Canon MXF File and Audio Problems
Jun 17, 2012 8:34 AM
I recently purchased a Canon XF-300 camcorder to use with my CS5 Premiere Pro system.
I assumes the XF-300 would create one huge video file until I shut off the machine.
Instead it makes several up to 2 GB MXF files and every time I start/stop the camcorder a new video file is created.
And what make it worse is that it puts each MXF file inside a folder.
When I am shooting a long videos there are problems with editing several 2GB clip as opposed to one 13 GB clip that I used to get with tape.
I use the XF utility to transfer just the video files from my CF card to my hard disk.
Then I perfer to use Pr to concatinate the separate MXF files into one MP2 file wasting a great deal of time.
Is there something I could do with the camcorder of the XF utility to get to one large file?
Also when I put an MXF file a Pr sequence the stero audio track that I am used to from tape separates into 2 separate tracks.
One seems to be mono left and the other mono right.
When I combine them into an MP2 file I get one track of mono sound.
How to I get one track of stero sound?
    Jun 17, 2012 8:55 AM   in reply to Francis Breen
    You did it the wrong way... you copy the entire folder from camera to your hard drive, and import into PPro from there
    Metadata & Project Folder http://forums.adobe.com/thread/1015001?tstart=0
    Jun 17, 2012 8:56 AM   in reply to Francis Breen
    Right click on a clip in the Project Panel and use Modify/Audio Channel and set the channel format to stereo. But what is the problem with having two mono tracks?
    Jun 17, 2012 9:01 AM   in reply to Francis Breen
    If the XF-300 uses the Canon XF codec like the Canon C-300 you can use the 'media browser' inside Premiere.  Once you browse to the master folder it will automatically see the media as XF format, read all the subdirectories and join the spanned clips into one long clip.  Premiere is the only software I use that recognizes the spanned clips from the C-300 (Scratch doesn't, neither does Resove 8).
    I'd copy the media to a hard drive then import into Premiere using the media browser tool.  From there you're ready to rock.
    Jun 17, 2012 9:44 AM   in reply to Francis Breen
    "Then I perfer to use Pr to concatinate the separate MXF files into one MP2 file wasting a great deal of time."
    Francis,
    You can use XF Utility to merge all your individual clips into one (1) single file, with no re-encoding. This will save you time and quality. (In XF Utility, Use Edit > Export to MXF and then select your prefferred export method.)
    No, there is no way to make the camera merge/join all clips into one clip.
    /Roger
    Jun 18, 2012 4:12 AM   in reply to Francis Breen
    Francis,
    From the manual i have:
    Merge All Clips = Merges the MXF stream files within each clip and also merges multiple selected files into a single file.
    Merge Each Clip =  Merges the MXF stream files within each clip but keeps multiple selected files as separate files.
    Regarding the audio issue:
    In Premiere Pro CS6 you can set the Default Audio Tracks so your files import as stereo instead of dual mono/multichannel mono media. I don't know if this was an option in CS5, but i think it is not.
    In CS6 you do this:
    1. Edit > Preferences > Audio ("Premiere Pro > Preferences > Audio" on the Mac)
    2. Under Default Audio Tracks, change Multichannel Mono Media from "Use File" to "Stereo".
    3. Click OK.
    Note that it won't affect already imported clips. This preference setting affects clip when you import them.
    /Roger
