Hey guys,
I have a kind of beginner question. I made a document with four layers:
background - parting linies - head lines - information
Each layer has many many elements (like parting lines: parting line 1, parting line 2, parting line 3 > each transformed 50 pixels).
The final result is a list that looks like this:
_______________
Head Line
- info
- info
_______________
Head Line
- info
- info
_______________
Now I want to resize the distances between each list element to 60 pixels. And it's a list that consists out of about 200 boxes. Is it possible to transform all elements the same way? Or do I have to mark each element on each layer that I want to transform? And which tool do I have to use? I have three columns and it would really take a long time to do this for each box and each elment of the box :-( There must be another way...
I hope someone understands my beginner problem :-/ Hard to explain in English ![]()
Thanks for your support...
Of course I can. It's all about the red marked box. I tried to change the layers into English that it's easier for you to understand.
As I already mentioned I have three columns like you can see on the left. This is the folder of one of them. Each folder contains "arrows", "pictures", "information boxes", "titels" and "lines 160px".
I only want to make the distance between each box (like "Gingium Loesung") 10px bigger. Is it only possible by grabbing each line, each arrow, each title,....Or can't I mark all I need and say "10 px down" like in Illustrator or Indesign?
Thanks a lot ![]()
We can't see what is going on because the layers are hidden groups, but I suspect each Type layer is a seperate layer, which means you will have to move them one at a time. If you want to increase the distance betweenn a group of type layers, then just move the group, but I have a feeling you would have thought of that.
Select the Layer Groups, set the Ruler to pixels, hit command-T (or ctrl-T) and change the Y-setting in the Options Bar accordingly.
Unfortunately the Options Bar’s entry fields don’t support mathematical operations yet.
It would be possible to create a Script to get an entry-dialog for the offset, but that hardly seems worthwhile.
