KWExpress
General lighting on a layer
Jun 19, 2012 11:51 AM
Tags: #photoshop #cs3 #layer #layers
Running Photoshop CS3 ( Yes, I know I should be shot for using an old version...) and I have a photo of our ferry boat, that I use and place as a layer in our advertising.  The image has a bluish tint, due to the surrounding water.  On the boat we do have some decals/paintings (of course they are blue also....).
How can I get the white portions of the boat to be whiter, while leaving the other elements the same?
Thank you very much, in advance.
    Jun 19, 2012 3:10 PM   in reply to KWExpress
    Hi KWExpress
    I can't say if this method is the best for you since I can't see the image. You could try using the magic wand tool. Uncheck contiguous in the settings on the top and select all the white portions of the boat. You may need to adjust your selection. While having the selection, adjust the levels in the adjustments panel to get the desired result. If this approach does not work for you, please post the photo that you are trying  to edit here so everyone can understand what you are trying to achieve.
    -Sharon
  • Trevor.Dennis
    May 24, 2010
    Jun 19, 2012 3:16 PM   in reply to Sharon Huang
    Better to use a Hue/Saturation adjustment layer, and target the problem colours.  If those are the Blues, then use the RGB drop-down and select Blue, and desaturate it.  If it leaves an area with an inapropriate tonal value (a band that is too bright or dark) also adjust the Lightness slider.  Use the layer mask to keep the effect to where you want it.
    I have a feeling that CS3 does not support scrubby sliders in its Hue/Saturation adjustment layers. but if there is a little pointy finger icon in the top left corner, then you can click on that, and then on the image, to target the colours causing you a problem.
  • PECourtejoie
    Jan 11, 2006
    Jun 20, 2012 2:49 AM   in reply to Trevor.Dennis
    Trevor, Scrubby Sliders is the term used when you get to adjust values of a field by hovering on its title, and when you get that hand surrounded with arrows, or when you CTRL+hover on a numerical field.
    the term you want is Targeted Adjustment Tool, I think. (Sorry for the schooling, but as you are one of the big responders, using the correct terminology is important)
    KWE, you could try to neutralize the color of the white using the eyedropper in Levels (especially if there is a shadow on the boat)
    Letting us see even part of the image might be useful.
    Selective color has a white option in its drop down.
  • Trevor.Dennis
    May 24, 2010
    Jun 20, 2012 3:22 AM   in reply to PECourtejoie
    Thanks for the heads up Pierre.  I am not the only person using the wrong term though, but I'll know next time.
  • PECourtejoie
    Jan 11, 2006
    Jun 20, 2012 7:21 AM   in reply to Trevor.Dennis
    You'll be able to spread the word!
