Eye Dropping onto a Gradient
Jun 17, 2012 6:32 AM
Hey guys,
How do I apply an eye dropped color directly to a Gradient Shape? Why can't I just do it like I would when applying a flat color with the Eye Dropper?
Many thanks,
Josh
    Jun 17, 2012 8:23 AM   in reply to Josh525
    Do you want to insert a color into an existing gradient or do you want to apply an existing gradient to an object? I don't understand.
    Jun 17, 2012 10:12 AM   in reply to Josh525
    The answer is yes when you select an object and click the eye dropper on a gradient filled object the selected object will fill with the gradient.
    As Monika suggested you can also get a specific color fron the gradient to fill the object with that specific color but if will be a flat color and you do that by holding down the shift key while clicking the eyedropper on that specific color within the gradient.
    You can also turn off the the option to select a color whther it is a flat  color or gradient in the gradient tool options double click the eye dropper tool in the toolbar and you will see the options.
    Read about the eyedropper tool in the help files.
    Jun 26, 2012 6:03 AM   in reply to Josh525
    You can't drag any color directly onto the shape to put it into a gradient. You can only drag colors into the gradient panel. See the manual on how to edit gradients.
    Jun 26, 2012 7:11 AM   in reply to Josh525
    Stack 2 fills in the appearance palette. You then can easily do color exploration by just changing the bottom fill color.
    Jun 27, 2012 5:25 PM   in reply to Josh525
    Have you tried Edit > Edit Colors > Recolor Artwork?
    Make a copy of your gradient, recolour it and then save the resulting gradient as a swatch.
    Jun 28, 2012 12:32 AM   in reply to Josh525
    Josh,
    Take a closer look at what Mike has done. His upper fill has a gradient with white applied to all the stops, but the two ends have an opacity set to 0, making them transparent; the middle two are set to higher opacity values. The lower single-color (flat) fill shows through completely on the ends, less so where the opacity is higher, simulating a single gradient. Changing the color of the lower fill changes the color of the apparent gradient but maintains the highlight. You don't have to touch the gradient, just select the color fill in the Appearance panel and change its color.
    Peter
    Jun 28, 2012 6:31 AM   in reply to Josh525
    If you have difficulties using the appearance panel, you can do it by making a copy on top of the original object, fill it with flat color and change its color mode.
    Step by step this is:
    Select your object and and from the main menu: choose Edit > Copy and then Edit > Paste in Front
    Fill the selected top object with a flat color, go to the Transparency panel, and change the color blending mode from Normal to Color. This will preserve the luminosity and change only the color when you change the color of the top object
    Alternatively you can choose Paste in Back, fill it with flat color, then select the top object and in the Transparency panel change its color mode to Luminosity. Then select the bottom object and change its color
    Jun 28, 2012 9:19 AM   in reply to Josh525
    Make it a Graphic Style which will copy to a new document.
