mbentz
onload popped up add
Jun 18, 2012 4:02 PM
how do I make an semi transparent onload popped up add/form like here : http://www.anthropologie.com/anthro/index.jsp
    Jun 18, 2012 4:16 PM   in reply to mbentz
    You could do this with FancyBox (a jQuery plugin).
    http://fancybox.net/blog
    Then style your Fancybox window with CSS opacity.
    http://www.w3schools.com/css/css_image_transparency.asp
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    Jun 19, 2012 10:24 AM   in reply to mbentz
    Tip #5 in the link I posted suggests using a manual call like this one:
    <script type="text/javascript">
    jQuery(document).ready(function() {
        $.fancybox(
            '<h2>Hi!</h2><p>Your custom message here...</p><p>Lorem ipsum dolor sit amet, consectetur adipiscing elit. Etiam quis mi eu elit tempor facilisis et neque</p>',
    'autoDimensions'  : false,
    'width'           : 400,
    'height'          : 'auto',
    'transitionIn'  : 'elastic',
    'transitionOut' : 'elastic',
    'overlayOpacity' : 0.8,
    'speedIn'        :  600,
    'speedOut'     : 400,
    'overlayColor' : '#FFF'
    </script>
    Nancy O.
    Jun 19, 2012 11:18 AM   in reply to mbentz
    Download Fancybox and extract it to your local site folder.
    This link tells how to use it.
    http://fancybox.net/howto
    These links go between the <head> and </head> tags in your HTML document
    <!--jQuery core library-->
    <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4/jquery.min.js"></script>
    <!--fancybox script-->
    <script type="text/javascript" src="/fancybox/jquery.fancybox-1.3.4.pack.js"></script>
    <!--optional easing script-->
    <script type="text/javascript" src="/fancybox/jquery.easing-1.4.pack.js"></script>
    <!--fancybox CSS-->
    <link rel="stylesheet" href="/fancybox/jquery.fancybox-1.3.4.css" type="text/css" media="screen" />
    The function code to invoke fancybox on page load goes above the end of </body> tag.
    <!--fancybox function-->
        $.fancybox(
    'width'           : 400,
    'height'          : 'auto',
    'speedIn'        :  600,
    'speedOut'     : 400,
    </script>
    Nancy O.
    Jun 19, 2012 1:28 PM   in reply to mbentz
    File > New > blank HTML page.
    Follow the instructions I gave you.
    Upload your test page and Fancybox folder to your server.
    If Fancybox box doesn't invoke on page load, come back & post the URL to your test page so we can look at it.
    Nancy O.
    Jun 19, 2012 2:19 PM   in reply to mbentz
    No fancybox folder found on server.
    http://www.zengerfolkman.com/fancybox/
    You need to upload the fancybox folder  to your server for this to work.
    When you do that, let me know and we'll check the paths.
    Nancy O.
    Jun 19, 2012 2:22 PM   in reply to mbentz
    That code points to http://www.zengerfolkman.com/fancybox/jquery.fancybox-1.3.4.pack.js = File Not Found
    You need to upload the Fancybox folder to the server. That's where the scripts live which drive Fancybox.
    If the server cannot find the folder containing the scripts then the browser ignores the code in your page and nothing happens.
    Jun 19, 2012 2:42 PM   in reply to mbentz
    Hurray!  Now do the same thing with your other document.
    Put scripts and CSS links inside the <head> tags after <title>.
    Put the function code in the <body> right above the </body> tag.
    Nancy O.
