schnarku
link to panel of a nested spry accordion
Jun 16, 2012 12:01 PM
Tags: #spry_accordion #spryurlutils.js
I would appreciate your help with this problem:
I am building a structure with a spry tabbed panel and nested accordions: http://www.ikf.ac.at/neu/projekte_direktlinks.html
Now, I want to link to specific (sub)panels in the structure. I know that this is usually done using spryurlutils.js, which allows you to link to a specific panel by adding a query string and fragment identifier to the url. For instance I would add ?tab=1 to get to the second tabbed panel or ?tab=1&panel=2 to get to the second tabbed panel and the third accordion panel - or, so I thought...
Here's the problem: Since I cannot distinguish between "parent panels" and "nested panels" in the URL the wrong (nested) panels are opened. Linking to http://www.ikf.ac.at/neu/projekte_direktlinks.html?tab=1&panel=2 does open the correct parent panel (#3) but, additionally, opens a subpanel (#3), which I do not want to be opened. Is there a way to distinguish between panels and nested panels in the URL?
I'd be very grateful for any help. Please keep it simple, as I'm not an expert
Best
Lukas
    Jun 16, 2012 12:27 PM   in reply to schnarku
    Jun 16, 2012 1:11 PM   in reply to schnarku
    For this to work, I think you need to give each of your panels a unique ID.
    .tab1
         #panel1
         #panel2
         #panel3
         #panel4
    .tab2
         #panel5
         #panel6
         #panel7
    .tab3
         #panel8
         #panel9
         #panel10
    etc...
    Nancy O.
    Jun 17, 2012 9:19 AM   in reply to schnarku
    Please have a look at the following
    <!doctype html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Untitled Document</title>
    <link href="SpryAssets/SpryTabbedPanels.css" rel="stylesheet">
    <link href="SpryAssets/SpryAccordion.css" rel="stylesheet">
    </head>
    <body>
    <div id="TabbedPanels1" class="TabbedPanels">
      <ul class="TabbedPanelsTabGroup">
        <li class="TabbedPanelsTab" tabindex="0">Tab 1</li>
        <li class="TabbedPanelsTab" tabindex="0">Tab 2</li>
      </ul>
      <div class="TabbedPanelsContentGroup">
        <div class="TabbedPanelsContent">
          <div id="Accordion1" class="Accordion" tabindex="0">
            <div class="AccordionPanel">
              <div class="AccordionPanelTab">TabbedLabel 1.1</div>
              <div class="AccordionPanelContent">
                  <div id="Accordion11" class="Accordion" tabindex="0">
                      <div class="AccordionPanelTab">Label 1.1.1</div>
                      <div class="AccordionPanelContent">Content 1.1.1</div>
                    </div>
                      <div class="AccordionPanelTab">Label 1.1.2</div>
                      <div class="AccordionPanelContent">Content 1.1.2</div>
                    </div>
                  </div>
              </div>
            </div>
              <div class="AccordionPanelTab">TabbedLabel 1.2</div>
                  <div id="Accordion12" class="Accordion" tabindex="0">
                      <div class="AccordionPanelTab">Label 1.2.1</div>
                      <div class="AccordionPanelContent">Content 1.2.1</div>
                    </div>
                      <div class="AccordionPanelTab">Label 1.2.2</div>
                      <div class="AccordionPanelContent">Content 1.2.2</div>
                    </div>
                  </div>
              </div>
            </div>
          </div>
        </div>
          <div id="Accordion2" class="Accordion" tabindex="0">
              <div class="AccordionPanelTab">TabbedLabel 2.1</div>
                  <div id="Accordion21" class="Accordion" tabindex="0">
                      <div class="AccordionPanelTab">Label 2.1.1</div>
                      <div class="AccordionPanelContent">Content 2.1.1</div>
                    </div>
                      <div class="AccordionPanelTab">Label 2.1.2</div>
                      <div class="AccordionPanelContent">Content 2.1.2</div>
                    </div>
                  </div>
              </div>
            </div>
              <div class="AccordionPanelTab">TabbedLabel 2.2</div>
                  <div id="Accordion22" class="Accordion" tabindex="0">
                      <div class="AccordionPanelTab">Label 2.2.1</div>
                      <div class="AccordionPanelContent">Content 2.2.1</div>
                    </div>
                      <div class="AccordionPanelTab">Label 2.2.2</div>
                      <div class="AccordionPanelContent">Content 2.2.2</div>
                    </div>
                  </div>
              </div>
            </div>
          </div>
        </div>
      </div>
    </div>
    <script src="SpryAssets/SpryTabbedPanels.js"></script>
    <script src="SpryAssets/SpryAccordion.js"></script>
    <script src="SpryAssets/SpryURLUtils.js"></script>
    <script>
    var params = Spry.Utils.getLocationParamsAsObject();
    var TabbedPanels1 = new Spry.Widget.TabbedPanels("TabbedPanels1", {defaultTab: params.tab ? params.tab : 0});
    var Accordion1 = new Spry.Widget.Accordion("Accordion1", { useFixedPanelHeights: false, defaultPanel: params.panel ? params.panel: 0 });
    var Accordion11 = new Spry.Widget.Accordion("Accordion11", { useFixedPanelHeights: false, defaultPanel: params.subpanel ? params.subpanel: 0 });
    var Accordion12 = new Spry.Widget.Accordion("Accordion12", { useFixedPanelHeights: false, defaultPanel: params.subpanel ? params.subpanel: 0 });
    var Accordion2 = new Spry.Widget.Accordion("Accordion2", { useFixedPanelHeights: false, defaultPanel: params.panel ? params.panel: 0 });
    var Accordion21 = new Spry.Widget.Accordion("Accordion21", { useFixedPanelHeights: false, defaultPanel: params.subpanel ? params.subpanel: 0 });
    var Accordion22 = new Spry.Widget.Accordion("Accordion22", { useFixedPanelHeights: false, defaultPanel: params.subpanel ? params.subpanel: 0 });
    </script>
    </body>
    </html>
    Gramps
    Less than 3 hours to go
    Hup Holland!
    Jul 5, 2012 6:24 PM   in reply to schnarku
    Copy and paste the code that I supplied above into a new document called junk.html and view it in your favourite browser. The default is tabbedpanels tab=0, master accordion panel=0 and sub accordion panel =0.
    To open the second tab, first master panel second subpanel our url would look like
    junk.html?tab=1&panel=0&subpanel=1
    This will show you content 2.1.2 (second tab, first master panel, second subpanel)
    Gramps
