Having trouble trying to figure out how to have a submit button mailout 2 attachments on the same email generated from mailForm() and mailPDF(). Also having trouble trying to get the generated .FDF file to only contain data of selected fields
Current SOURCE:
var RE = this.getField("RequestExcel").value;
var S = this.getField("SubmitPdf").value;
if(RE == true)
this.mailForm({bUI: true, cTo: "x.x@gmail.com", cCc:"" , cSubject: "TestForm", CMsg:""});
if(S == true)
this.mailDoc({bUI: true, cTo: "x.x@gmail.com", cCc:"" , cSubject: "TestForm", CMsg:""});
The app.newFDF()is a typical example of a security restricted method that needs a
privileged context in which to run. Place the following script in a .js in the User (or App)
JavaScript folder.
trustedNewFDF = app.trustedFunction( function (FileLocation)
// additional code may appear above
app.beginPriv(); // explicitly raise privilege
app.newFDF( FileLocation );
app.endPriv();
// additional code may appear below.
Now, after restarting Acrobat, execute the function trustedNewFDF() from anywhere,
for example, a mouse up action from a push button.
So I've got my javascript array (var seatsArray = [];), let's say it has some contents. I want to write the contents of that array to a .txt file on the server when the user clicks a button. The text file will not already exist so it needs to be created.
Also, if anyone knows how I could allow the user to specify the name of the text file to be created by typing it in a text area, that would be great.
Any ideas?
Many thanks John
EDIT:
Added the suggested code, however, nothing happens when I hit save?
<form id="my_form" action="">
<input type="text" id="file_name" rows="1" cols="20">
<a href="javascript: SubmitForm()">Save</a>
</form>
<script type="text/javascript">
function submitform();
var d = seatsArray.join();
var url = "/txtfiles/"+d + "&file_name=" +
document.getElementById("file_name").value;
document.getElementById("my_form").action = url;
document.getElementById("my_form").method = "POST";
document.getElementById("my_form").submit();
</script>
That is all in the body section.
//Semi Troll Post :/
*Decided 2 take a different route and run a VBA macro in outlook...
*ALready can auto save .XFDF [.xml] (designated form field data) into designated folder in outlook.
*End goal iz to run a macro to load XFDF data into pre-made excel file
Code i have right now will load pre made .xls file if excel is already running....however it would be much more ideal 2 get code to open&load designated .xls file even if an instance of excel is not currently running
CoDE\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
Sub WorkOnAWorkbook()
Dim oXL As Excel.Application
Dim oWB As Excel.Workbook
Dim oSheet As Excel.Worksheet
Dim oRng As Excel.Range
Dim ExcelWasNotRunning As Boolean
Dim WorkbookToWorkOn As String
'specify the workbook to work on
WorkbookToWorkOn = "C:\Users\House\Desktop\XXX Test Forms\TestForms\XXX.xls"
'If Excel is running, get a handle on it; otherwise start a new instance of Excel
On Error Resume Next
Set oXL = GetObject(, "Excel.Application")
If Err Then
ExcelWasNotRunning = True
Set oXL = New Excel.Application
End If
On Error GoTo Err_Handler
'If you want Excel to be visible, you could add the line: oXL.Visible = True here; but your code will run faster if you don't make it visible
'Open the workbook
Set oWB = oXL.Workbooks.Open(FileName:=WorkbookToWorkOn)
'Process each of the spreadsheets in the workbook
For Each oSheet In oXL.ActiveWorkbook.Worksheets
'put guts of your code here
'get next sheet
Next oSheet
If ExcelWasNotRunning Then
oXL.Quit
End If
'Make sure you release object references.
Set oRng = Nothing
Set oSheet = Nothing
Set oWB = Nothing
Set oXL = Nothing
'quit
Exit Sub
Err_Handler:
MsgBox WorkbookToWorkOn & " caused a problem. " & Err.Description, vbCritical, _
"Error: " & Err.Number
oXL.Quit
End If
End Sub
Sub Test()
MsgBox ("Hello world *****!!!!")
End Sub
Sub GenerateExcel()
Dim Wb As String
Dim wbPath As String
'Create variable to instantiate a new Excel instance
Dim xl As New Excel.Application
'hide stuff from user
Application.ScreenUpdating = False
'capture the new workbook's name & path
Wb = ActiveWorkbook.Name
wbPath = Workbooks(Wb).Path
'Close the new workbook before it becomes visible
Workbooks(Wb).Close False
'Open the workbook in the new instance of Excel and set visible
'If the workbook doesn't exist (a new workbook) then
'create a new one in the new Excel instance
xl.Workbooks.Open wbPath & "\" & Wb
If Err.Number > 0 Then
Err.Clear
xl.Workbooks.Add
End If
xl.Visible = True
'Discard the object variable and unhide from user
Set xl = Nothing
Application.ScreenUpdating = True
End Sub
Sub fdfimport()
Dim OutSH As Worksheet
Dim Fname As Variant
Fname = Application.GetOpenFilename("FDF File (*.FDF),*.fdf", , _
"Select Text Data File")
Open Fname For Input As #1
Do While Not EOF(1)
Line Input #1, myvar
arr = Split(myvar, Chr(10))
arr2 = Split(arr(4), "/V")
If InStr(1, myvar, "(Contact)") > 0 Then
Set OutSH = Sheets("Contact")
outrow = OutSH.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row
For i = 1 To 8
placer = InStr(1, arr2(i), ")")
OutSH.Cells(outrow, i).Value = Left(arr2(i), placer - 1)
Next i
Else
Set OutSH = Sheets("NoContact")
For i = 1 To 12
Next i
End If
Loop
Close #1
Sheets("Contact").Cells.Replace what:="(", replacement:=""
Sheets("NoContact").Cells.Replace what:="(", replacement:=""
End Sub
Don't know if this is of any use to you but I have just written a little utility that lets you open multiple XFDF files and load them into a pre-existing (and closed) Excel spreadsheet. It needs to be configured with a mapping of the form fields to the spreadsheet columns but it's published free and may help you... you can look at it at http://www.tarrget.info/XFDF2XL
Cheers, Anthony
