Mattof79
Move a design from PS to Indesign
Jun 16, 2012 12:23 AM
Tags: #photoshop #pdf #indesign
Hi All,
I have designed a full colour event poster in Photoshop (CS5) in A3 size.
The design itself uses photographs with various layer styles, texture (background) images with pixel gradient masks, text and some .eps logos
The problem that i have come across after designing it is that the final exported pdf (in print quality) is too large for the recipient. They have suggested supplying the art in indesign format (or using indesign to create the .pdf)
While i have a vague knowledge of how to use indesign, i really don't know what i need to do to get my design from Photoshop to indesign and maintain the look of the poster.
So.. Just wondering if anyone would be able to give me an idea of the best way to go about this.
Any help would be much appreciated.... Thanks
    Jun 16, 2012 1:54 AM   in reply to Mattof79
    Hi
    I suggest you make a copy of the Photoshop file (File > Save As... and rename it) so that you keep your layered file in case you need to go back to the original and make further changes. Then flatten the copy and save it as a Photoshop PDF e.g. [PDF/X-1a:2001].
    Derek
  • lilia@
    Jan 31, 2012
    Jun 16, 2012 2:34 AM   in reply to Mattof79
    save as a photoshop pdf or
    in indesign... place the image in a frame and then export to pdf
    Jun 16, 2012 3:24 AM   in reply to lilia@
    By the way, you should ensure that your A3 PSD document is not more than 300ppi (Image > Image size).
    Jun 16, 2012 6:19 AM   in reply to Mattof79
    How did you create this PDF and what makes you or the recipient think ID will create a smaller one?
    If you’re sending this for print, then I would question the printer. File size should not be an issue.
    If it’s just for proofing, then use the PDF optimizer in Acrobat to knock the file size down.
    Finally, if you save as PDF from Photoshop WITHOUT the ability to edit that PDF in Photoshop the file size will drop dramatically. Make sure to save as PSD first.
    Bob
