Hi guys,
I accidently threw a few photos into the trash in LR4. How do I recover them? I can't find them anywhere. Thank you.
David
Open your Recycle Bin / Trash Can.
You will see a list of all files that are in the trash.
Highlight the ones you want to recover ( you can use Ctrl + click to select several files) and - still in the Recycle Bin go >File >Restore.
This is in Windows; it might be somewhat different on a Mac but the principle should be the same.
<Restore> puts the files back into the folder where they were before you trashed them.
After <Restore> your images will not be automatically displayed in Lr, since by sending them to the Recycle Bin they also were removed from the catalog.
You have to do a <Synchronize folder> to re-import them into Lr.
Also, since the images were removed from the catalog, your images will have lost all edits that you made previously in Lr.
david,
Photos are not "in" Lr in any way. Photos are on your hard drive and Lr links to them.
Since Lr is not a browser based program, i.e. it does not automatically "see" what is on your hard drive, you cannot use Lr to find the photos in your case.
You have to use Mac Finder to find the photos. If Mac Finder cannot find them then the sad conclusion is that they are gone for good.
If Mac Finder finds them, note down the exact location where they are. Or, if you want, move the photos via Mac Finder to a new location, and note that location.
Then open Lr and re-link Lr to the photos.
See here how the re-linking is done: http://www.computer-darkroom.com/lr2_find_folder/find-folder.htm
PS:
Actually, since the photos have been removed from Lr, the re-linking won't work.
You have to do the <Synchronize folder> for re-importing these photos into Lr.
Synchronize folder will work only if you have found /moved the photos in a folder that is being displayed in Lr already.
If you have found / moved the photos in a folder that's not displayed in Lr, you have to import them and navigate to the folder in question in the Source panel (left side0 of the Import dialog.
Message was edited by: web-weaver (PS added)
Hi...
Need not to worry, now also you can retrieve them back. Two month back one of my friend accidentally pressed delete option instead restore option in trash on Mac OS, leads to data loss. To restore deleted files from trash approached the Mac OS X file Recovery tool.
Now he is able to access that deleted files from trash on Mac OS. Demo version of that software provides better results, after he purchased that software to restore deleted files.
