Grafik51429
Photoshop CS6 file extension problem
Jun 14, 2012 3:37 AM
Tags: #photoshop #cs6 #file_extensions
I want to choose an file extension in the "Save as" Dialog. If i choose Jpeg, Photoshop takes EPS and so on. Systemupdate and reinstall PS does not help.
My System: Mac OS X 10.6.8
    Jun 14, 2012 4:12 AM   in reply to Grafik51429
    Boilerplate-text:
    Are Photoshop and OS fully updated?
    As with all unexplainable Photoshop-problems you might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed) by keeping command-alt-shift pressed on starting the program or starting from a new user-account.
    System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
    http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
    Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
    If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
    Jun 14, 2012 6:13 AM   in reply to Grafik51429
    You’re welcome.
    Jun 14, 2012 10:40 AM   in reply to Grafik51429
    You probably set the Additional Plugins Folder preference and pointed it to an older version of Photoshop by mistake -- loading duplicated plugins, which cause this problem on MacOS.
    Copying plugins from an older version: BAD idea.
    Jun 14, 2012 11:53 AM   in reply to Grafik51429
    I am having the same problem. Glad you have found a cure. Tried the shift-opt-command at startup but no apparent results. Did you re-install from the cloud?
    Thanks for the information.
  • Noel Carboni
    Dec 23, 2006
    Jun 14, 2012 12:39 PM   in reply to haber456789
    Read what Chris Cox wrote carefully.
    You have copied plug-ins provided by Adobe with a previous version of Photoshop into the plug-ins folder for the new version.
    Undo that.
    Reinstallation does NOT wipe out copied plug-ins, so it will not help.
    -Noel
    Jun 15, 2012 12:38 AM   in reply to Grafik51429
    Only step 4 was necessary -- because it reset the "additional plugins folder" preference that you mistakenly pointed to an older version of Photoshop.
    Jun 15, 2012 1:09 AM   in reply to Grafik51429
    You had duplicated the plugins from a previous version somewhere, because the duplicated file format plugins are what causes the save dialog menu to get out of sync.
Bookmarked By (1)
