Rilyera
Flash line weight with line/pen tool
Jun 19, 2012 2:18 AM
Tags: #help #flash_cs5.5 #animation
Hello everyone,
I'm starting work on an animation project where I want very straight, vector lines, not something drawn by the brush/pencil tool or things like that which are normally used in Flash animations. What I was wondering is, is there a way to smoothly transition between line weights between 2 points?
For example, can I set point A to a line weight/thickness of 1, then set point B to a weight of 2, and have the thickness smoothly transition between the two different weights? I can't find any way of changing it during the creation process, nor can I find a way to change it afterwards.
Thanks.
    Jun 19, 2012 11:39 AM   in reply to Rilyera
    That's a really amazing question.
    if you mean by transition in animation your best bet is not to use lines but to use fills it would be a lot easier.
    by the way if you want to explore learning more indepth how to draw by code here i have training on that on my site but i think in your case your best bet is to more micro doing it with fills.
    flash isn't a super hero when it comes to being very accurate when it comes down to into the pixel level animations flash is great when animatiing in perfect pixels so a jump from 1 point to 2 points works great but animating between pixels is a real chalange there are ways around it but there really complex such as using bitmap data instead but i wouldn't go that path unless your comfterble going deep into development for it. - i hope someone else comes up with a better tip.
    Jun 20, 2012 6:52 AM   in reply to Rilyera
    ha aman you don't need AS for that you will find as more complicated for something like this!
    i think your right on with what you are doing i think the pen tool is probably your best bet or if you enjoy doing the art in other tools you can always import it into flash if the creative tools on Ilustrator or other tool work better to you flash is really good with importing art as long as you don't need to animate the actual art that might be easier.
