I am struggling to load a sequential array of images to appear like a moving image. So when u click the button the images load one after the other.
The code below is what i have so far, but it fails to do what i seek in that there's only one image loading which is the last image in the array, so either because the images are stacking up atop each other, or because i simply dont understand the basics...
And, i am unclear about what you said kglad, that my solution will be more complicated because i need to preload my image sequence and then use a loop to load it?
import flash.net.URLRequest;
import flash.display.Loader;
var count:int = 0;
var imageArray:Array=["1.jpg","2.jpg","3.jpg","4.jpg","5.jpg","6.jpg","7. jpg",
"8.jpg","9.jpg","10.jpg","11.jpg","12.jpg","13.jpg"];
for(var i:uint=0;i<imageArray.length;i++){
var btn:YourButton=new YourButton();
btn.ivar=i;
addChild(btn);
btn.x=0;
btn.y=0;
btn.addEventListener(MouseEvent.CLICK,clickF);
var ldr:Loader=new Loader();
addChild(ldr);
ldr.x=20;
ldr.y=20;
function clickF(e:MouseEvent){
ldr.load(new URLRequest("D:/flash cs5.5/image_sequence/twirlSeq/"+imageArray[e.currentTarget.ivar]));
function loadComplete(e:Event){
// first process loaded image, then...
count++;
if(count < imageArray.length){
loadCurrentImage(); // load the next image
} else {
// sequencial loading complete, carry on to next activity
function loadCurrentImage(){
ldr.load(imageArray[count]);
ldr.contentLoaderInfo.addEventListener(Event.COMPLETE, loadComplete);
you'll need to preload those images if you want them to load rapidly and appear to be animated.
so, load them all then use something like:
var count:int;
var ldr0:Loader=new Loader();
ldr0.contentLoaderInfo.addEventListener(Event.COMPLETE,loadCompleteF);
var ldr1:Loader=new Loader();
ldr1.contentLoaderInfo.addEventListener(Event.COMPLETE,loadCompleteF);
function clickF(e:MouseEvent):void{
count=0;
loadF();
function loadF():void{
addChild(this["ldr"+count%2])
this["ldr"+count%2].load(new URLRequest(imageArray[count]));
function loadCompleteF(e:Event):void{
count++;
if(count<imageArray.length){
if(this["ldr"+count%2].content){
this["ldr"+count%2].unloadAndStop();
loadF();
} else {
// last load completed
Hi kglad, thnx for replying. am still failing. If i understand the code which i need, it is saying that there's an array which is a string, 2 loaders that listen for the loadCompleteF event, the btn click function that counts and activates the loadF function, which adds the first loader, is counting for divisible by 2 and loading a new url request with the image array, in accordance to the counter. the loadCompletF function starts the count and conditions the laoders.
I am trying to understand your recommendation...not sure i do.
In any case, this is taking ma a step back because the code i provided is at least loading the last of the images while this new version is not, sorry to say, and many thanks anyhow because i do appreciate your help.
thanks for not giving up on me Kglad. i've done that - pasted yours in lieu of mine, got this strange error: ReferenceError: Error #1065: Variable TCMText is not defined.
Plus, i dont understand the code at all. i mean, would you be willing to put it in words for me, and then i might know what to do wiht the error...
create a new fla, add btn and add the code i suggested. test.
var count:int;
// initialize count
count=0;
// call loadF
loadF();
// add one of the loaders to the top of the displaylist and load the next image
// increment count
count++;
// check if the last has loaded
// if not clear the content out of the next loader.
// and call loadF so the next loader can load the next image in the array
loadF();
} else {
// if the last has loaded.
HI kglad. Amazing, it's practically done. And many many thanks for explaining what each phase is doing. THat is really helpful.
Otherwise, i have an issue, and a question. The question: why does "count%2" in the loadCompleteF function clear the content.
The issue: I am getting a familiar error - "SecurityError: Error #2000: No active security context."
which i am familiar with when there's a string that's a path, but in this case, i have the jpgs in the same folder as the fla file, plus, the string is an array. Usually this error is resolved when i change the string which is hte path. SO the question is, where can i put in a url path?
thank you so much, again.
