    4/1/2013 10:41:46.956 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ###appWinOperate(), sessionId: 14, opCode=10, mouseX=0, mouseY=0
    4/1/2013 10:41:46.956 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. initiate ()
    4/1/2013 10:41:46.957 [INFO] com.adobe.exman.controller.gateway.ExternalGateway requestToLoadExtension(), the params to external install: sessionid=12
    4/1/2013 10:41:46.957 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway ###call2extensionMgr externalLoadExtension,12
    4/1/2013 10:41:46.957 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 12----
    4/1/2013 10:41:46.958 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,0
    4/1/2013 10:41:46.958 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=0
    4/1/2013 10:41:46.958 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.959 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0
    4/1/2013 10:41:46.959 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 0
    4/1/2013 10:41:46.959 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.960 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.960 [INFO] com.adobe.exman.view.ExManApp app got progress: 0
    4/1/2013 10:41:46.964 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,10
    4/1/2013 10:41:46.964 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=10
    4/1/2013 10:41:46.965 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.965 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :10
    4/1/2013 10:41:46.965 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 10
    4/1/2013 10:41:46.965 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.966 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.966 [INFO] com.adobe.exman.view.ExManApp app got progress: 10
    4/1/2013 10:41:46.966 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,15
    4/1/2013 10:41:46.967 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=15
    4/1/2013 10:41:46.967 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.967 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :15
    4/1/2013 10:41:46.968 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 15
    4/1/2013 10:41:46.968 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.968 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.968 [INFO] com.adobe.exman.view.ExManApp app got progress: 15
    4/1/2013 10:41:46.976 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,20
    4/1/2013 10:41:46.977 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=20
    4/1/2013 10:41:46.977 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.977 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :20
    4/1/2013 10:41:46.977 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 20
    4/1/2013 10:41:46.978 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.978 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.978 [INFO] com.adobe.exman.view.ExManApp app got progress: 20
    4/1/2013 10:41:46.979 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,30
    4/1/2013 10:41:46.979 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=30
    4/1/2013 10:41:46.979 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.979 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :30
    4/1/2013 10:41:46.980 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 30
    4/1/2013 10:41:46.980 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.980 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.980 [INFO] com.adobe.exman.view.ExManApp app got progress: 30
    4/1/2013 10:41:46.981 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,31
    4/1/2013 10:41:46.981 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=31
    4/1/2013 10:41:46.981 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.982 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :31
    4/1/2013 10:41:46.982 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 31
    4/1/2013 10:41:46.982 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.982 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.982 [INFO] com.adobe.exman.view.ExManApp app got progress: 31
    4/1/2013 10:41:46.983 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,32
    4/1/2013 10:41:46.983 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=32
    4/1/2013 10:41:46.983 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.984 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :32
    4/1/2013 10:41:46.984 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 32
    4/1/2013 10:41:46.984 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.984 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.985 [INFO] com.adobe.exman.view.ExManApp app got progress: 32
    4/1/2013 10:41:46.985 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,33
    4/1/2013 10:41:46.985 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=33
    4/1/2013 10:41:46.985 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.986 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :33
    4/1/2013 10:41:46.986 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 33
    4/1/2013 10:41:46.986 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.986 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.987 [INFO] com.adobe.exman.view.ExManApp app got progress: 33
    4/1/2013 10:41:46.987 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,34
    4/1/2013 10:41:46.987 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=34
    4/1/2013 10:41:46.987 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.988 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :34
    4/1/2013 10:41:46.988 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 34
    4/1/2013 10:41:46.988 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.988 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.989 [INFO] com.adobe.exman.view.ExManApp app got progress: 34
    4/1/2013 10:41:46.989 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,35
    4/1/2013 10:41:46.989 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=35
    4/1/2013 10:41:46.990 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.990 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :35
    4/1/2013 10:41:46.990 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 35
    4/1/2013 10:41:46.990 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.991 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.991 [INFO] com.adobe.exman.view.ExManApp app got progress: 35
    4/1/2013 10:41:46.991 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,36
    4/1/2013 10:41:46.992 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=36
    4/1/2013 10:41:46.992 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.992 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :36
    4/1/2013 10:41:46.992 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 36
    4/1/2013 10:41:46.993 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.993 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.993 [INFO] com.adobe.exman.view.ExManApp app got progress: 36
    4/1/2013 10:41:46.994 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,37
    4/1/2013 10:41:46.994 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=37
    4/1/2013 10:41:46.994 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.994 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :37
    4/1/2013 10:41:46.995 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 37
    4/1/2013 10:41:46.995 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:46.995 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:46.995 [INFO] com.adobe.exman.view.ExManApp app got progress: 37
    4/1/2013 10:41:46.998 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,38
    4/1/2013 10:41:46.998 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=38
    4/1/2013 10:41:46.999 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:46.999 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :38
    4/1/2013 10:41:46.999 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 38
