I've created a short course with a quiz. At the end of the quiz, i would like to have the learner go to one of two slides (one for pass - the other for fail). From the "pass" slide, I would like them to click a button where a PDF certificate will open. The "fail" slide will let the user review the content of the course.
Currently, my file will show the "pass" slide, but will advance to other slides when the button is clicked to print the certificate.
Thus far, the "fail" actions are acting as expected.
Can anyone give me suggestions of how I can fix my file?
Is this a button you specifically created or something provided as part of a Captivate template?
If you select the button and look at the Properties panel, are there any actions you can adjust?
If not, then how about putting a blank slide after this 'pass' slide...so when the print button is clicked, that's what it advances too...then setup something on that slide that then jumps/moves to the page you want...(like a 'well done' message or something) - then all other slides are as they are, just adjusted one slide number down...?
Hi there,
Why dont you hide the pass and fail slides and depending upon the quiz result, you can execute advanced action which will fist show the required slide and then perform your action on that slide.
Or once you are on the pass slide, you can add an action "on exit" to either execute a java script and close the window, or to go to a last "thank you" slide.
Let me know if you need any more help on this.
Select the slides you want to hide in the Filmstrip, use the right-click menu to hide them. But it is not possible to show a slide by an advanced action, here I do not know what is meant at all? You can skip a slide using a statement Jump to, but a hidden slide will simply not been included in the published version, no way to get it back once the SWF (or other output) is created.
Another remark: be very careful with actions executed 'On exit' because they will only be done if the last frame of the slide is also reached. That is not always the case, if you have an interactive object that has Success/failure actions to go to another slide the last frames after the pausing point of that object will never be visited and the On exit action not be executed.
Lilybiri
