FMS causes memory to fill and crash linux server
May 10, 2012 10:13 AM
FMS 4.5 on centOS 6.2
Issue - error in stream either encoder issue or packet loss (rtmp sent to server to livepkgr HTTP streaming out, using f4m for flash machines and m3u8 for iOS) causes FMS to ramp up memory until 100%usage causing the server to crash.  why is this happening????? need help pronto! Thanks!
    May 12, 2012 7:15 AM   in reply to iGoez
    FMS 4.5 is not officialy supported on CentOS 6.2 - so we've not tested if from our end - but i don't see whether there should issue from FMS end - may be something is changed in 6.2 from 5.5 which is causing this.
    Do you see anything in you master/core/edge logs which can be little indicative of what might be happening?
    May 15, 2012 8:19 AM   in reply to SE_0208
    We are having a similar problem, although not on CentOS 6.2   We are running on RedHat:
    Red Hat Enterprise Linux Server release 5.8 (Tikanga)
    Kernel:
    Linux stream1 2.6.18-308.4.1.el5 #1 SMP Wed Mar 28 01:54:56 EDT 2012 x86_64 x86_64 x86_64 GNU/Linux
    FMS:
    FMS_4_5_0_r297
    The FMS httpd server is consuming all the memory in the system (here is the output from top):
      PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+ COMMAND
      26118 fms       19   0 12.6g 7.3g 1672 S 99.6 93.6   9:46.69 httpd
    Our system has 8Gb of physical memory and 10Gb of swap.   It consumes all the memory then all the sway until the system is trashed to death.
    After some time the system will kill off the process:
      May  9 10:03:57 stream1 kernel: Out of memory: Killed process 26118, UID 505, (httpd).
    There is nothing obvious in the master.log:
    #Fields: datetimex-pidx-statusx-ctxx-comment
    2012-05-0908:45:4031937(i)2581173FMS detected IPv6 protocol stack!-
    2012-05-0908:45:4031937(i)2581173FMS config <NetworkingIPv6 enable=false>-
    2012-05-0908:45:4031937(i)2581173FMS running in IPv4 protocol stack mode!-
    2012-05-0908:45:4031937(i)2581173Host: stream1 IPv4: 127.0.0.1-
    2012-05-0908:45:4031937(i)2571011Server starting...-
    2012-05-0908:45:4131937(i)2581413/opt/adobe/fms/Apache2.2/bin/httpd -f ./conf/httpd.conf -d "/opt/adobe/fms/Apache2.2" -k start returned 0: [Wed May 09 08:45:40 2012] [info] mod_jithttp - FMS installation path: "/opt/adobe/fms/"
    httpd: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName-
    2012-05-0908:45:4131937(i)2581224Edge (31960) started, arguments : -edgeports ":1935,80" -coreports "localhost:19350" -conf "./conf/Server.xml" -adaptor "_defaultRoot_" -name "_defaultRoot__edge1" -edgename "edge1".-
    2012-05-0908:45:4131937(i)2571111Server started (./conf/Server.xml).-
    2012-05-0908:48:0831937(i)2581221Core (32387) started, arguments : -adaptor "_defaultRoot_" -vhost  -app  -inst  -tag  -conf "./conf/Server.xml" -name "_defaultRoot_::::".-
    2012-05-0909:34:5831937(w)2581171System memory load (91) is high.-
    2012-05-0910:03:5931937(i)2581172System memory load (58) is now below the maximum threshold.-
    2012-05-0910:05:5831937(w)2581171System memory load (91) is high.-
    Or the edge.log:
    #Date: 2012-05-09
    #Fields: date    time    x-pid    x-status    x-ctx    x-comment
    2012-05-09    08:45:41    31960    (i)2581173    FMS detected IPv6 protocol stack!    -
    2012-05-09    08:45:41    31960    (i)2581173    FMS config <NetworkingIPv6 enable=false>    -
    2012-05-09    08:45:41    31960    (i)2581173    FMS running in IPv4 protocol stack mode!    -
    2012-05-09    08:45:41    31960    (i)2581173    Host: stream1 IPv4: 127.0.0.1    -
    2012-05-09    08:45:41    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : localhost:19350/v4    -
    2012-05-09    08:45:42    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 80/v4    -
    2012-05-09    08:45:42    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 1935/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:19350 (rtmfp-core)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.71:19350 (rtmfp-core)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.70:19350 (rtmfp-core)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 10.0.0.1:19350 (rtmfp-core)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 192.168.122.1:19350 (rtmfp-core)/v4    -
