I recently upgraded form cs3 to cs6 photoshop. When I try to use the Akamai Netsession Download it gets to 1 second to go and starts downloading from the begining.The partial download is about 1GB in size. I've tried the alternative download option and when I go to open the DMG I get a checksum error message. I've turned that off in the Disk Utility preference options and the DMG will now open and istall but completes with errors, namely CS6 Bridge has not been installed and I get a huge list of errors, DF027, DW063, DF023, DF001. I had CS6 beta installed but uninstalled that before I tried to install anything. Where do I go from here??
Which version of the Mac you are on ?
Also please provide the Install logs for further analysis for the issue.
I'm running 10.7.4
Here's the install logs:
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF027, DW063 ... WARNING: DS012 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 435 error(s), 15 warning(s)
----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 21)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 22)
----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 11)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 12)
----------- Payload: {48623899-C152-457D-9B30-1F957332AC2F} AdobeColorPhotoshop CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 3)
----------- Payload: {78E38D75-4D92-4F6E-B631-17A436BED680} AdobeColorVideoProfilesCS CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 5)
----------- Payload: {97BA0109-F6BE-4F50-8904-C19442D7216E} Adobe Bridge CS6 5.0.0.0 -----------
ERROR: DF027: Unable to copy file from "/private/tmp/.tempdirXsFt84eM/Assets1/Adobe Bridge/Adobe Bridge CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/Resources/P S3VM32" to "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/Resources/P S3VM32" (Seq 427)
ERROR: DW063: Command ARKCopyFileCommand failed.(Seq 427)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents/Info.plist". (Seq 139)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 139)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app/Contents"(Seq 139)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 139)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Adobe Bridge CS6.app"(Seq 139)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/Resources/Photoshop Adapter.rsrc". (Seq 138)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 138)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/Resources/Localizable.strings". (Seq 137)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 137)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/Resources"(Seq 137)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 137)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter". (Seq 136)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 136)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/MacOS"(Seq 136)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 136)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/_CodeSignature/CodeResources". (Seq 135)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 135)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/_CodeSignature"(Seq 135)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 135)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents/CodeResources"(Seq 134)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 134)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin/Contents"(Seq 134)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 134)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required/Photoshop Adapter.plugin"(Seq 134)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Required"(Seq 134)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/TRUMATCH.acb". (Seq 133)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 133)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/TOYO COLOR FINDER.acb". (Seq 132)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 132)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/TOYO 94 COLOR FINDER.acb". (Seq 131)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 131)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Solid Uncoated.acb". (Seq 130)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 130)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Solid Coated.acb". (Seq 129)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 129)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Premium Metallics Coated.acb". (Seq 128)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 128)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Pastels & Neons Uncoated.acb". (Seq 127)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 127)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Pastels & Neons Coated.acb". (Seq 126)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 126)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Metallic Coated.acb". (Seq 125)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 125)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Color Bridge Uncoated.acb". (Seq 124)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 124)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ Color Bridge Coated.acb". (Seq 123)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 123)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ CMYK Uncoated.acb". (Seq 122)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 122)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE+ CMYK Coated.acb". (Seq 121)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 121)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE solid uncoated.acb". (Seq 120)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 120)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/PANTONE solid coated.acb". (Seq 119)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 119)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS Z.acb". (Seq 118)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 118)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS Z Process.acb". (Seq 117)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 117)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS N.acb". (Seq 116)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 116)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS N Process.acb". (Seq 115)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 115)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS K.acb". (Seq 114)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 114)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS K Process.acb". (Seq 113)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 113)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS E.acb". (Seq 112)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 112)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/HKS E Process.acb". (Seq 111)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 111)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/FOCOLTONE.acb". (Seq 110)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 110)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/DIC Color Guide.acb". (Seq 109)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 109)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Color Books/ANPA Color.acb". (Seq 108)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 108)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Presets/Color Books"(Seq 108)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 108)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Batch Rename/String Substitution.setting". (Seq 107)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 107)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Presets/Batch Rename/Default.setting". (Seq 106)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 106)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Presets/Batch Rename"(Seq 106)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 106)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Presets"(Seq 106)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/Resources/WBMP.rsrc". (Seq 105)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 105)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/Resources"(Seq 105)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 105)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/MacOS/WBMP". (Seq 104)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 104)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/MacOS"(Seq 104)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 104)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/_CodeSignature/CodeResources". (Seq 103)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 103)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/_CodeSignature"(Seq 103)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 103)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/PkgInfo". (Seq 102)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 102)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/Info.plist". (Seq 101)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 101)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents/CodeResources"(Seq 100)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 100)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin/Contents"(Seq 100)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 100)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/WBMP.plugin"(Seq 100)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/ZigZag.eve". (Seq 99)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 99)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Wind.eve". (Seq 98)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 98)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Wave.eve". (Seq 97)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 97)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Twirl.eve". (Seq 96)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 96)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Tiles.eve". (Seq 95)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 95)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Targa.eve". (Seq 94)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 94)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Standard