PLEASE HELP! Adobe CS6 Master Collection Trial is failing to initialize.
Jun 19, 2012 11:46 PM
Tags: #creative #fail #6 #collection #cs6 #installation #initialize
I have downloaded CS6 Trial three times now so it is not a corrupt download. Everytime I go to run the software it says "We've encountered the following issues. Installer failed to initialize. Please download Adobe Support Advisor to detect the problem." So I downloaded it but it says there is nothing wrong!
In the log file I get this:
Wed Jun 20 14:34:49 2012[INFO] Setup - =================  Exiting Installer with Code: 0  =================
Wed Jun 20 14:34:49 2012[INFO] PIM - PIMSqlite closeDB status 0
Wed Jun 20 14:34:49 2012[INFO] PIM - FREE PIM Instance ...
Wed Jun 20 14:34:56 2012[INFO] Setup - Build Version - 6.0.335.0
Wed Jun 20 14:34:56 2012[INFO] Setup - Logging Level verbosity Set  to 4
Wed Jun 20 14:34:56 2012[INFO] Setup - TimeLog: Bootstrapper Start
Wed Jun 20 14:34:56 2012[INFO] Setup - TimeLog: Start initial checks
Wed Jun 20 14:34:56 2012[INFO] Setup - Launch Path set to /Volumes/CS6 MstrColl/Adobe CS6 Master Collection
Wed Jun 20 14:34:56 2012[INFO] Setup - Found 6 packages in setup manifest
Wed Jun 20 14:34:56 2012[INFO] PIM - Build Version - 6.0.335.0
Wed Jun 20 14:34:56 2012[INFO] PIM - Logging Level verbosity Set  to 4
Wed Jun 20 14:34:56 2012[INFO] PIM - CREATE PIM Instance ...
Wed Jun 20 14:34:56 2012[INFO] PIM - trying to createOrUpdatePIMDbSchema.
Wed Jun 20 14:34:56 2012[INFO] PIM - SUCCESS Created Tables.
Wed Jun 20 14:34:56 2012[INFO] PIM - PIM Database is Up To Date.
Wed Jun 20 14:34:56 2012[INFO] PIM - Updater Inventory location:/Volumes/CS6 MstrColl/Adobe CS6 Master Collection/Install.app/Contents/Frameworks/UpdaterInventory.framework /UpdaterInventory
Wed Jun 20 14:34:56 2012[INFO] PIM - Current db schema version on machine 1.
Wed Jun 20 14:34:56 2012[INFO] PIM - Current db schema version to install 1.
Wed Jun 20 14:34:56 2012[INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
Wed Jun 20 14:34:56 2012[INFO] PIM - PackageCheck: Package id DF1EA1EE-7B19-4CC4-8950-BEB6D7F70191 is a New Package, one installed on the system is old. Size required: 49365843
Wed Jun 20 14:34:56 2012[INFO] PIM - PackageCheck: Package id 36C746D4-D32C-422A-9B0F-F3719DAA3DF8 is a New Package, one installed on the system is old. Size required: 2889421
Wed Jun 20 14:34:56 2012[INFO] PIM - PackageCheck: Package id 5C2E838A-E0AD-4727-B8FD-54DA0C7A6FBB is a New Package, one installed on the system is old. Size required: 15633430
Wed Jun 20 14:34:56 2012[INFO] PIM - PackageCheck: Package id B5032FD8-3CFB-4FA1-9051-811EB16A189B is a New Package, one installed on the system is old. Size required: 4237309
Wed Jun 20 14:34:57 2012[INFO] PIM - PackageCheck: Package id 59792158-B2AE-4670-8F68-EB7DE9535F3D is a New Package, one installed on the system is old. Size required: 13952220
Wed Jun 20 14:34:57 2012[INFO] PIM - PackageCheck: Package id 7EF4FA31-DD11-4D7E-A9D0-7C1526746C65 is a New Package, one installed on the system is old. Size required: 16135843
Wed Jun 20 14:34:57 2012[INFO] PIM - PackageCheck: Package id F07FC360-0D5A-46FA-97FE-D317850ECBFF is a New Package, one installed on the system is old. Size required: 22302498
Wed Jun 20 14:34:57 2012[INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 136968220
Wed Jun 20 14:34:57 2012[INFO] PIM - freeDiskSpace ... 171341668352
Wed Jun 20 14:34:57 2012[INFO] Setup - TimeLog: End initial checks
Wed Jun 20 14:34:57 2012[INFO] Setup - TimeLog: Begin Installing
Wed Jun 20 14:34:57 2012[INFO] PIM - START installPackage at file /Volumes/CS6 MstrColl/Adobe CS6 Master Collection/packages/core/PDApp.pimx
Wed Jun 20 14:34:57 2012[INFO] PIM - Validating package file: '/Volumes/CS6 MstrColl/Adobe CS6 Master Collection/packages/core/PDApp.pimx'
Wed Jun 20 14:34:57 2012[INFO] PIM - Validating package file: '/Volumes/CS6 MstrColl/Adobe CS6 Master Collection/packages/core/PDApp.pima'
Wed Jun 20 14:34:57 2012[INFO] PIM - SUCCESS insertPackageUpdateList.
Wed Jun 20 14:34:57 2012[INFO] PIM - SUCCESS insertAppletRegInfoList.
Wed Jun 20 14:34:59 2012[INFO] PIM - NOTE Failed to mount the package dmg. checking if already mounted...
Wed Jun 20 14:34:59 2012[FATAL] PIM - Error Failed to mount the package dmg.
Wed Jun 20 14:34:59 2012[FATAL] PIM - Error Failed to extract assets...
Wed Jun 20 14:34:59 2012[FATAL] Setup - Error installing core /Volumes/CS6 MstrColl/Adobe CS6 Master Collection/packages/core/PDApp.pimx package. pim_installPackage returned -8
Wed Jun 20 14:34:59 2012[FATAL] Setup - Error installing Packages.
What do I do???
    Jun 20, 2012 12:23 AM   in reply to joel.t
    Check this for some guidance: Troubleshoot error messages | Bootstrapper
    Mylenium
    Jun 20, 2012 1:22 AM   in reply to joel.t
    Restart in the Safe mode and then try and install the software.
    Find the link to restart the machine in the Safe Mode :- http://helpx.adobe.com/x-productkb/global/start-safe-boot-mode-mac.htm l