    2012-05-09    08:45:43    31960    (i)2631509    Public rtmfp-core addresses for listener _defaultRoot__edge1 are: 127.0.0.1:19350;128.252.28.71:19350;128.252.28.70:19350;10.0.0.1:1935 0;192.168.122.1:19350    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:1935 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.71:1935 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.70:1935 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 10.0.0.1:1935 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 192.168.122.1:1935 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 127.0.0.1:80 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.71:80 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 128.252.28.70:80 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 10.0.0.1:80 (rtmfp)/v4    -
    2012-05-09    08:45:43    31960    (i)2631174    Listener started ( _defaultRoot__edge1 ) : 192.168.122.1:80 (rtmfp)/v4    -
    2012-05-09    08:48:08    31960    (i)2581252    Registering core (32387).    -
    2012-05-09    09:34:58    31960    (w)2581171    System memory load (91) is high.    -
    2012-05-09    10:04:00    31960    (i)2581172    System memory load (58) is now below the maximum threshold.    -
    2012-05-09    10:05:58    31960    (w)2581171    System memory load (91) is high.    -
    Our exact stream setup is like this:
    We are using livepkgr.  Three streams 200,500,1000Kb streams.   We have written a f4m and m3u8 manifest for the 3 streams.   We modified the event.xml based on Adobes recommendations.   We modified the manifiest.xml making sure it matches the f4m and m3u8 bit rates.
    Anything you can help us with would be appricated.
    Jun 5, 2012 6:56 AM   in reply to SE_0208
    Having the same issue CentOS release 5.7 (Final) 12G ram.
    httpd eats up all resources and kills the server.
    Using livepkr for HDS and HLS.
    Any help on this issue would be greatly appreciated.
    Jun 13, 2012 6:30 AM   in reply to RMonst3r
    Hello,
    it seems to be a common issue.
    same problem for me on Linux Machine with RAM 16 Gbytes:
    Linux 2.6.18-274.3.1.el5 #1 SMP Tue Sep 6 20:13:52 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
    Into Messages logs i have a lot of: Server[17763]: System memory load (91) is high. and then the system crashes... no more services up.
    Please any advice?
    Jun 13, 2012 6:59 AM   in reply to Zeromega
    Please use latest FMS 4.5.2 as there has been lots of memory and performance improvements from 4.5.0.297 build. Let me know if you still see the issue.
    Jun 13, 2012 7:17 AM   in reply to Amit Kumar
    WIll try and let you guys know how it works.
    Jun 15, 2012 6:00 PM   in reply to RMonst3r
    Still happening on lastest FMS.
    Processes on this host with the greatest increase in usage of Memory during the last 5 minute(s) (from June 15 23:36 UTC to June 15 23:40 UTC):
    httpd1862010.32 GB
    Server crash.
    Jun 16, 2012 1:17 AM   in reply to RMonst3r
    I've added RLimitMEM 1000000000 1000000000 on the apache conf to see if that would prevent the entire machine from crashing.
    Will see...
    Jun 16, 2012 10:06 PM   in reply to RMonst3r
    That didn't work either...
    http://s18.postimage.org/5djfu9qfd/fmscrash.png
    Never had a problem with FMS using the live application, only when i started using livepkr and HLS this started happening every day.
    Unfortunately we need HLS/HTML5 streaming, if this cannot be fixed soon we will have to dump the fms platform in favor of a competitor.
    Jun 27, 2012 2:13 AM   in reply to RMonst3r
    Guys,
    I am looking to reproduce this at my end. I am working with FMS 4.5.2 on CentOS 6.2.
    Few questions:
    1. What kind of load does the server have?
    2. After how long does this occur?
    3. For how long are the streams published?
    Shiven
    Jun 27, 2012 1:43 PM   in reply to ShivenK
    I put FMS in it's own CentOS 5.5 Xen VM and it's behaving now.
    Can't really experiment with it since it's on a production machine.
    Sep 17, 2012 11:14 AM   in reply to RMonst3r
    I`m using Adobe Media Server 5 on a EC2 running CentOs 5.5 and I have the exact same issue.
    on my logs, there are several messages of high memory usage, then below threshold, even when I have less than 50 clients.
    I use two interactive applications.
    My daily load is around 5.000 recorded streams.
Bookmarked By (3)