Multiplugin.rsrc". (Seq 93)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 93)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Spherize.eve". (Seq 92)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 92)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/SmartBlur.eve". (Seq 91)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 91)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Shear.eve". (Seq 90)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 90)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Ripple.eve". (Seq 89)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 89)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/RadialBlur.eve". (Seq 88)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 88)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/PreciseFlareCenter.eve". (Seq 87)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 87)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Polar.eve". (Seq 86)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 86)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Pointillize.eve". (Seq 85)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 85)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/png.eve". (Seq 84)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 84)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Pinch.eve". (Seq 83)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 83)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/MezzoTint.eve". (Seq 82)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 82)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/LensFlare.eve". (Seq 81)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 81)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/IllustratorExport.eve". (Seq 80)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 80)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/gif.eve". (Seq 79)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 79)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Fibers.eve". (Seq 78)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 78)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Extrude.eve". (Seq 77)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 77)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Displace.eve". (Seq 76)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 76)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Deinterlace.eve". (Seq 75)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 75)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/Crystallize.eve". (Seq 74)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 74)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/ColorHalftone.eve". (Seq 73)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 73)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/bmpadvanced.eve". (Seq 72)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 72)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/bmp.eve". (Seq 71)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 71)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/aiff.eve". (Seq 70)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 70)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources/ACR_PS.eve". (Seq 69)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 69)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Resources"(Seq 69)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 69)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin". (Seq 68)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 68)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/MacOS"(Seq 68)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 68)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/_CodeSignature/CodeResources". (Seq 67)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 67)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/_CodeSignature"(Seq 67)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 67)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/PkgInfo". (Seq 66)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 66)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/Info.plist". (Seq 65)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 65)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents/CodeResources"(Seq 64)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 64)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin/Contents"(Seq 64)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 64)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Standard Multiplugin.plugin"(Seq 64)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/Resources/Radiance.rsrc". (Seq 63)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 63)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/Resources"(Seq 63)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 63)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/MacOS/Radiance". (Seq 62)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 62)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/MacOS"(Seq 62)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 62)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/_CodeSignature/CodeResources". (Seq 61)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 61)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/_CodeSignature"(Seq 61)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 61)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/PkgInfo". (Seq 60)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 60)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/Info.plist". (Seq 59)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 59)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents/CodeResources"(Seq 58)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 58)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin/Contents"(Seq 58)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 58)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Radiance.plugin"(Seq 58)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/Resources/Pixar.rsrc". (Seq 57)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 57)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/Resources"(Seq 57)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 57)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/MacOS/Pixar". (Seq 56)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 56)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/MacOS"(Seq 56)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 56)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/_CodeSignature/CodeResources". (Seq 55)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 55)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/_CodeSignature"(Seq 55)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 55)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/PkgInfo". (Seq 54)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 54)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/Info.plist". (Seq 53)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 53)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents/CodeResources"(Seq 52)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 52)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin/Contents"(Seq 52)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 52)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Pixar.plugin"(Seq 52)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/Resources/PCX.rsrc". (Seq 51)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 51)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/Resources"(Seq 51)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 51)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/MacOS/PCX". (Seq 50)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 50)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/MacOS"(Seq 50)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 50)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/_CodeSignature/CodeResources". (Seq 49)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 49)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/_CodeSignature"(Seq 49)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 49)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/PkgInfo". (Seq 48)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 48)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/Info.plist". (Seq 47)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 47)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents/CodeResources"(Seq 46)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 46)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin/Contents"(Seq 46)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 46)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PCX.plugin"(Seq 46)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/Resources/PBM.rsrc". (Seq 45)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 45)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/Resources"(Seq 45)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 45)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/MacOS/PBM". (Seq 44)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 44)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/MacOS"(Seq 44)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 44)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/_CodeSignature/CodeResources". (Seq 43)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 43)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/_CodeSignature"(Seq 43)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 43)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/PkgInfo". (Seq 42)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 42)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/Info.plist". (Seq 41)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 41)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents/CodeResources"(Seq 40)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 40)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin/Contents"(Seq 40)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 40)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/PBM.plugin"(Seq 40)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/Resources/MultiProcessor