Help with a whiteboard!
Jun 19, 2012 4:02 PM
Tags: #problem #actionscript3 #whiteboard #swapchildren
Hello, I am making a whiteboard math app.  The program has a whiteboard in the middle and the top and bottom of the program have a bar that will have various buttons and text fields for displaying the question, entering an answer, help, and the person's score.  I have pretty much everything working how I want it except that the "pen" for the whiteboard writes all over the top and bottom bars, buttons, text fields, etc.  How do I stop this?  The top and botttom bars are movie clips named "top" and "bottom" if that helps.
Here is the code:
import flash.display.MovieClip;
import flash.events.MouseEvent;
var lines:MovieClip;
var isMoving:Boolean = false;
var linesColor:Number = 0x000000;
var linesSize:uint = 1;
var equations:Array = new Array;
var equationsAnswers:Array = new Array;
var score:uint = 0;
var questionsAsked:uint = 0;
var answer:String = new String;
equations = ["x + 7 = 13", "x - 8 = 23"];
equationsAnswers = ["6", "31"];
lines = new MovieClip();
stage.addEventListener(MouseEvent.MOUSE_DOWN, startLines);
stage.addEventListener(MouseEvent.MOUSE_MOVE, drawLines);
stage.addEventListener(MouseEvent.MOUSE_UP, stopLines);
checkbtn.addEventListener(MouseEvent.CLICK, newquestion);
stage.addChild(lines);
function startLines(e:MouseEvent) : void {
    isMoving = true;
    lines.graphics.lineStyle(linesSize, linesColor, 1.0);
    lines.graphics.moveTo(mouseX, mouseY);
function drawLines(e:MouseEvent):void {
    if (isMoving){
        lines.graphics.lineTo(mouseX, mouseY);
function stopLines(e:MouseEvent):void {
    isMoving = false;
function newquestion(e:MouseEvent):void {
    answer = inputAnswer.text;
    if (answer == equationsAnswers[questionsAsked]){
        score ++;
    questionsAsked++;
    scoreshow.text = score + ":" + questionsAsked;
    question.text = equations[questionsAsked];
    inputAnswer.text = "";
Any help would be very appreciated!
    Jun 19, 2012 4:09 PM   in reply to jerm8352
    Ypu can create a MovieClip to get inside the "lines" an the use a mask to show only the "drawable" area
    var drawable:MovieClip=new MovieClip();
    drawable.addChild(lines);
    drawable.mask=maskWhiteboard
    (maskWhiteboard is other Movie Clip)
    Jun 20, 2012 7:50 AM   in reply to jerm8352
    maskWhiteboard is a movieclip that you create with the size and shape of the area where you can draw, excluding your buttons
    Jun 20, 2012 11:21 AM   in reply to jerm8352
    stage.addChild(drawable);
    you need add to the stage the Movieclip named drawable
    var score:uint=0;
    var questionsAsked:uint=0;
    var answer:String=new String();
    equations=["x + 7 = 13","x - 8 = 23"];
    equationsAnswers=["6","31"];
    drawable.mask=whiteboardMask;
    function startLines(e:MouseEvent):void {
        isMoving=true;
        if (isMoving) {
        isMoving=false;
        answer=inputAnswer.text;
        if (answer == equationsAnswers[questionsAsked]) {
            score++;
        questionsAsked++;
        scoreshow.text=score+":"+questionsAsked;
        question.text=equations[questionsAsked];
        inputAnswer.text="";
    Jun 20, 2012 1:20 PM   in reply to jerm8352
    you're welcome
    It's just a detail that went unnoticed
    Jun 27, 2012 3:17 PM   in reply to jerm8352
    Jun 27, 2012 3:52 PM   in reply to jerm8352
    do not worry sometimes happens
