signsupplies5
cs5 Advanced Photo Album Template Live Links
Jun 12, 2012 10:58 AM
Tags: #as3 #xml #actionscript #flash_cs5
I'm using this template as a "quick & dirty" content slider for my website. I got everything to work great, there's no issues with it's functionality or actionscript. I would just like to make each image a "clickable" link. I got 4 images that I want to take users to 4 separate webpages, I've searched and searched for answers but most are over my head. Is there anybody that could help me? Here's the actions:
import fl.data.DataProvider;
import fl.events.ListEvent;
import fl.transitions.*;
import fl.controls.*;
// USER CONFIG SETTINGS =====
var secondsDelay:Number = 7;
var autoStart:Boolean = true;
var transitionOn:Boolean = true; // true, false
var transitionType:String = "Fade"; // Blinds, Fade, Fly, Iris, Photo, PixelDissolve, Rotate, Squeeze, Wipe, Zoom, Random
var hardcodedXML:String="<photos><image title='Your Choice'>image1.jpg</image><image title='Quick Option'>image2.jpg</image><image title='New Product'>image3.jpg</image><image title='Get Started'>image4.jpg</image></photos>";
// END USER CONFIG SETTINGS
// DECLARE VARIABLES AND OBJECTS =====
var imageList:XML = new XML();
var currentImageID:Number = 0;
var imageDP:DataProvider = new DataProvider();
var slideshowTimer:Timer = new Timer((secondsDelay*1000), 0);
// END DECLARATIONS
// CODE FOR HARDCODED XML =====
imageList = XML(hardcodedXML);
fl_parseImageXML(imageList);
// END CODE FOR HARDCODED XML
// EVENTS =====
imageTiles.addEventListener(ListEvent.ITEM_CLICK, fl_tileClickHandler);
function fl_tileClickHandler(evt:ListEvent):void
    imageHolder.imageLoader.source = evt.item.source;
    currentImageID = evt.item.imgID;
playPauseToggle_mc.addEventListener(MouseEvent.CLICK, fl_togglePlayPause);
function fl_togglePlayPause(evt:MouseEvent):void
    if(playPauseToggle_mc.currentLabel == "play")
        fl_startSlideShow();
        playPauseToggle_mc.gotoAndStop("pause");
    else if(playPauseToggle_mc.currentLabel == "pause")
        fl_pauseSlideShow();
        playPauseToggle_mc.gotoAndStop("play");
next_btn.addEventListener(MouseEvent.CLICK, fl_nextButtonClick);
prev_btn.addEventListener(MouseEvent.CLICK, fl_prevButtonClick);
function fl_nextButtonClick(evt:MouseEvent):void
    fl_nextSlide();
function fl_prevButtonClick(evt:MouseEvent):void
    fl_prevSlide();
slideshowTimer.addEventListener(TimerEvent.TIMER, fl_slideShowNext);
function fl_slideShowNext(evt:TimerEvent):void
    fl_nextSlide();
// END EVENTS
// FUNCTIONS AND LOGIC =====
function fl_parseImageXML(imageXML:XML):void
    var imagesNodes:XMLList = imageXML.children();
    for(var i in imagesNodes)
        var imgURL:String = imagesNodes[i];
        var imgTitle:String = imagesNodes[i].attribute("title");
        imageDP.addItem({label:imgTitle, source:imgURL, imgID:i});
    imageTiles.dataProvider = imageDP;
    imageHolder.imageLoader.source = imageDP.getItemAt(currentImageID).source;
    title_txt.text = imageDP.getItemAt(currentImageID).label;
function fl_startSlideShow():void
    slideshowTimer.start();
function fl_pauseSlideShow():void
    slideshowTimer.stop();
function fl_nextSlide():void
    currentImageID++;
    if(currentImageID >= imageDP.length)
        currentImageID = 0;
    if(transitionOn == true)
        fl_doTransition();
function fl_prevSlide():void
    currentImageID--;
    if(currentImageID < 0)
        currentImageID = imageDP.length-1;
        fl_doTransition();
function fl_doTransition():void
    if(transitionType == "Blinds")
        TransitionManager.start(imageHolder, {type:Blinds, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Fade")
        TransitionManager.start(imageHolder, {type:Fade, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Fly")
        TransitionManager.start(imageHolder, {type:Fly, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Iris")
        TransitionManager.start(imageHolder, {type:Iris, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Photo")
        TransitionManager.start(imageHolder, {type:Photo, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "PixelDissolve")
        TransitionManager.start(imageHolder, {type:PixelDissolve, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Rotate")
        TransitionManager.start(imageHolder, {type:Rotate, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Squeeze")
        TransitionManager.start(imageHolder, {type:Squeeze, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Wipe")
        TransitionManager.start(imageHolder, {type:Wipe, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Zoom")
        TransitionManager.start(imageHolder, {type:Zoom, direction:Transition.IN, duration:0.25});
    } else if (transitionType == "Random")
        var randomNumber:Number = Math.round(Math.random()*9) + 1;
        switch (randomNumber) {
            case 1:
                break;
            case 2:
                break;
            case 3:
                break;
            case 4:
                break;
            case 5:
                break;
            case 6:
                break;
            case 7:
                break;
            case 8:
                break;
            case 9:
                break;
            case 10:
                break;
    } else
        trace("error - transitionType not recognized");
if(autoStart == true)
    Jun 19, 2012 5:02 PM   in reply to signsupplies5
    Without writing the code for you, the general idea is knowing what the image number is. That seems to be your issue. Your click events need to be able to extract the name of the image that was clicked (who's instance name can have that number in it). Based on that number you can determine what to do.
    Any MouseEvent.CLICK function handlers will give you the name (if you set it) of what was clicked.
    e.g.
    import flash.display.Sprite;
    import flash.events.MouseEvent;
    var a:Sprite = new Sprite();
    a.beginFill(0xFF0000,1);
    a.graphics.drawRect(0,0,100,100); // draw red rectangle
    a.graphics.endFill();
    addChild(a);
    // give it a name
    a.name = "a_1";
    a.addEventListener(MouseEvent.CLICK, handleClick);
    // Now on a click, extract the name and use it:
    function handleClick(e:MouseEvent):void
         // what button was clicked?
         trace(e.target.name);
         // get the number
         var num:int = int(e.target.name.toString().split('_')[1]);
         trace("Button #" + num + " clicked");
         // do something based on the number
         if (num == 1)
              // do something based on button 1
         else if (num == 2)
              // do something based on button 2
         // etc...
