CS6 Programs unstable Frequent crashes in the Apps
May 24, 2012 4:53 PM
Just purchased the Creative Cloud subscription and unless I run all the programs in Admin mode I get ferquent crashes.
Dynamic Link does not work in Premiere and I cannot even import a PSD file into Premiere unless I start the program in Admin mode.
Is their a fix?
eg When importing a PSD file into Premiere I get " Adobe Media Core CS6 has stopped working" "APPCRASH  PhotoshopServer.exe "
When sending a Premiere Sequence to Encore using Dynamic Link "Adobe Encore has stopped working" "APPCRASH Encore.exe"
Never had these issues with CS5 Master Suite.
Message was edited by: Roy Hessey
    May 24, 2012 5:00 PM   in reply to Roy Hessey
    Ideally we recommend running the softwares in the Admin mode only , because it provide the complete permission for files and folders.
    Also you haven't mentioned your OS and its hard to say , but for sure it is the permissions issue with your normal account which might be causing these issues.
    May 25, 2012 9:39 AM   in reply to Roy Hessey
    As I said earlier such issues come up because of permissions , may be your CS5 files and folders have the correct permission however CS6 files and folders don't.
    As you have Windows 7 , you may try to uninstall your CS6 , log in with the Hidden Admin account and then install the software.
    To know the steps to unhide the hidden admin account check this link :- http://www.howtogeek.com/howto/windows-vista/enable-the-hidden-adminis trator-account-on-windows-vista/
    Once you have installed the software in Admin account , login back in your normal standard account and then check.
