nilamk
Native Drag Drop
Feb 10, 2012 5:26 AM
I have used the following event and respective event handler in canvas.
nativeDragEnter="canvas1_nativeDragEnterHandler(event)"
nativeDragExit="canvas1_nativeDragExitHandler(event)"
nativeDragDrop="canvas1_nativeDragDropHandler(event)"
nativeDragComplete="canvas1_nativeDragCompleteHandler(event)"
It gives type error like
TypeError: Error #1034: Type Coercion failed: cannot convert mx.events::DragEvent@18b51741 to mx.events.DragEvent.
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/dispatchEvent()[C:\autobuild\3.4.0\frameworks\pr ojects\framework\src\mx\core\UIComponent.as:9408]
at mx.managers::NativeDragManagerImpl/_dispatchDragEvent()[C:\autobuild\ galaga\frameworks\projects\airframework\src\mx\managers\NativeDragMana gerImpl.as:625]
at mx.managers::NativeDragManagerImpl/nativeDragEventHandler()[C:\autobu ild\galaga\frameworks\projects\airframework\src\mx\managers\NativeDrag ManagerImpl.as:598]
    Apr 6, 2012 6:31 AM   in reply to nilamk
    It seems to be a Creative Suite sdk bug.
    You won't this exception raised anymore, if you're running your extension in release mode.
    This workaround is pretty creepy.
    Still waiting for Adobe to fix that bug.
    Jun 20, 2012 12:01 AM   in reply to nilamk
    I am too facing same problem, i didn't used DragEvent anywere in my code instead used NativeDragEvent, any updates on this  please...
    Jun 20, 2012 12:28 AM   in reply to charanseeram
    It's an issue with the CS SDK. You cannot debug drag events. I works fine in as a release build, but debugging drag and drop is a drag...
    Jun 20, 2012 12:36 AM   in reply to Harbs.
    thanks Harbs, inDesign plugin dev is  new to me, now uisng trace() instead debuging , but does inDesing follow any other lib's to achive drag drop feacility instead of NativeDragEvents  of flex sdk 3.4?,  coz i have to " d n d " mutiple files at a time on to inDesign document from my plugin application, (idms/indd/indt/images/textfiles) ..thanks in advance
    Jun 22, 2012 5:27 AM   in reply to nilamk
    nativeDragDrop is not working on to  inDesing when i drop the collected items , can some one suggest the best way, can i handle this using NativeDragComplete handler ??, NativeDragComplete is working but how  can i  bring this selected source  items in to  this handler ...
    Jun 22, 2012 5:30 AM   in reply to charanseeram
    You need to use File objects.
    Harbs
