AElisabeth
Why won't my labels print out correctly?
Feb 3, 2012 2:12 PM
Tags: #printing #labels #avery
I have received in an email some labels in Adobe Reader that should be a breeze to print out. And it is - on regular paper, and on the back of the label sheets. As soon as I try to print on the side where the labels are, there is misalignment. The labels are printed too high! The labels are Avery 48260 (uses Avery Template 5160, which is what the creator of the labels told me to use). I have tried sending the sheets both directions, even cut off the top part of the label sheet, so that the print would land on the top label, but then it does NOT print too high! My printer is HP Photosmart C4680.
I called Avery, and I'm using the right product. It could be the thickness of the sheet, that the printer isn't recognizing, but it seems to recognize it when I send it through upside down and it prints on the backside.
Avery suggested I contacted Adobe. I hope someone has some advice for for me.
I just tried one more time (without doing anything differently, on an uncut label sheet, the label side up). This time it aligned well enough that I can use them, although not perfectly. I need twenty of these sheets, but I'm afraid to send them through all at once. They seem to move, somehow...? It must be the printer?
    Feb 8, 2012 4:40 AM   in reply to AElisabeth
    Could you please let me know the following:
    1. What is the version of Adobe Reader installed on your system?
    2. Have you tried changing the Scaling option to "Shrink Oversized pages" / "Shrink to Printable Area" and then printing.
    Jun 17, 2012 5:32 AM   in reply to AElisabeth
    I think "misalignment" is purely a less technical issue. And as you pointed out, the problem is on the paper. How thick are the sheets you used?
