PDF Export Compression - Actual or  Effective?
Jun 17, 2012 10:45 PM
Tags: #pdf #export #preset #actual #compression #ppi #effective
When I create a PDF Export Preset under compression I can set the downlsampling PPI for images at or over a certain PPI e.g. Bicubic Downsamling to 300 pixels per inch for images above 450 pixels per inch.
When I place an image in a document I see the Actual PPI of the image and if I scale it or resize it I see an Effective PPI.
My question is, when I set the compression values does the exporter use the Actual PPI of the image or the Effective PPI once I've placed it and sized it as I want?
Tony