Support.rsrc". (Seq 39)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 39)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/Resources/Info.plist". (Seq 38)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 38)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/Resources"(Seq 38)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 38)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support". (Seq 37)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 37)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/MacOS"(Seq 37)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 37)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/_CodeSignature/CodeResources". (Seq 36)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 36)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/_CodeSignature"(Seq 36)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 36)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/PkgInfo". (Seq 35)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 35)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/Info.plist". (Seq 34)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 34)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents/CodeResources"(Seq 33)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 33)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin/Contents"(Seq 33)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 33)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MultiProcessor Support.plugin"(Seq 33)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/Resources/MMXCore.rsrc". (Seq 32)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 32)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/Resources/Info.plist". (Seq 31)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 31)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/Resources"(Seq 31)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 31)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/MacOS/MMXCore". (Seq 30)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 30)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/MacOS"(Seq 30)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 30)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/_CodeSignature/CodeResources". (Seq 29)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 29)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/_CodeSignature"(Seq 29)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 29)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/PkgInfo". (Seq 28)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 28)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/Info.plist". (Seq 27)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 27)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents/CodeResources"(Seq 26)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 26)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin/Contents"(Seq 26)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 26)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/MMXCore.plugin"(Seq 26)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/Resources/JPEG2000.rsrc". (Seq 25)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 25)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/Resources"(Seq 25)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 25)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/MacOS/JPEG2000". (Seq 24)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 24)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/MacOS"(Seq 24)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 24)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/_CodeSignature/CodeResources". (Seq 23)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 23)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/_CodeSignature"(Seq 23)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 23)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/PkgInfo". (Seq 22)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 22)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/Info.plist". (Seq 21)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 21)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents/CodeResources"(Seq 20)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 20)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin/Contents"(Seq 20)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 20)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/JPEG2000.plugin"(Seq 20)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/Resources/dicom.rsrc". (Seq 19)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 19)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/Resources"(Seq 19)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 19)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/MacOS/dicom". (Seq 18)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 18)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/MacOS"(Seq 18)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 18)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/_CodeSignature/CodeResources". (Seq 17)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 17)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/_CodeSignature"(Seq 17)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 17)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/PkgInfo". (Seq 16)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 16)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/Info.plist". (Seq 15)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 15)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents/CodeResources"(Seq 14)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 14)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin/Contents"(Seq 14)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 14)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/dicom.plugin"(Seq 14)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/Resources/Cineon.rsrc". (Seq 13)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 13)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/Resources"(Seq 13)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 13)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/MacOS/Cineon". (Seq 12)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 12)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/MacOS"(Seq 12)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 12)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/_CodeSignature/CodeResources". (Seq 11)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 11)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/_CodeSignature"(Seq 11)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 11)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/PkgInfo". (Seq 10)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 10)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/Info.plist". (Seq 9)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 9)
ERROR: DF015: Unable to delete symlink "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents/CodeResources"(Seq 8)
ERROR: DW063: Error rolling back command ARKCopySymlinkCommand(Seq 8)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin/Contents"(Seq 8)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 8)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins/Cineon.plugin"(Seq 8)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Plug-Ins"(Seq 8)
ERROR: DF032: Unable to restore display attributes of "/Applications/Adobe Bridge CS6" to 0000 with mask 0002(Seq 7)
ERROR: DW063: Error rolling back command ARKSetDisplayAttributesCommand(Seq 7)
ERROR: DF032: Unable to restore display attributes of "/Applications/Adobe Bridge CS6/Icon
" to 0001 with mask 0001(Seq 7)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Icon
". (Seq 7)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 7)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/fr_MA/license.html". (Seq 6)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 6)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/fr_MA"(Seq 6)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 6)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/fr_CA/license.html". (Seq 5)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 5)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/fr_CA"(Seq 5)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 5)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/es_MX/license.html". (Seq 4)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 4)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/es_MX"(Seq 4)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 4)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/en_IL/license.html". (Seq 3)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 3)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/en_IL"(Seq 3)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 3)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/en_GB/license.html". (Seq 2)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 2)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/en_GB"(Seq 2)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 2)
ERROR: DF023: Unable to delete file "/Applications/Adobe Bridge CS6/Legal/en_AE/license.html". (Seq 1)
ERROR: DW063: Error rolling back command ARKCopyFileCommand(Seq 1)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal/en_AE"(Seq 1)
ERROR: DW063: Error rolling back command ARKCreateDirectoryCommand(Seq 1)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6/Legal"(Seq 1)
ERROR: DF001: Unable to get permissions of "/Applications/Adobe Bridge CS6"(Seq 1)
----------- Payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2259)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2260)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2261)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2262)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2263)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2264)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2265)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2266)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'en_GB' try fetching for en_US(Seq 2267)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe Bridge CS6: Install failed
