SotManiac
Graphic Styles, Multiple Strokes
Jun 16, 2012 4:44 PM
Tags: #illustrator #appearance #graphic_style #multiple_stroke
I make a graphic style with more than one stroke. I choose the brush tool. I click the graphic style. I draw a line. only one of the strokes is applied to the path. I have to select the path again, and then click the graphic style for it to apply.
"New art has basic appearance" is unchecked.
It's time consuming and frustrating. And it takes the punch out of one of the better additions to the program.
    Jun 16, 2012 11:49 PM   in reply to SotManiac
    Well to be honest this is going to sound sarcastic but it is not intended. You make three lines the way you want it to apply to new shapes. the you select and drg it ot he brush panel and eselct to make it an pattern brush you have to read the help files in order to understand how to make a pattern brush.
    Like this one
    Jun 17, 2012 5:22 AM   in reply to SotManiac
    Don't choose the Brush Tool. Use the Pencil Tool.
    JET
    Jun 17, 2012 5:22 PM   in reply to SotManiac
    I am a student learning the cs6 package for design school. I recently got a subscription to macprovideo.com (great decision), and recalled a video that dealt with graphic styles. I checked it out, and it happens to be one of the free ones! check it out it may help.
    http://www.nedwebserver.com/ned-web/ai-cs6-102-objects-and-layers-crea te-a-map&nedweb&site=MPV&asv=18&sid=hb80iib4odga5uuboib0tk42s7
    Jun 18, 2012 6:27 AM   in reply to SotManiac
    You can do it layer based by assigning the appearance to the layer. If you already have the style, first click the dot representing the target, next to layer's name in the layer's panel and then click the style in the style panel. All brush strokes you make on this layer will appear with the same style. However if the brush paths overlap each other the strokes will not. You can achieve the overlap by using another layer with the same style.
