Martin_Winkler
Speedgrade CS6: Where is the disk cache?
Jun 17, 2012 6:08 AM
Hello speedgrade users,
I hope I'm not being a pest with this basic question, but I'm struggling a bit with the status of the documentation right now.. I have zero experience with Speedgrade, I do however know my way around several other finishing systems.
I'm looking for the persistent disk cache. I have been able to find the normal RAM cache under the settings, but nothing else. I'm talking about the thing that would cache my digital intermediate as it grows (with layers and grades and masks and custom effects on and prerendered for review), but so far I could only get RAM caching to work with DPX playback, I am simply unable to find the option to tick on the disk cache and specify the raid where it should go.
Can anybody nudge me a bit in the right direction?
    Jun 17, 2012 2:04 PM   in reply to Martin_Winkler
    Disk cache?  If I am not wrong, there isn't disk cache, in SG is all real time in GPU.
    Jun 18, 2012 3:38 AM   in reply to Martin_Winkler
    I can confirm, there's no background rendering, all is done on the GPU in realtime.
    Jun 19, 2012 7:39 AM   in reply to Martin_Winkler
    Yes, it seems to be a really heavy footage for your hardware. You can try to set Dynamic Quality (Settings -> Dynamic Quality) to lower resolution for playback.
    Jun 20, 2012 2:18 AM   in reply to Martin_Winkler
    Hey Martin,
    As Milan already suggested, Dynamic Quality can help to improve playback speeds. With Dynamic Quality, you can achieve at least real time playback at 1/8 or 1/4 resolution out of one 5K Red clip. In order to achieve 1/2 resolution real time playback you propably need a dual CPU setup (Dual Nehalem or similar). You can also improve playback speed by increasing the simultaneously loaded frames (settings-cache):
    To preview a single clip on a low-spec workstation/laptop you can also play out of RAM (green bar in timeline indicates preloaded frames, gray bar shows max available RAM). You can use up to 80% of installed RAM
    To achieve realtime with Red stereo at half resolution you propably need Red Rocket hardware accelerator boards in addition. SpeedGrade supports the use of multiple Red Rockets. I'd recommend to use two Red Rockets for working with R3D Stereo 3D projects. Depending on the complexity of your grading (amount of primaries, secondaries, LUTs etc) you should also consider a higher graphics  with a bigger frame buffer (Quadro 5000/6000).
    Dennis
