I selected one, four, and multiple pictures in Bridge to reduce the file size of jpgs. I went to Tools > Photoshop > Image Processor. Nothing happened. Photoshop did not open. That got me to thinking that sometimes while I am in Photoshop Bridge won't open either. Any ideas on resolving issue of "Bridge not opening Photoshop Image Processor" would be greatly appreciated.
Hello Curt Y, Everything is checked in the "Startup Scripts," including Bridge (twice) and Photoshop (twice). Not sure why duplicate entries but there are.
I found elsewhere in this forum your suggestion to start Photoshop, which I did and I was able to use the image processor via Bridge's Tools > Photoshop > Image Processor. But it still will not work / launch Image Processor if Photoshop is closed.
If you have any suggestions regarding being able to access the Image Processor to resize pictures and such without first opening Photoshop, I'd greatly appreciate it. If not, the work around will have to suffice.
Thank you for sharing your knowledge. ![]()
If you mean that you have two of the same versions (both CS3) in there that indicates there is something wrong with your install
My first goal would be to reset the preferences for both PS and Bridge and then try again
see also this KB document, section preferences reset:
http://helpx.adobe.com/bridge/kb/troubleshoot-errors-freezes-bridge-wi ndows.html
And inhere also info on how to retrieve your path for cache to manual delete it.
I'm experienceing complications when creating a contact sheet using inDesign CS3. I'm selecting .JPEG images using Adobe Bridge CS3 on an Apple PPC; to create using inDesign. I've confirmed that all of the startup scripts are checked in Bridge's preferences. I've navigated down to:
Hard Drive:Applications:Adobe Bridge CS3:Presets:
After I placed ContactSheet_ID.jsx in Presets folder nothing worked.
Well, it hasn't worked for me so far. But yes, it's the inDesign script that does all the work. But having this functionality work through Bridge makes for an efficient workflow. I'm interested with implementing it as an alternative way to present assignments I've photographed on speculation. I believe .JPEG's are too convenient and that's why I'm delivering .PDF contact proofs and presentations.
Check out this link http://forums.macrumors.com/showthread.php?t=433352
They use CS3 and InDesign contact sheet. Hope this helps.
