Doesn't work my addChild command on Class
Jun 16, 2012 Jun 16, 2012
My project running without problem, but when I'm click my object in the stage, I'm taking "TypeError: Error #1009: Cannot access a property or method." error. Here my project https://rapidshare.com/files/1556610915/Proje.rar
my code in fla:
import Gosterge;
var gosterg:Gosterge = new Gosterge();
gosterg.gostergeleriEkle(a,c,k1);
my code in Gosterge.as:
package
          import flash.display.Sprite;
          import flash.events.MouseEvent;
          public class Gosterge extends Sprite
                    public var cerceve:Sprite = new Sprite  ;
                    public function Gosterge():void
                              // constructor code
                    private function tikla(evt:MouseEvent):void
                              trace("tikla çalıştı");
                              cerceve.graphics.lineStyle(1, 0x0000FF, 1);
                              cerceve.graphics.lineTo(100,0);
                              cerceve.graphics.lineTo(100,100);
                              cerceve.graphics.lineTo(0,100);
                              cerceve.graphics.lineTo(0,0);
                              cerceve.x = evt.currentTarget.x - 5;
                              cerceve.y = evt.currentTarget.y - 5;
                              stage.addChild(cerceve);
                    public function gostergeleriEkle(... args):void
                              for (var i:uint = 0; i < args.length; i++)
                                        args.addEventListener(MouseEvent.CLICK, tikla);
Please help, I can't find problem.
ActionScript
938
LEGEND , Jun 16, 2012 Jun 16, 2012
Will itsolve your problem if you pass the stage to the function as an argument.  Since the class is not added to the stage, then it probably needs to be provided a reference to it.  See the bolded changes/additions to the code below...
import Gosterge;
gosterg.gostergeleriEkle(this.stage,a,c,k1);
package
          import flash.display.Stage;
Chances are the stage is not a defined entity for the class.  You might need to add an event listener for ADDED_TO_STAGE wherein the event handler establishes the stage for the class.  See if the following tutorial helps solve anything, and if niot, try searching Google using "AS3 ADDED_TO_STAGE"
http://www.emanueleferonato.com/2009/12/03/understand-added_to_stage-event/
Thank you for your quick response. I will try now, I wasted 2 days for these problem. If I can solve problem, I will write here
I tried your advice, but I can't solve problem. Can you edit my project? if you help me, I would greatful.
import Gosterge;
package
                    public var _stage;
                              // constructor code
                              _stage.addChild(cerceve);
                    public function gostergeleriEkle(stag:Stage,... args):void
                             _stage = args[0];
                              for (var i:uint = 1; i < args.length; i++)
Jun 17, 2012 Jun 17, 2012
Thank you very much, thank you very much, really thank you very much , I finally understood. It works now . My class couldn't reach the stage. Mr. Ned, you're the best , I'm so grateful
You're welcome
