I'm trying to change a swap image behavior so it fades when I click a word. Tutorials show "effects" option which would do what I want but I use Dreamweaver 8 and I don't seem to have the effects option in my behaviors panel. Am I missing something?
JQuery is supposed to be 'simple' but I'm afraid I'm the simple one and can't seem to adapt it to what I want to do.
Suggestions welcome.
And when should one use <A>onMouseout instead of onMouseout?
jQuery is worth knowing how to use. Very versatile and pretty easy to implement once you understand the basics.
The demo below uses jQuery fadeTo on CSS Disjointed Rollovers.
http://alt-web.com/DEMOS/jQuery-Disjointed-Image-Gallery.shtml
Nancy O.
It looks simple but I guess I'm the simple one becaue I can't adapt the code to do what I want.
I have an image(1). I want it to fade into another image(2) which is the exact same size. It could be either a mouseOver/mouseOut or a click on some text or an image(3) or even image(1). I was hoping for a simple method to do this without having to buy a new DW. I have DW8 and there are no built-in menu choices to do this. I believe CS3 can do this in the behavior panel.
Maybe using CSS opacity on image(2) to reveal underlying image(1) placed in a layer I suppose.
JQuery is clearly able to do it but even the basic tutorials assume too much in my case. :-(
It looks simple but I guess I'm the simple one because I can't adapt the code to do what I want.
Let's see your test page.
CS3 is long gone. The current DW release is CS6 which contains a bevy of new features including CSS Transitions.
http://tv.adobe.com/watch/digital-design-cs6/creating-css-transitions- in-dreamweaver-cs6/
Nancy O.
Thanks Nancy,
(The link wouldn't play with Safari or Firefox)
I've made some progress by trial and mostly error http://dinghydogs.com/indexJQuery.html The central images work with mouseOver on my desktop. I uploaded everything I edited so I have no explanation for the images not showing.
(PS. found out what was wrong. I named the images index......jpg. and apparently that's a no no.)
Many puzzles: The layers didn't line up when I did it manually or by the numbers (top and left). I had to move them with the arrow keys and try over and over in the browser until they lined up.
I still don't know how to make the same fade effect using text.
Message was edited by: harvey waxman
Thanks, but my main concern is for the divs that have only images, the two in the center of the page. What and how would you suggest I change?
Also, might you have an explanation of why I can't change the duration of the fade? I tried changing the '1000' in the JQuery functions:
$(this).stop().animate({opacity: "0.0"}, '1000'); but it made no difference at all.
@Harvey,
You don't need .animate for this. Try copying & pasting code below into a new, blank document.
@Ken,
I'm using APDiv layers for the disjointed rollovers. Normally I don't use APDivs except in special situations like this.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>CSS Rollovers with jQuery fade</title>
<!--link to latest jQuery core library-->
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js">
</script>
<style type="text/css">
/**BEGIN DISJOINTED IMAGE ROLLOVERS**/
#rollover {
position:relative;
margin-left: 550px;
margin-top: 300px;
width: 250px;
border: 1px solid silver;
#rollover ul li {list-style:none}
#rollover li a {color: #000}
#rollover a:hover {color:#C00;}
/**images**/
#rollover span {
display:none;
position: absolute;
/**adjust position of images**/
left: 40px;
top: -125px;
/**optional image captions**/
font-size: 12px;
line-height: 1.2;
color:#666;
text-align: center;
/**Click on links text**/
#rollover h4 {
position: absolute;
/**adjust position**/
left: 40px;
top: -120px;
/**style text**/
font-size: 14px;
letter-spacing:-1px;
width: 100px;
/**END DISJOINTED ROLLOVER STYLES**/
</style>
</head>
<body>
<!--begin disjointed rollovers. Change images and captions to your own.-->
<div id="rollover">
<h4>Click links below for details:</h4>
<ul>
<li><a href="#">Some link</a><span><img src="Image1.jpg" alt=" " /><br />optional caption #1</span></li>
<li><a href="#">Some link</a><span><img src="Image2.jpg" alt=" " /><br />optional caption #2</span></li>
<li><a href="#">Some link</a><span><img src="Image3.jpg" alt=" " /><br />optional caption #3</span></li>
<li><a href="#">Some link</a><span><img src="Image4.jpg" alt=" " /><br />optional caption #4</span></li>
</ul>
<!--end #rollovers --></div>
<!--jQuery fade function, put this above the end of body tag-->
<script type="text/javascript">
$(document).ready(function(){
$("#rollover a").hover (function(){
$(this).next("span").fadeTo("slow", 1.00);
},function(){
$("#rollover span").fadeTo("normal", 0.00);
</script>
</body>
</html>
Nancy O.
Hi Nancy,
I really appreciate all your efforts but this didn't come close to what I was looking for and exhibited some bizarre effects to boot. Maybe due to my version of DW. I won't take up the time of the group explaining what happened but I had seen it before with other scripts copied from different sites.
Thanks again.
