ceorgejakel
Doesn't work my addChild command on Class
Jun 16, 2012 3:02 AM
Tags: #problem #error #flash #3.0 #action #3 #actionscript #ac3 #actionscript3 #actionscript_3.0
My project running without problem, but when I'm click my object in the stage, I'm taking "TypeError: Error #1009: Cannot access a property or method." error. Here my project https://rapidshare.com/files/1556610915/Proje.rar
my code in fla:
import Gosterge;
var gosterg:Gosterge = new Gosterge();
gosterg.gostergeleriEkle(a,c,k1);
my code in Gosterge.as:
package
          import flash.display.Sprite;
          import flash.events.MouseEvent;
          public class Gosterge extends Sprite
                    public var cerceve:Sprite = new Sprite  ;
                    public function Gosterge():void
                              // constructor code
                    private function tikla(evt:MouseEvent):void
                              trace("tikla çalıştı");
                              cerceve.graphics.lineStyle(1, 0x0000FF, 1);
                              cerceve.graphics.lineTo(100,0);
                              cerceve.graphics.lineTo(100,100);
                              cerceve.graphics.lineTo(0,100);
                              cerceve.graphics.lineTo(0,0);
                              cerceve.x = evt.currentTarget.x - 5;
                              cerceve.y = evt.currentTarget.y - 5;
                              stage.addChild(cerceve);
                    public function gostergeleriEkle(... args):void
                              for (var i:uint = 0; i < args.length; i++)
                                        args[i].addEventListener(MouseEvent.CLICK, tikla);
Please help, I can't find problem.
    Jun 16, 2012 4:23 AM   in reply to ceorgejakel
    Chances are the stage is not a defined entity for the class.  You might need to add an event listener for ADDED_TO_STAGE wherein the event handler establishes the stage for the class.  See if the following tutorial helps solve anything, and if niot, try searching Google using "AS3 ADDED_TO_STAGE"
    http://www.emanueleferonato.com/2009/12/03/understand-added_to_stage-e vent/
    Jun 16, 2012 3:29 PM   in reply to ceorgejakel
    Will itsolve your problem if you pass the stage to the function as an argument.  Since the class is not added to the stage, then it probably needs to be provided a reference to it.  See the bolded changes/additions to the code below...
    import Gosterge;
    gosterg.gostergeleriEkle(this.stage,a,c,k1);
    package
              import flash.display.Stage;
                        public var _stage;
                                  // constructor code
                                  _stage.addChild(cerceve);
                        public function gostergeleriEkle(stag:Stage,... args):void
                                 _stage = args[0];
                                  for (var i:uint = 1; i < args.length; i++)
    Jun 17, 2012 9:48 AM   in reply to ceorgejakel
    You're welcome
