jh369057
Honeypot Field
Feb 9, 2009 2:56 PM
I am trying to create a honeypot within my comments form. So I am wondering once I have a hidden field how do I tell dreamweaver not to submit the form if my hidden "honeypot" field is filled out by a bot.
    Feb 9, 2009 3:06 PM   in reply to jh369057
    1. A honeypot field is not a type="hidden" field. It's a field that is
    styled with CSS to display:none. Thus, it's not visible on the screen, and
    unless you knew CSS, you wouldn't know that it's not visible.
    2. You process the form on the server after it's submitted, and if the
    honeypot has been 'touched' so that it doesn't contain the default value,
    then you simply discard the submission.
    It will require server scripting to accomplish. It's not a Dreamweaver or
    an HTML or even a javascript thing....
    Murray --- ICQ 71997575
    Adobe Community Expert
    (If you *MUST* email me, don't LAUGH when you do so!)
    http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
    http://www.dwfaq.com - DW FAQs, Tutorials & Resources
    "jh369057" <webforumsuser@macromedia.com> wrote in message
    news:gmqcac$p6v$1@forums.macromedia.com...
    >wondering
    > form if
    Feb 9, 2009 3:58 PM   in reply to jh369057
    If your server supports PHP, this Formm@ailer script from DB Masters
    conceals your email address from prying eye email harvesters and it has
    several spam controls built into its script including hidden field
    (honeypot), "sorta captcha," and time limits on submissions to keep robots
    from exploiting your forms. Free to use if you credit the author; $20 if
    you don't.
    http://dbmasters.net/index.php?id=4
    Q&A Forum - http://dbmasters.net/forum.php?id=3&fid=9
    --Nancy O.
    Alt-Web Design & Publishing
    www.alt-web.com
    Feb 10, 2009 3:39 AM   in reply to jh369057
    > And I set my filter to not display anything that is not 'NULL'
    Where did you set that?
    > is there a simple code to either not submit or auto delete these
    In the form processing script the first thing you do is to check the
    honeypot fields. If they have been 'jiggered' you bypass the rest of the
    processing. It sends no email for them.
    news:gmqo52$9dr$1@forums.macromedia.com...
    > So I used <input name="LastName" type="text" id="LastName" style="display:
    > none;"/>. And I set my filter to not display anything that is not 'NULL'
    > but
    > is there a simple code to either not submit or auto delete these so I dont
    > have
    > to manually delete these entries?
    Jun 16, 2012 3:59 AM   in reply to Newsgroup_User
    Hi!, I have read that the users who have CSS disabled will see the field with the "display: none", and if we write something like "If you see this, leave this form field blank" for them the bot will read it as well and may avoid it.
    I was thinking a way to avoid this problem: just hide the honeypot field with an "ap Div" layer so the user won´t see it and I think it won´t be affected by a css disabled. Do you think it will work?, do you know a better solution?.
    Thanks in advance for your time!!
    Toni
    Jun 16, 2012 9:21 AM   in reply to Toni-77
    You need CSS to create APDiv layers too.  So there's nothing to be gained here.
    Unlike JavaScript which some people disable for security reasons, CSS is almost never disabled anymore because all modern browsers support it.
    Nancy O.
    Jun 17, 2012 3:25 AM   in reply to Nancy O.
    Thanks Nancy! I am new and it´s nice people help!. Isn´t there anything to put over the honeypot field to hide it from users without using CSS or anything else that could be disabled?.
    Toni
    Jun 17, 2012 9:31 AM   in reply to Toni-77
    In a word, no.
    Don't lose sleep over this. I've been using hidden fields on forms for years and it's never been a problem.
    If you don't like the hidden field approach, add a simple question to your forms that spam bots can't answer.
         "Which day of the week follows Tuesday?"
         "How many are in a dozen?"
    Nancy O.
    Jun 18, 2012 1:07 AM   in reply to Nancy O.
    Ok and thanks very much!, I buy honeypot, it seems almost perfect!. Another issue I have just read about it: the honeypot field may be filled as well by the web browser's autocomplete function for users so we would treat them as bots. To avoid it we could add autocomplete="off", it seems it works for most browsers.
    Do you know if it really works fine?.
    Toni
    Jun 18, 2012 9:39 AM   in reply to Toni-77
    Again, I don't see this as an issue to worry about.  I put my hidden field at the very top of the form.  Browser autocomplete only activates when the form input field is a) in focus by mouse click or tab key and b) when user types a character into the field. Since humans can't see the field, it never reaches focus.
    Nancy O.
    Jun 18, 2012 12:57 PM   in reply to Nancy O.
    Ok and thank you very much for your time!. Best regards, Toni