    4/1/2013 10:41:46.999 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.000 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.000 [INFO] com.adobe.exman.view.ExManApp app got progress: 38
    4/1/2013 10:41:47.000 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,39
    4/1/2013 10:41:47.001 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=39
    4/1/2013 10:41:47.001 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:47.001 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :39
    4/1/2013 10:41:47.001 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 39
    4/1/2013 10:41:47.002 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.002 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.002 [INFO] com.adobe.exman.view.ExManApp app got progress: 39
    4/1/2013 10:41:47.002 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,40
    4/1/2013 10:41:47.003 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=40
    4/1/2013 10:41:47.003 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:47.003 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :40
    4/1/2013 10:41:47.003 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 40
    4/1/2013 10:41:47.004 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.004 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.004 [INFO] com.adobe.exman.view.ExManApp app got progress: 40
    4/1/2013 10:41:47.005 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,50
    4/1/2013 10:41:47.005 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=50
    4/1/2013 10:41:47.005 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:47.005 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :50
    4/1/2013 10:41:47.006 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 50
    4/1/2013 10:41:47.006 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.006 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.006 [INFO] com.adobe.exman.view.ExManApp app got progress: 50
    4/1/2013 10:41:47.007 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,60
    4/1/2013 10:41:47.007 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=60
    4/1/2013 10:41:47.007 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:47.007 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :60
    4/1/2013 10:41:47.008 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 60
    4/1/2013 10:41:47.008 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.008 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.008 [INFO] com.adobe.exman.view.ExManApp app got progress: 60
    4/1/2013 10:41:47.009 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,9,70
    4/1/2013 10:41:47.009 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 9
    responseBody=70
    4/1/2013 10:41:47.009 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 9
    4/1/2013 10:41:47.010 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :70
    4/1/2013 10:41:47.010 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    notification body: 70
    4/1/2013 10:41:47.010 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.010 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.010 [INFO] com.adobe.exman.view.ExManApp app got progress: 70
    4/1/2013 10:41:47.011 [INFO] com.adobe.exman.controller.gateway.Application ###Receive airCallBack Message12,0
    4/1/2013 10:41:47.011 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
    sessionId= 12
    responseType= 0
    responseBody=
    4/1/2013 10:41:47.011 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSessi on got parameters in handleResponse:
    responseType= 0
    4/1/2013 10:41:47.012 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
    4/1/2013 10:41:47.012 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.012 [DEBUG] com.adobe.exman.view.ExManApp LOAD_EXTENSIONS_COMPLETE
    4/1/2013 10:41:47.013 [INFO] com.adobe.exman.ExManGUI chenxiaoyan: п
    4/1/2013 10:41:47.018 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 22
    4/1/2013 10:41:47.019 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, add set All Extensions...
    4/1/2013 10:41:47.020 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, init set All Extensions...
    4/1/2013 10:41:47.021 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 22
    4/1/2013 10:41:47.021 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 22!
    4/1/2013 10:41:47.022 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, add set Adobe Extensions...
    4/1/2013 10:41:47.022 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, init set Adobe Extensions...
    4/1/2013 10:41:47.023 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 22
    4/1/2013 10:41:47.023 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 22!
    4/1/2013 10:41:47.023 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, add set Customized Set...
    4/1/2013 10:41:47.023 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Flash CS6, init set Customized Set...
    4/1/2013 10:41:47.024 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 22
    4/1/2013 10:41:47.024 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 22!
    4/1/2013 10:41:47.027 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 21
    4/1/2013 10:41:47.027 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set All Extensions...
    4/1/2013 10:41:47.028 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set All Extensions...
    4/1/2013 10:41:47.031 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 12 for product 21
    4/1/2013 10:41:47.033 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set Adobe Extensions...
    4/1/2013 10:41:47.033 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set Adobe Extensions...
    4/1/2013 10:41:47.034 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 12 for product 21
    4/1/2013 10:41:47.035 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, add set Customized Set...
    4/1/2013 10:41:47.036 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Fireworks CS6, init set Customized Set...
    4/1/2013 10:41:47.037 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 12 for product 21
    4/1/2013 10:41:47.039 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 20
    4/1/2013 10:41:47.040 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, add set All Extensions...
    4/1/2013 10:41:47.040 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, init set All Extensions...
    4/1/2013 10:41:47.040 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 20
    4/1/2013 10:41:47.041 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 20!
    4/1/2013 10:41:47.041 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, add set Adobe Extensions...
    4/1/2013 10:41:47.041 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, init set Adobe Extensions...
    4/1/2013 10:41:47.042 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 20
    4/1/2013 10:41:47.042 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 20!
    4/1/2013 10:41:47.042 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, add set Customized Set...
    4/1/2013 10:41:47.043 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Premiere Pro CS6.0, init set Customized Set...
    4/1/2013 10:41:47.043 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 20
    4/1/2013 10:41:47.044 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 20!
    4/1/2013 10:41:47.044 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 19
    4/1/2013 10:41:47.045 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, add set All Extensions...
    4/1/2013 10:41:47.045 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, init set All Extensions...
    4/1/2013 10:41:47.046 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 2 for product 19
    4/1/2013 10:41:47.046 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, add set Adobe Extensions...
    4/1/2013 10:41:47.047 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, init set Adobe Extensions...
