Keeping Two Copies of Original Image in File
Jun 17, 2012 1:02 AM
If I select Edit Content on a Smart Object layer, and then select Duplicate Layer, will that put two copies of the original image in the file?
I used the Place command to bring high resolution images into a canvas of a much lower resolution. I've already spent a lot of time scaling and positioning the images on the canvas. But it turns out, I would now like to do certain editing on the original pixels of the images because of their greater resolution. Of course, that defeats the purpose of Smart Objects for non-destructive editing.
But there's no reason I can't keep two copies of an original image in a file, and destructively edit only one copy, right?
  • PECourtejoie
    Jan 11, 2006
    Jun 17, 2012 4:21 AM   in reply to NY2LA
    Hello,
    If you target a smart Object and Select duplicate layer, you create another instance of the smart object, editing in one will be reflected in the other.
    If you drag and drop it to the new document icon, you create an independent smart object. (more file size, but editing is not reflected in the other ones)
    Just a thought: If you double-click on the smart object, nothing prevents you to edit it non-destructively.
  • PECourtejoie
    Jan 11, 2006
    Jun 17, 2012 12:48 PM   in reply to NY2LA
    Sorry to have lost you.
    You asked if duplicating a SO creates two files, no, it creates another copy that is parented to the original SO.
    Once an image is dragged as a smart object inside a document, the SO becomes a file embedded inside that document.
    If you edit the original image, changes will not show in the smart object. For that, you would need linked smart objects: http://viget.com/inspire/linked-smart-objects-in-photoshop
    If you double-click the  (non-linked) SO, you will be editing the embedded 6000 px document (and not the original file). If you select save as, you could save it as an independent document.
    I have to say that I'm a bit lost about "But I also want to save a copy of those original images without editing in the files."
  • PECourtejoie
    Jan 11, 2006
    Jun 19, 2012 3:45 AM   in reply to NY2LA
    Ah, OK, I thought that you were duplicaing the SO.
    Yes, that's what I said when I told you that you can edit the smart object non-destructively (keeping the original layer intact, to go back to it if necessary.
