I haven't been able to find anything on this. Please point me to a link if I missed it somewhere. How can I divide a line into equal segments in Illustrator? This is computer software, right? Shouldn't a computer be able to figure how to segment an arbitrary line? I tried turning the line into a sliced object and dividing that, but it didn't seem to work. Pathfinder only works on two or more objects. What have I missed? Am I just being really dense? (don't answer that)
Ideas?
noldo,
Presuming you are talking about an arbitrary subdivision of a straight line, you may:
1) Select the target line and set the Reference Point in the Transform palette to a suitable border and write down the X or Y value;
2) Click the Rectangular Grid Tool, set the height/width to the same value as shown in the Transform palette, and set the horizontal or vertical division to the number of subdivision minus one;
3) Insert the X or Y value from 1);
4) Ungroup the grid;
5) With the Scissors Tool cut at the corners of the outer frame of the grid and delete the lines not crossing your target line;
6) Select both target line and gridlines and Pathfinder>Trim and reset the stroke;
7) Delete the cut parts of gridlines.
That should give you an equal division of the target line into short lines. If you want it as one line with equidistant Anchor Points, you may DirectSelect the coinciding end points and Ctrl/Cmd+J to rejoin them.
Not just a click with a tool.
As I am sure you know, you may halve any path repeatedly with Object>Path>Add Anchor Points.
Are you talking about a standalone line segment? How do you want the divided segments arranged?
If the answers are 'yes' and 'I don't care,' I would simply append '/n' (without the quotation marks) to the W or H field in the control or transform panel/palette, where n equals the number of segments into which you want the line divided. Hit Enter to apply the transformation. Then, simply copy and paste n-1 times.
Make sure the constrain proportion link between the W and H fields is activated if the line segment is not perfectly vertical or horizontal.
Oh... and make sure you've turned off 'Scale Strokes & Effects' if you want to maintain stroke weight.
It all depends on whether the path is straight or not and what you call "equal" sections. Equal along a vertical, horizontal or angled axis, or equal along the path.
Object>Path>Add Anchor Points will only halve straight paths. If you're working with curves it will give you unequal results depending on the length of vector handles.
If you want to divide a curve into equal sections it becomes a bit complicated. Dashed strokes with carefully adjusted increments might get you part of the way. But as soon as you expand a dashed stroke its thickness comes into play.
Using Pathfinder on this kind of thing will certainly divide your path into horizontally equal sections, but the steeper the slope of the curve the longer the sections along the line. Please try to define your problem better.
Oh, you guys and your thinking....
I would just use the script here: http://park12.wakwak.com/~shp/lc/et/en_aics_script.html#divide
(lotsa good scripts there - none of them mine.)
All good suggestions.
Jacob, thanks for pointing out the grid tool. That little bugger was hidden to me. Very nice.
Harron, your suggestion works very well though it recreates the line as a segment. Still, it gives me a quick division for a straight line. And it lets the machine do the calculation. I'll be playing with that.
And Jesseham, thanks for that link. I found that too, but was wary of using it for Mac. Have you tried any of those scripts with AICS4/Mac?
Thanks for the help guys!
I can't vouch for AI 14 (CS4), but I can tell you that this particular script works fine on AI 12 (CS2) Mac. This usually bodes well for CS4. Just to make sure, use the .jsx version, which Hiroyuki now includes in his downloadable. (Look for the 'jsx_lf.zip' file within the downloaded .zip file.)
Note that his script creates evenly spaced anchor points along a line or curve segment. You will have to use the scissors tool to separate the segments, if that's what you want.
When discussing "technique" with Illustrator, there's at least 101 different ways to draw whatever. In this particular case, Harron's described method of dividing a straight line into equal segments is also my method of choice. The only thing I'd like to add is, that to retain the original position of the line, regardless if it's horizontal, vertical, or angulated, is the Reference Point that you select. Eddie
Horizontal Line Draw line. Notice that the Reference Point is at 9 o'clock position.
Horizontal Line With line selected, divide by number of segments that you want. In this case, seven.
Horizontal Line Click "Enter".
Horizontal Line Final result after stringing together multiples.
Angled Line Notice that the Reference Point is at 11 o'clock position.
Angled Line Either the W or H may be divided, it does not make a difference.
Angled Line Final result after stringing together multiples.
Noldo, you still haven't answered the questions of those who are trying to help you. Are you talking about a single straight segment (like a path drawn with the Line Tool) or not?
If so, just invoke Filter>Distort>ZigZag. (I'm not using CS4. In that, it would be an Effect.)
Ridges Per Segment: as desired
Points: Corner
JET
All of these are good suggestions, JETalmage, all of them helped me find the answer. All I was trying to do was divide a straight line, whether a path or a line was not important, but, yes, straight, into equal segments of any number (5 segments, 7, 4.35, whatever). This was purely a matter of finding a solution of proportions to work with.
The Zigzag tool is nice but it gives you a zigzag -- not what I wanted.
I think this question has been answered, and I thank you all. I'm glad to see that there are so many solutions -- just as I suspected.
Does anyone know of a "use Illustrator to solve geometrical problems" web page somewhere? Just curious. . .. Can you divide a line into the Golden Section with Illustrator?
Let's call this case closed.
And muchas gracias to all of you. Seriously.
The same principle applies to curved paths, so long as you are talking about adding equidistant points per segment. The added points are equidistant (for practical purposes) along the segment, as you can verify by copying individual segments, pasting them, and then checking the length of each in the Document Info Palette.
You can also verify it by applying the Filter to two ellipses that have the same major diameter but different minor diameters. Note that corresponding points do not align vertically between the two ellipses.
This is useful in equidistant segmenting of segments (but not for equal divisions of whole paths with multiple and unequal segments).
Add Points, on the other hand, does abide by the curvature. So, the corresponding points do align vertically. This is important for example, when you need to find radial angles of an ellipse as when you need an elliptical protractor to use in construction of an illustration. It's also useful for plotting positions for frame-by-frame "orbit" animations, because the orbiting object then "speeds up" as it approaches the minor diameter, and "slows down" as it approaches the major diameter, which is more convincing of a uniform orbital motion.
Unfortunately, Illustrator's rather lame Add Anchor Points command doesn’t provide an option for how many points to add per segment. It only adds points to bisect segments. You have to apply it repeatedly. That rules out odd-numbers of new segments. (Another example of how an Illustrator feature falls far short of completion, compared to other programs.)
So how do you, for example, find the 12 hour posiitions of a circle? You need 2 added points per original segment. Add Anchor Points can’t, but Zig-Zag Filter can. Note that the hour points of a circle, of course, demark each 15 degrees. Certainly a useful increment.
But what about our elliptical protractor? Certainly, for example, an isometric protractor with tick marks every, say, 10 degrees would be a very useful thing. That would require 8 added points per segment. Add Anchor Points can’t do that. Zig-Zag Filter can, but the points would be equidistant--not suitable for use as an elliptical protractor. What to do?
Use Zig-Zag Filter on a circle...
...then scale the circle vertically by 58% (sine of the isometric angle, 35’16”).
Such machinations can be the keys to building isometric elliptical and spherical protractors (and dimetric and trimetric protractors, for that matter)--essential tools for correct construction of simple and compound rotations about the drawing axes.
(Now try to tell me that the various features (and unintuitive workarounds) involved above couldn't and shouldn't be integrated into a single, more discoverable tool.)
JET