    4/1/2013 10:41:47.047 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 2 for product 19
    4/1/2013 10:41:47.048 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, add set Customized Set...
    4/1/2013 10:41:47.048 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Photoshop CS6, init set Customized Set...
    4/1/2013 10:41:47.049 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension number is 2 for product 19
    4/1/2013 10:41:47.050 [DEBUG] com.adobe.exman.util.DBWrapper ExtensionSetUI::getExtensionSets(): set number is 3 for product 18
    4/1/2013 10:41:47.051 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, add set All Extensions...
    4/1/2013 10:41:47.051 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, init set All Extensions...
    4/1/2013 10:41:47.051 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 18
    4/1/2013 10:41:47.052 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 18!
    4/1/2013 10:41:47.052 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, add set Adobe Extensions...
    4/1/2013 10:41:47.052 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, init set Adobe Extensions...
    4/1/2013 10:41:47.053 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 18
    4/1/2013 10:41:47.053 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 18!
    4/1/2013 10:41:47.053 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, add set Customized Set...
    4/1/2013 10:41:47.054 [DEBUG] com.adobe.exman.view.ProductDataItem initSetCollection(): for product Illustrator CS6, init set Customized Set...
    4/1/2013 10:41:47.054 [WARN] com.adobe.exman.util.DBWrapper ExtensionSetUI::getAllExtensions(): extension not found for product 18
    4/1/2013 10:41:47.054 [WARN] com.adobe.exman.view.ProductDataItem initExtensionCollection: extension not found for product 18!
    4/1/2013 10:41:47.060 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy initialize(), _productEMStores: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Fireworks CS6/,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Premiere Pro CS6.0/,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Photoshop CS6/,/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/,/Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Illustrator CS6/
    4/1/2013 10:41:47.060 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
    4/1/2013 10:41:47.061 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
    4/1/2013 10:41:47.062 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 0
    4/1/2013 10:41:47.062 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), no MXI file to load.
    4/1/2013 10:41:47.062 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
    4/1/2013 10:41:47.063 [DEBUG] com.adobe.exman.view.ExManApp @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    4/1/2013 10:41:47.063 [DEBUG] com.adobe.exman.view.ExManApp NOTIF_PROGRESS
    4/1/2013 10:41:47.063 [INFO] com.adobe.exman.view.ExManApp app got progress: 70
    4/1/2013 10:41:47.063 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand execute(), LoadInstalledExtensionsCommand is executed.
    4/1/2013 10:41:47.064 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand loadInstalledMXIFileInfo(), loadInstalledMXIFileInfo from: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/
    4/1/2013 10:41:47.064 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand getMXIFileCount(), file count: 1
    4/1/2013 10:41:47.065 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air
    4/1/2013 10:41:47.065 [INFO] com.adobe.exman.controller.LoadInstalledExtensionsCommand.LoadMXIFile CompleteCallBack onComplete(), xmlFilename: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air
    4/1/2013 10:41:47.066 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy loadMXIDataIntoGridData(): xmlFilename: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air
    4/1/2013 10:41:47.067 [INFO] com.adobe.exman.vo.ExtensionStaticData ExtensionStaticData, going XMLLoader
    4/1/2013 10:41:47.067 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load XML File: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air
    4/1/2013 10:41:47.067 [DEBUG] com.adobe.exman.business.XMLLoader XMLLoader(), XML file is NOT XManConfig.xml file, copy it to a temp file to load
    4/1/2013 10:41:47.068 [DEBUG] com.adobe.exman.business.XMLLoader Temp file created: /private/var/folders/_v/mdm8v7z902n0mflgvwpdt7thlr038v/T/TemporaryIte ms/FlashTmp0
    4/1/2013 10:41:47.069 [DEBUG] com.adobe.exman.business.XMLLoader Config file copied to temp file
    4/1/2013 10:41:47.070 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), try to load: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air
    4/1/2013 10:41:47.070 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now:
    4/1/2013 10:41:47.084 [FATAL] com.adobe.exman.business.XMLLoader Unable to load the XML file: /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air, errorID = 1090, message is: Error #1090
    4/1/2013 10:41:47.084 [ERROR] com.adobe.exman.vo.ExtensionStaticData Load /Users/********/Library/Application Support/Adobe/Extension Manager CS6/EM Store/Flash CS6/gSearch.mxi_air unsuccessful, externalXML is null.
    Apr 1, 2013 7:57 AM   in reply to Matthew Ferrell
    And like that, it's fixed.  I deleted the gsearch.mxi_air files from the folder mentioned in the fatal error lines at the end.  Now extension manager loads just fine.
    Apr 3, 2013 1:40 AM   in reply to boydbartley
    I had a similar problem in Windows Vista Business 64bits, in the log file I got many sqlite access problems and the only solution I found was deleting the file:
    C:/Users/All users/Adobe/Extension Manager CS6/Configuration/DB/ExMan.db
    Then I started Adobe Extension Manager CS6 and it rebuilded the file; most probably it was an access rights issue. Before I tried to uncheck read-only rights, reinstalled, etc but only after deleting the file it worked.
