Suuzzis
The new LR4.1 download has turned my photos a pinkish hue, why
Jun 20, 2012 12:46 AM
After instaling LR4.1 my photos turned a pinkish hue, on uninstaling they returned to their original colour.  They were taken with a Canon 600D 18-55mm IS lens. I am a hobbyist photographer and wonder if I can ignore this update without compromising future updates too.  I don't like what it has done to my photos.  The update refers to chromatic aberation correction, which it appears my photos don't need.
  • Victoria Bampton
    Apr 1, 2008
    Jun 20, 2012 1:11 AM   in reply to Suuzzis
    What are you viewing the photos in, when you're seeing the pinkish hue?
    And when you've uninstalled 4.1, what are you viewing the photos in, without the pinkish hue?
    And finally, raw or JPEG files?
    Jun 20, 2012 3:20 AM   in reply to Victoria Bampton
    I have exactly same problem. After instaling LR4.1 all of my photos are pink. See attached file. I tried to uninstal and instal LR and nothing happened. Could you please help?
  • Victoria Bampton
    Apr 1, 2008
    Jun 20, 2012 3:36 AM   in reply to Barusha28
    Can you switch to the Develop module and do a slightly bigger screenshot please?  I want to see the contents of the Basic panel and the Camera Calibration panel initially.
    Jun 20, 2012 3:40 AM   in reply to Victoria Bampton
    Is this print screen clearer?
  • Victoria Bampton
    Apr 1, 2008
    Jun 20, 2012 3:44 AM   in reply to Barusha28
    Perfect.
    Look at the white balance setting.  Way off the charts.
    Now press Reset (bottom right) - does that fix it?
    If not, hold down shift and the Reset button will change to Reset (Adobe).  Does that fix it?
    Report back on that and we can go from there.
    Jun 20, 2012 3:55 AM   in reply to Victoria Bampton
    Well, first option did not work and second did. However do i need to do that with every single picture? Because when I imported the pictures, everyone was like this. I there possibilite to reset them all?
  • Victoria Bampton
    Apr 1, 2008
    Jun 20, 2012 3:59 AM   in reply to Barusha28
    Great, so that means that you've accidentally changed your default settings somewhere along the line.
    Now go to Develop menu > Set Default Settings and press the Restore Adobe Default Settings button.  That will fix the pink defaults.
    Then switch to the Grid view and select all of the pink pictures, and press the Reset button in the Quick Develop panel or in the right-click menu.
    Jun 20, 2012 4:04 AM   in reply to Victoria Bampton
    Great, it is working. Thank you for your help and have a nice day.
