MenuBar control
Jun 15, 2012 12:18 PM
    Jun 15, 2012 12:18 PM   in reply to Community Help
    This code does not reder properly. ITem D-3 is rendered in place of item D-2, which is SKIPPED. Is there a fix for this?I'm using SDK 4.6
    Jun 15, 2012 12:20 PM   in reply to Claudius Tiberiu Iacob
    THAT code. This page ate my XML...
          <root>
              <menuitem label="MenuItem A" icon="myTopIcon">
                   <menuitem label="SubMenuItem A-1" enabled="False"/>
                   <menuitem label="SubMenuItem A-2"/>
              </menuitem>
              <menuitem label="MenuItem B" type="check" toggled="true"/>
              <menuitem label="MenuItem C" type="check" toggled="false" icon="myTopIcon"/>
              <menuitem type="separator"/>
              <menuitem label="MenuItem D" icon="myTopIcon">
                   <menuitem label="SubMenuItem D-1" type="radio" groupName="one">
                        <menuitem label="SubMenuItem D-2" type="radio" groupName="one">
                             <menuitem label="SubMenuItem D-3" type="radio" groupName="one" />
                        </menuitem>
                   </menuitem>
                   <menuitem label="SubMenuItem D-2" type="radio" groupName="one" toggled="true"/>
                   <menuitem label="SubMenuItem D-3" type="radio" groupName="one"/>
              </menuitem>
         </root>
    Jun 17, 2012 11:27 PM   in reply to Claudius Tiberiu Iacob
    @Claudius,
    I'm not exactly sure what you want to render, but I removed the root element, tweaked the first D-1 tag, and got the following to work:
    </menuitem>
    <menuitem label="SubMenuItem D-2" type="radio" groupName="one"/>
    </menuitem>                                <menuitem label="SubMenuItem D-2" type="radio" groupName="one" toggled="true"/>
    </menuitem>
    Randy Nielsen
    Senior Content and Community Manager
    Adobe Systems Incorporated
    Jun 18, 2012 2:01 AM   in reply to jrunrandy
    Dear jrunrandy
    Thank you for your interest in this matter.
    I isolated the issue by trimming away all unnecessary code. Have a look at the following MXML Application:
    <?xml version="1.0" encoding="utf-8"?>
    <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                                     xmlns:s="library://ns.adobe.com/flex/spark"
                                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
        <fx:Declarations>
            <fx:XML id="myData" xmlns="">
                <menu>
                    <menuitem label="Level 0" icon="myTopIcon">
                        <menuitem label="Level 1" type="radio" groupName="one">
                            <menuitem label="Level 2" type="radio" groupName="one">
                                <menuitem label="Level 3" type="radio" groupName="one" />
                            </menuitem>
                        </menuitem>
                    </menuitem>
                </menu>
             </fx:XML>
        </fx:Declarations>
         <mx:MenuBar
             dataProvider="{myData}"
             width="100%"
             labelField="@label"
             showRoot="false"/>
    </s:Application>
    IMHO, this code should render a menu resembling to this hierarchical structure:
    Level 0
        -> Level 1
                -> Level 2
                         -> Level 3
    However, the menu that is rendered resembles to this structure (also check the attached screen shot):
    Level 0
       -> Level 1
               -> Level 3
    Jun 18, 2012 2:05 AM   in reply to Claudius Tiberiu Iacob
    P.S.: Removing the type="radio" attribute does not resolve the issue.
    Thank you
    Jun 19, 2012 1:02 AM   in reply to Claudius Tiberiu Iacob
    Hi Claudius,
    OK. I see. I'm able to reproduce this. I'm not sure where to report Flex bugs these days. I suggest trying either bugs.adobe.com or the Apache Flex site.
    -Randy
