bite-rate calculate
Jun 13, 2012 2:28 AM
is this possible to calculate playing video bite-rate through as3 ?
  • kglad
    Jul 21, 2002
    Jun 13, 2012 6:12 AM   in reply to Venkom
    the bitrate is a property of an event object received by the metadataevent.  so, you can just "read" it by listening for the metadataevent.
  • kglad
    Jul 21, 2002
    Jun 15, 2012 6:40 AM   in reply to Venkom
    that's not the bitrate.  you want to determine the download rate.
    for that use:
    var previouslyExecuted:Boolean;
    if(!previouslyExecuted){
    previouslyExecuted=true;
    var totalKb:Number;
    var previousTotalKb:Number=0;
    var myInterval:uint;
    function videoInfo():void
              totalKb = ((ns.info.byteCount* 8) / 1024);
              trace (totalKb-previousTotalKb);
    previousTotalKb=totalKb
    clearInterval(myInterval);
    myInterval = setInterval (videoInfo, 10000);
  • kglad
    Jul 21, 2002
    Jun 17, 2012 6:37 AM   in reply to Venkom
    you're welcome.
    p.s.  if you also want the bitrate, use the metadataevent.  exactly how you do that depends on whether you're using netstream or an flvplayback component.
  • kglad
    Jul 21, 2002
    Jun 19, 2012 11:36 AM   in reply to Venkom
    if you want to send totalKB-previousTotalKb to your js function use:
              totalKB = ((ns.info.byteCount* 8)/1024);
              trace (totalKB - previousTotalKb);
    flash.external.ExternalInterface.call("sendToJS", totalKB-previousTotalKb);
              previousTotalKb = totalKB;
    myInterval = setInterval(videoInfo, 10000);
