Hardware Question - Graphics Cards
Jun 17, 2012 12:20 PM
Tags: #adobe #mercury #premiere #playback #graphics #engine #nividia
I am building an editing work station and I am considering two graphics cards:  The EVGA Geforce GTX 670 and the Nividia Quadro 4000.  When I looked at benchmark tests on passmark .com it appeared that the GTX actually performed better and was a more powerful card than the Quadro.  My question is how important or how effective is the mercury playback engine?  Is it better to have the GTX which seems to be faster or is it better to have the mercury playback engine working for me?  All opinions welcome.
    Jun 17, 2012 1:32 PM   in reply to editor147
    Go for the Quadro 4000 if one of the following is true:
    1. You have a HP Dreamcolor (€ 1800) 10 bit monitor or better and NEED 10 bit output.
    2. You don't care for lesser performance and you have deep pockets.
    3. You want bragging rights no matter what is costs.
    Go for the GTX 670 if one of the following is true:
    1. You don't need 10 bit output.
    2. You want the best performance for a reasonable amount of money. The best BFTB (bang-for-the-buck).
    3. You may want to attach more than three monitors at some time.
    Recently a € 3900 Quadro 6000 demonstrated that it does not perform any better than a € 237 GTX 470. The Quadro 4000 is far less than a 6000.
    Jun 17, 2012 1:47 PM   in reply to editor147
    Moved to Hardware forum
    Jun 18, 2012 10:39 AM   in reply to editor147
    To the Quadro 4000's benefit, it's a single slot card, requires less PSU wattage and if you are considering 3D animation software, enhances viewport redraw.  On average, the higher cost is definitely a factor against it.  Although mine was (literally) a $2 upgrade over the standard GPU when I ordered my Dell T5500 awhile back.  Now with CS6 I'm able to use my second screen as a large program monitor while also having A/V go out via firewire to a VTR at the same time(with MPE on) in addition to source, program and 'scopes present on my main screen.  I'm pretty sure that this enhancement is not limited to Quadros, but it does work for me.
    BTW, having an extra available card slot could come in handy for a Fusionio ioFX board for AE! ;-)
    Jun 18, 2012 11:37 AM   in reply to Paul@NYN
    Jun 19, 2012 4:37 AM   in reply to Harm Millaard
    I haven't really been keeping up with the GTX 6xx series cards as of yet, but from what I can see, the GTX 670 should handily outperform my GTX 570.  I bring that up because I pulled the Quadro 4000 out of my Mac and replaced it with the GTX 570.  Exports using the MPE in hardware mode took, literally, half the time.
    I can only assume the same would apply to the PC; I see no reason why it wouldn't.
    jas
