I am building a rather text heavy site. When viewed live or in the four most popular browsers the text appears far shorter in height than in design view (I'm the Arial family in CS6. I can enter a full page of text (900px) but when seen in a browser it appears to be only 75% of the page depth. How can I get the text to appear exactly the same as I have inputted into Dreamweaver?
All the text is showing but finishes short of the end of the page, so there's gap between the last line and the bottom of the page. By experimenting I've found that when typing in the text if I don't press return to insert paragraphs, i.e. just have a solid block of text, everything is ok live and the text fills the page. Once I insert paragraphs the problem returns and the page of text appears to shrink in depth.
wittonend wrote:
Thanks for the reply, I've solved the problem by inserting line breaks rather than paragraphs. My inexperience showing through but if you know why inserting paragraphs had this effect it might be useful to share.
Something is wrong with your code as <p></p> paragraph tags would not cause the problem you are describing. Without seeing the page and the code its difficult to give you a definitive answer.
bottom of the page.
Hit Ctrl+++ in browsers to increase text size.
Line breaks are not a good choice and should never be used in place of <h1, h2, h3> and <p> tags.
Use CSS to style your paragraphs.
p {
font-size: 18px; /**adjust font-size as required**/
line-height: 1.5;
Nancy O.
Hi Nancy / Osgood
Thanks for your interest in this problem that I have. I can't attach the Word docs or pdfs to the forum so I hope you don't mind me replying directly.
The attached images might illustrate the situation more clearly. I have set up two test HTML pages, one using paragraph spacing and the other using line breaks.
You will see that the text in the one using paragraphs shrinks in length when viewed Live. The other one using line breaks renders perfectly.
The code I used for the paragraphed version is below:
The quick brown fox jumps over those lazy dogs
The only difference is that I used line breaks in the other version.
ThanksWittonend
Are you just copying from Word and pasting into Dreamweaver because that could be the issue. Word never really transfers correctly over to Dreamweaver if you do that. Even if the code looks ok I have experienced strange things happening.
I usually dump the text in simple-text(Mac) or notepad (PC) to get rid of the formating and then start from that point.
This is the code for the paragraphed version that shrinks:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>Paragraphs</title>
<style type="text/css">
body,td,th {
font-family: Arial, Helvetica, sans-serif;
color: #000;
body {
background-color: #FFF;
text-align: center;
font-size: 12px;
h1 {
font-size: 36px;
color: #390;
h2 {
font-size: 24px;
color: #390;
h3 {
font-size: 18px;
color: #390;
p {
font-size: 12px;
line-height: 1;
#container {
#container {
background-color: #FF6;
height: 800px;
width: 800px;
margin-right: auto;
margin-left: auto;
position: relative;
text-align: left;
</style>
</head>
<body>
<div id="container">
The quick brown fox jumps over those lazy dogs</p>
<p>The quick brown fox jumps over those lazy dogs</p>
</div>
</body>
</html>
and this is for the line break version that doesn't:
<head>
body,td,th {
color: #000;
body {
text-align: center;
font-size: 12px;
h1 {
font-size: 36px;
color: #390;
h2 {
font-size: 24px;
color: #390;
h3 {
font-size: 18px;
color: #390;
p {
font-size: 12px;
line-height: 1;
#container {
#container {
height: 800px;
width: 800px;
margin-right: auto;
margin-left: auto;
position: relative;
text-align: left;
</style>
</head>
<body>
<div id="container">The quick brown fox jumps over those lazy dogs.<br />
<br />The quick brown fox jumps over those lazy dogs.
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
<br />
The quick brown fox jumps over those lazy dogs.</div>
</body>
</html>
Both sets of code are the same except for the paragraph / line break issue.
