Actionscript external interface onload
Jun 15, 2012 5:22 PM
Hi
I Have this external interface code that sends a video url to a video player when a user clicks a button it goes some thing like this:
<script language="JavaScript" type="text/javascript">
$(document).ready(function() {
function callJavascript(sendText){
   window.document.myMovie.SetVariable("testValue", sendText);
</script>
The code above works fine when a user click a button with onclick the passed variable is a video url
and is send to the player.
The problem is I would like to get the video url passed when the page is loaded.
I have tried.
var sendText=$("Videosroll/Videos/1.flv").val();
</script>
This does not work. I think its because the videoplayer is not fully loaded when this action is called.
I have looked at javascript timers etc. If any one has a solution please help.
  • kglad
    Jul 21, 2002
    Jun 16, 2012 1:24 AM   in reply to Tony404
    use the externalinterface call() method to call callJavascript() (but it wouldn't make any sense to have flash pass sendText so that should be variable in callJavascript() )
  • kglad
    Jul 21, 2002
    Jun 16, 2012 6:31 AM   in reply to Tony404
    again,  in your html use:
    function callJavascript(){
      return videourl;  // <- make sure this is defined.  if it's not defined when your page loads, use a loop in flash to keep calling until it is defined.
    </script>
    // in flash, use:
    import flash.Exteneral.ExternalInterface;
    var videoURL:String=ExternalInterface.call("callJavascript");
    // do whatever with videoURL;
  • kglad
    Jul 21, 2002
    Jun 17, 2012 6:19 AM   in reply to Tony404
    where is videourl (in your html document) defined?
  • kglad
    Jul 21, 2002
    Jun 17, 2012 7:38 AM   in reply to Tony404
    use:
      return "Videos/1.flv";
    </script>
  • kglad
    Jul 21, 2002
    Jun 17, 2012 8:44 AM   in reply to Tony404
    i have no idea why you keep changing the javascript code i suggest.  the only javascript needed is in message 7.  that's it.
    if that fails, add a textfield, assign it an instance name (eg, tf) and use the following actionscript:
    var videoURL:String=ExternalInterface.call("callnow");
    tf.text=videoURL;
    myVid.play(videoURL);
  • kglad
    Jul 21, 2002
    Jun 19, 2012 10:58 AM   in reply to Tony404
    the actionscript is calling the callnow function.   there's no need for that onload="callnow()".
    copy and paste the actionscript you're using.  if that is copied and pasted, you have a typo in you import statement that needs to be fixed.
  • kglad
    Jul 21, 2002
    Jun 28, 2012 5:12 PM   in reply to Tony404
    you're welcome.
