adobeisavirus
flash player exe's still running after install green videos or crashing browser when using flash
Jun 15, 2012 5:42 PM
Tags: #help #flash #install #player #failed #flash_player #installation #install_failed #flashplayer #flash_player_11 #adobe_download_assistant
my task manager shows flashutil32_11_3_300_257_activex.exe still running.
fresh install of winfdows732bit first install of flash went bad. or didnt work, like usual.
now when i go to youtube or hulu or other video sites the videos are green/garbled or nonfunctioning/crashing the browser.
hulu is paid for me so if i cant fix trash player i got to cancel my hulu.
tried opera with alternative trashplayer.
uninstalled a number of times, downloaded adobes uninstaller.
reinstalled.
uninstalled
deleted macomed folders reinstalled, uninstalled.
tried 11.2.xxxx but it installed 11.3
attached is a picture of my problems with adobe.
this is a fresh install!!!!! should NOT be having this!!!!!!!
    Jun 15, 2012 5:50 PM   in reply to adobeisavirus
    What is your display adapter, device driver & date?
    Most likely all your problems are caused by an outdated driver version.
    Jun 15, 2012 9:42 PM   in reply to adobeisavirus
    Did you install the driver that was released this week (v296.88, 2012.06.13)?
    Jun 16, 2012 7:40 PM   in reply to adobeisavirus
    Can you file a bug report with all relevant information at https://bugbase.adobe.com/ and post the bug number or bug URL back here at the forum?
    Jun 17, 2012 8:25 AM   in reply to adobeisavirus
    Guys,
    I'm  having the same problem!
    Most of the videos appear with large green and red areas (as in the image)Untitled-1.jpg that make the vision almost impossible.It happens either with Firefox, Chrome or Explorer, but other video formats work fine, so I understand is a Flash player problem. Every now and then the flash player crashes too.
    I've tried to uninstall and reinstall the 11.3 player and finally installed the 11.2 version back and the problems disappeared, but I can't see a lot of stuff, as they require the latest version.
    What should I do?
    Jun 17, 2012 6:04 PM   in reply to sellino
    Please post your display adapter information; see http://forums.adobe.com/thread/945765
    Jun 18, 2012 3:22 AM   in reply to Pat Willener
    Hey Pat,
    I have the NVIDIA Quadro FX 570M, driver version: 8.17.12.9683, driver date: 18-May-12.
    Do you need some other info?
    Jun 18, 2012 8:13 PM   in reply to sellino
    That is quite a new driver; still, can you go to http://www.nvidia.com/Download/Scan.aspx and check if a newer driver is available?  The scanning tool works best on Internet Explorer; I have never been able to run it on Firefox.
    Jun 19, 2012 3:41 AM   in reply to Pat Willener
    Pat,
    I've done that and found out that I have the latest driver version...
    What should I do now?
    Jun 19, 2012 5:43 PM   in reply to sellino
    Can you file a bug report at https://bugbase.adobe.com/ and post the bug number / URL back here?
    Jun 23, 2012 9:35 PM   in reply to Pat Willener
    Just done it:
    Bug#  3222077
    So now how much time should I wait to get my problem solved?
