oyson
LMS registers a completed demo as "in progress"
Jun 18, 2012 3:09 AM
Tags: #complete #quiz #lms #incomplete
HI everyone,
I’m an experienced Captivate user, but I’m making my first LMS project.
I need to have a user click on a button at the end of a demo.
The purpose is that this action should be reported as complete in our LMS (cornerstone on demand).
We’ve tested it with our LMS and even though a user has completed the demo by clicking the button at the end of the slide, the LMS still reports it as “in progress.”
My questions are:
  1. What do I need to do in order to make it work?
  2. Does an LMS need to be setup or configured in a certain way so that it can receive the correct data?
I’ve created one slide containing an interactive object (a button). The action on success is: continue
I have also selected the following settings under Quiz:
Settings, Pass or Fail and Default Labels have not been changed.
Output settings are:
I’d be more than happy to send the source file if it will help.
If you need more information, please let me know.
The project was initially developed using Captivate 5.5 and published in Captivate 6.
Looking forward to a reply!
Salvador
    Jun 18, 2012 3:51 AM   in reply to oyson
    Can you please share your source file and mail me the link at vandana @ adobe dot com.
    Jun 18, 2012 3:11 PM   in reply to oyson
    You've got 'slide views' and '100%' checked, so to get a 'completed' status, your users will have to view every slide *through to completion* - so you can't just click Next quickly and go past screens without waiting for them to reach the end. Your button, weights, etc shouldn't have any effect with that slide views setting...
    Jun 19, 2012 6:55 AM   in reply to oyson
    You want the lesson marked 'completed' when the user has viewed all slides...correct?
    So when you try this, are you absolutely letting ever slide play through to the end? So you are absolutely viewing every slide in the project entirely?
    And the result is still 'in progress'?
    What's the purpose of the button at the end? Some sort of acknowledgement...?
    Perhaps you want to set that button as 'scored' with a weight of 1, then change the User Access area to 'Quiz' instead of 'Slide Views', then check the Quiz section and be sure it's set to 100%...but then you have to make sure there is only one scored interaction...which would be that button at the end.
    Try that?
    Jun 19, 2012 8:56 AM   in reply to oyson
    The best way to be sure is just to test it in the LMS. SCORM is an inexact spec and differences between how LMS products interpret it can mean different settings are required. Generally, your settings look good to me (though I don't think, in your case, the 'show score' and 'allow user to review' options are necessary) but you really just need to publish and test in the LMS to see how it responds.
    Hope that helps!
    Jun 20, 2012 1:50 AM   in reply to oyson
    Hi Salvador,
    Perhaps your file got blocked. I have not recieved it. Can you please upload the file at acrobat.com and share it with me.
    I tried with a simple 2 slide course with a button on last slide, and I got 'complete' status. Therefore, would like to verify with your course.
    Vandana
