MarianoHonradoJr
Making a snapshot as the clone source
Jun 20, 2012 1:15 AM
I'm struggling in Photoshop with a large number of scanned B/W photos from the '50s and '60s with wide areas of dust and scratches. Dreading the prospect of tedious cloning or healing, I googled for "Dustbusting 101 in Photoshop". One of the most promising, workable solutions is the following advice:
"To get rid of the dust and scratches here is what you have to do. Make a copy of the background layer, select this layer, go to FILTER > NOISE > DUST & SCRATCHES. Set the Threshold to 0 and increase the radius setting until most of the scratches and dust disappear. Add some noise to this layer so that it closely matches your original image. Use this layer to "paint" in the dust and scratches, to do this make sure this background copy is still selected, go to EDIT > TAKE SNAPSHOT. Then select the original background and turn off the background copy layer. Click on the cloning tool and in the options box choose FROM SNAPSHOT. If the dust or scratches are light use the DARKEN MODE for the cloning tool (this will only fill in the light areas and will not affect the other areas of the image). If the dust or scratches are dark use the LIGHTEN MODE for the cloning tool and go over these areas. For this technique you should use a small brush size, although it is tempting to rush through it using a large brush."
I am stymied when I get to the part which says: "... Click on the cloning tool and in the options box choose FROM SNAPSHOT. ..." Can somebody help how to make the snapshot as the clone source? Am I (or the above) missing something? I work in PS CS5.
Many thanx for your time.
Mariano L. Honrado, Jr.
    Jun 20, 2012 1:33 AM   in reply to MarianoHonradoJr
    That's a somewhat odd description of the history brush functionality, if I'm not mistaken...
    Mylenium
  • PECourtejoie
    Jan 11, 2006
    Jun 20, 2012 2:13 AM   in reply to MarianoHonradoJr
    Hello, it might be instructions from long time ago. (I just looked, and there is no from snapshot option in CS3)
    Indeed, the history brush might be a good alternative. (just below the paintbrush, and make sure that you put the source for the history brush next to your sharpened snapshot)
    Another option: in the clone source panel, you can also clone from another animation frame, using animation frames as an alternate history.
  • PECourtejoie
    Jan 11, 2006
    Jun 20, 2012 3:06 AM   in reply to MarianoHonradoJr
    If you have two layers, sharpen one of them, use it as the Clone Stamp Tool source (ALT+click it), switch to the untouched layer (you can hide the top sharpened layer if you want), and simply clone in the changes.
    Jun 20, 2012 3:50 AM   in reply to MarianoHonradoJr
    I have a pdf from years ago, i guess around the time of photoshop 4 where i think it was Russell Brown that did those exact steps as you described.
    So i think photoshop 4 was the last version because the history palette came out in photoshop 5.
    Anyway one way besides the history brush might be to make a pattern of the layer (Edit>Define Pattern) and then use the Pattern Stamp Tool to replicate your instructions.
    The pattern stamp tool would be the step of cloning from a snapshot.
  • PECourtejoie
    Jan 11, 2006
    Jun 20, 2012 7:31 AM   in reply to MarianoHonradoJr
    It's a solution.
    Some would duplicate the layer, run D&S, change its blending mode to lighten, add a mask all layer mask (ALT+click the layer mask icon), and then paint in the D&S with a white brush. (so that blending mode can be adjusted after the facts, opacity, etc.
    But usually, one does not want to go remove such adjustment, so "baking in"  the changes in the image could be a usable workflow.
