AI document is opening with a blank window??
Jun 14, 2012 1:57 PM
Tags: #cs4 #illustrator #cs6 #blank
I have a customer that sent me some Illustrator files (.ai) that, when I open them, they open with just a blank window and a box with no fill or stroke around the outside of the document. I am using Illustrator CS4 and I suspect this may be an Illustrator CS6 document but I didn't get any warnings when I opened it so I'm not sure. (I also don't know what version of Illustrator the original creator is using). The document sizes are large (35MB +) so there should be SOME content in them. I've tried making sure nothing is hidden and there are no layers that are turned off. I've also tried opening the files in Acrobat CS4 with no luck.
Does anyone have an idea of what might be going on?
    Jun 14, 2012 2:39 PM   in reply to MKMGraphics
    One quick means of checking is to open the AI file in a text editor. You will see a line down just a little way such as:
    <xmp:CreatorTool>Adobe Illustrator CS5.1</xmp:CreatorTool>
    If they are CS6, consider the upgrade or at least download the trial to work with them. Might get you through the job.
    Take care, Mike
    Jun 14, 2012 3:31 PM   in reply to MKMGraphics
    Any way to put one on a file sharing site for us to look at?
    Jun 14, 2012 6:57 PM   in reply to MKMGraphics
    If they saved the AICS5 file with pdf compatibility, then you should be able to place it AICS4.
    Or you could download the CS5 or CS6 trial, open the file and save down.
    Jun 14, 2012 10:27 PM   in reply to MKMGraphics
    Hi Kris--sorry for the delay in getting back to this thread.
    As Larry mentioned, a look at the file would be incredibily helpful. If it is sensitive, consider still uploading it to dropbox.com or another file sharing site that can handle large documents and contact one of us via a private message (click on one of our names and in the right-hand panel there is a link for sending a PM).
    It sounds like there are either elements that CS4 and Acrobat cannot cope with in the file (seems a tad unlikely that one of them cannot at least open the PDF data if it was thus saved that way) or there is something corrupt in the file. Trying to open it in CS6 (would require you to download and install it) would be the quickest means of finding out. Else one of us opening it in CS5.1 or CS6 would probably be needed.
    Take care, Mike
    Jun 28, 2012 3:46 PM   in reply to MW Design
    I have the same issue but with CS6 - when opening some older files from CS4/CS5 I'm getting this dialog box, and after that just a blank artboard is opened.
    This happens with certain files, not all of them.
    Here is one of the files in question: https://dl.dropbox.com/u/1342341/mesf-logo.ai
    Thanks in advance for your help
    Jun 29, 2012 5:19 AM   in reply to MKMGraphics
    Could there be a white box on top of everything? (view> overprint preview, or select and delete it)
    It sounds like there were several artboards created in CS5 and CS4 is only showing you the first (blank) one, although CS4 should warn you and let you pick which artboard to keep when opening for the first time.
    Is CS4 updated to the latest patch?
    Your file might be corrupt, can you retrieve the file again and start with a fresh file?
    When you open the original file in Acrobat, are you sure there is not more than one page, with the first page being blank?
    A trial download of CS6 is a good idea, if your OS can handle it.
    Have you tried placing it into InDesign?
