solab95
Dreamweaver cs6 php variable code hints not working
Jun 15, 2012 7:56 AM
Tags: #dreamweaver #cs6 #code_hints
Im new to dreamweaver cs6, and one thing i loved about cs5 was that when i typed '$' it would instantly give me a selection of variables that i had used in my page already or variables included in php ($_POST, $_SESSION, $_REQUEST...), however, now when i type '$' i only get a list of variables i already used and sometimes it is incorrect, for example if i used $_SESSION['valid'] then the code hint would be $_SESSION.
I already checked my prefrences for code hints and i have everything is checked.
So anyway my question is how to enable these types of code hints.
Thanks for your help,
solab95
    Jun 17, 2012 8:52 PM   in reply to solab95
    I'm having the exact same problem.
    Jun 18, 2012 9:40 AM   in reply to solab95
    me 2, i am having the same problem. hey solab by any chance did you resolve the issue?
    Jun 21, 2012 6:29 AM   in reply to solab95
    hi, in preferences->code hints disable jquery code 1.7 and it works.
    Jun 21, 2012 7:02 AM   in reply to freelancerphp
    really i will def. try that later, but i guess adobe has to fix that, what happens if you code php and jquery.... thanks alot though  big hlep
    Jun 22, 2012 7:20 PM   in reply to hectoru
    That's my case... I can't disable jQuery hints, I need them.
    I went back to CS5.5, this problem plus the CPU consumption are enough.
    Nov 9, 2012 12:16 PM   in reply to solab95
    The jquery 1.7 disableing did the trick, thank you that problem was driving me crazy!!!!
    Jan 17, 2013 10:15 AM   in reply to solab95
    the solution proposed here is really not a sollution because that way you're loosing jQuery hints which i find very usefull TOO.
    instead what i do is this (and i get used to do this since it's usefull):
    • after you start CS6 press ctrl-u (prefferences)
    • select code hints
    • move 'delay' slide to some other position
    • click OK
    • do the same but set 'delay' to 0
    and that's it. i know it's borring for most of you but when i start CS6 once i leave it open all day long anyway
    hope this was helpfull...
    Aug 14, 2013 3:08 PM   in reply to zazho
    Still not working
    Dec 10, 2013 12:28 AM   in reply to yocat13
    it kind of worked when i turned of jquery hints off from the preferences to my surpise i found it working even when i again enabled the jquery hint..  both jquery and php hinting seemd to work fine then.. only problem is u have to do it all the time u restart dreamweaver..
