Hello, I am making a whiteboard math app. The program has a whiteboard in the middle and the top and bottom of the program have a bar that will have various buttons and text fields for displaying the question, entering an answer, help, and the person's score. I have pretty much everything working how I want it except that the "pen" for the whiteboard writes all over the top and bottom bars, buttons, text fields, etc. How do I stop this? The top and botttom bars are movie clips named "top" and "bottom" if that helps.
Here is the code:
import flash.display.MovieClip;
import flash.events.MouseEvent;
var lines:MovieClip;
var isMoving:Boolean = false;
var linesColor:Number = 0x000000;
var linesSize:uint = 1;
var equations:Array = new Array;
var equationsAnswers:Array = new Array;
var score:uint = 0;
var questionsAsked:uint = 0;
var answer:String = new String;
equations = ["x + 7 = 13", "x - 8 = 23"];
equationsAnswers = ["6", "31"];
lines = new MovieClip();
stage.addEventListener(MouseEvent.MOUSE_DOWN, startLines);
stage.addEventListener(MouseEvent.MOUSE_MOVE, drawLines);
stage.addEventListener(MouseEvent.MOUSE_UP, stopLines);
checkbtn.addEventListener(MouseEvent.CLICK, newquestion);
stage.addChild(lines);
function startLines(e:MouseEvent) : void {
isMoving = true;
lines.graphics.lineStyle(linesSize, linesColor, 1.0);
lines.graphics.moveTo(mouseX, mouseY);
function drawLines(e:MouseEvent):void {
if (isMoving){
lines.graphics.lineTo(mouseX, mouseY);
function stopLines(e:MouseEvent):void {
isMoving = false;
function newquestion(e:MouseEvent):void {
answer = inputAnswer.text;
if (answer == equationsAnswers[questionsAsked]){
score ++;
questionsAsked++;
scoreshow.text = score + ":" + questionsAsked;
question.text = equations[questionsAsked];
inputAnswer.text = "";
Any help would be very appreciated!
Thank you again. However, when I do this, it won't draw anywhere. I put a new movie clip on the stage with an instance name of whiteboardMask. Then, I put the code, changing it to whiteboardMask instead of maskWhiteboard. Now, when I test it, it will not draw anywhere.
var score:uint = 0;
var drawable:MovieClip = new MovieClip;
drawable.addChild(lines);
drawable.mask=whiteboardMask;
isMoving = true;
if (isMoving){
isMoving = false;
score ++;
questionsAsked++;
Any help would be appreciated.
stage.addChild(drawable);
you need add to the stage the Movieclip named drawable
var score:uint=0;
var questionsAsked:uint=0;
var answer:String=new String();
var drawable:MovieClip=new MovieClip();
equations=["x + 7 = 13","x - 8 = 23"];
equationsAnswers=["6","31"];
function startLines(e:MouseEvent):void {
isMoving=true;
if (isMoving) {
isMoving=false;
answer=inputAnswer.text;
if (answer == equationsAnswers[questionsAsked]) {
score++;
questionsAsked++;
scoreshow.text=score+":"+questionsAsked;
question.text=equations[questionsAsked];
inputAnswer.text="";
