Peter S Price
MIAW crashes Win projector
Jun 14, 2012 7:48 PM
Tags: #crashing_when_starting #miaw
I have used Director 7 quite a bit, but am still learning Dir 11.5 as a newbie.
I want to use a MIAW to show a "tutorial" window with buttons that control handlers in the main window. It works in the editing window, but when I run the projector (in Windows XP) it crashes as soon as I try to call the MIAW:
on mouseUp me
  sWindow = window().new ("Script")
  sWindow.filename = "TeachScr"
  sWindow.open()
  put "Window should be open"
end mouseUp
I am wondering if I need another Xtra to handle MIAWs?
Any help gratefully received - thanks.
    Jun 15, 2012 1:03 AM   in reply to Peter S Price
    When you open the file with this code in it and execute
    put the scriptExecutionStyle
    from the Message Window, what does it report?
    Jun 15, 2012 5:22 AM   in reply to Peter S Price
    Try this
    on mouseUp me
    if  _player.windowlist.getone(window("Script"))=0 then
    end if
      sWindow.open()
    end mouseUp
                                                      or
    on mouseUp me
      sWindow.open()
    end mouseUp
    on closewindow me
    window("window name").forget()
    end
    Jun 15, 2012 6:11 AM   in reply to murali_kumar
    sWindow = window().new ("Script")  <-- this line seems to have a very minor problem... try removing the space between new and ("Script"). It's in the OP's code and in the responder's code. I haven't tested to see if the code works, but considering the error the OP was getting and I've never seen that exact syntax with the space before, I'd guess that was the problem.
    murali_kumar wrote:
    Try this
    on mouseUp me
    end if
      sWindow.open()
    end mouseUp
                                                      or
    on mouseUp me
      sWindow.open()
    end mouseUp
    on closewindow me
    end
    Jun 15, 2012 7:45 AM   in reply to Peter S Price
    I tried your code on my Windows XP SP3 box using D11.5.8 and it works fine. I don't know why you get an error.
    Jun 16, 2012 12:24 AM   in reply to Peter S Price
    So ... instead the projector crashes as soon as the miaw is called.
    What happens when you run it in the authoring environment? Any error messages?
    What does "crashes" mean? Vapourises without any feedback, or ... ?
    Jun 16, 2012 3:27 PM   in reply to Peter S Price
    Would you like to send your files, as a zip archive, to sean (dot) n (dot) wilson (at) gmail (dot) com and I'll have a look and see if there's anything to be fixed.
    Jun 20, 2012 1:20 PM   in reply to Peter S Price
    Your appreciation is humbling.
    I meant to add that you can use 'deactivateApplication' in place of 'deactivateWindow' if you need to react to the user Alt-Tabbing away from your program.
