JoeThousand
Getting smooth polygon
Jun 9, 2012 12:16 AM
Tags: #cs5 #pointstocurves
I draw square. The 1st point and last points are left-top and finally set 5 points.
The direction is clock-wise and made closed path.
To get smooth-curved polygon shape, I used API 'PointsToCurves'.
But, the first and last points are connected by cornered (not smooth) point.
Here's result.
Maybe, I must set that square is closed path, to API, but it seems to be no parameter to set.
So, I want to know how to get smooth corner shape every corner.
I use SDK CS5.
Best regards.
    Jun 11, 2012 7:37 AM   in reply to JoeThousand
    One thing to try is creatin four points (drop the repeated last one) and set the path to be closed. That might let Illustrator do the work for you. Failing that, maybe make sure the first & lastpoints have 'corner' set to false?
    Jun 15, 2012 11:28 AM   in reply to JoeThousand
    Have you tried both of those with five points (i.e. repeating first & last point)? I'm assuming yes. If that doesn't work, I'm kind of stumped. It feels like this should be doable, but I'm not sure why its not working.
